Question about Maytag 24 in. MDB8600AW Jetclean II Built-in Dishwasher
The Dishwasher is suddenly leaking heavily through the bottom of the door.
  • richard_f722 Aug 04, 2010
    My Maytag Built is Dishwasher Model MD86000AWB suddenly is leaking profusely through the bottom corners of the door. I removed any debris from the drain. I removed the foot panels below the door and ran a cycle. Continues to leak at the door. The drain seems to be ok since all water drains properly at the end of the cycle. It appears that the water level is to high during the cycle. I checked a round object on the lower left front of the dishwasher. Not sure if it is a float but it appears to hit a switch in the bottom of the machine. Not sure if is working or not or its function.
    Brigadier General:
  • 3,513 Answers
Hi
Please check the bellow link regarding your query…
http://www.ehow.com/how_112279_fix-leaky-dishwasher.html
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Aug 04, 2010
  • Maytag Master
  • 909 Answers
Take the bottom moving tray out then close door and see if leaking is still taking place. If so make sure the door is properly closed, then set machine to drain position. If water does not drain, clear the problem in the drain pump then retry. If pump is good, set program to start washing from the beginning.. Note if washing motor activates once water is in tub. Normally, water comes out of door if it has been forced open excessively by whatever manner, or if one of the two other components mentioned are defective.
    The drain appears to be working. I cleared any debris. I removed the lower kick panel to check the bottom of the machine and there is no leaking. Water drained properly when The wash cycle completed. The leak is in the door. There is a round knob type thing in the front left ... maybe a float. I checked it out and it presses against a switch in the bottom front of the washer.
    Not sure if is defective or not. I played with that to see if it affects the water levels. The water level seemed high during the cycle. Could it be the door gasket or is the water level too high during the cycle forcing leakage around the lower door?
Dishwasher model number 665 is discharging water at the bottom on the door during the wash cycle. Dishwasher is 10 years old but not heavily used. Lower basket is also showing signs of rust on tips of...
it may only be a problem with the float valve located in the bottom of the dishwasher. There is a relay switch attached to it on the outside(under the machine) that can get worn out and simply replacing the switch can help. The problem is that if this switch is not functioning properly, the water keeps filling in the cycle and it overflows out the door. Good luck!
Aug 03, 2011 | Kenmore Dishwashers
My dishwasher leaks at the bottom of door during operation and leaks heavily
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
Sep 20, 2010 | Dishwashers
Dishwasher leaks from the bottome of the door
if it leaked everytime then it would be your door gasket.but not everytime it's your door latch not engaging completely everytime.open the door and look and see if you can access the tightening screw for the door latch.probably not but look anyway.if you can then tighten the latch.
Nov 26, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Dishwasher door leaks heavily. this is a new problem today. The leak is from the lower right corner of the door.
It could need a good cleaning. Residue from soap and food tend to build up in that area all along the bottom of the door and seal. The other issue could be the seal itself, check the rubber seal at the bottom of the door and make sure it is not torn or damaged.
Unless the water level is getting to high, it should be one of these two.
Let me know. If you can provide me with the model number, I might be able to get a little closer.
Regards,
Aug 23, 2009 | Dishwashers
My clients unit is leaking substaintial water in
Check the drainage hose to see if its connected properly. it is located under the unit. it may be loose or, not connected correctly. if the drainage hose is connected properly, this will be a faulty water valve. replace if found to be faulty.
Jun 16, 2009 | Dishwashers
Door leaks on the floor in front of my dishwasher
1. make sure dishwasher is level front to back and side to side.
2. check the main washer arm (WD22X154) on the bottom side for leaks. If you use heated dry, the heating elements can cause the part of the spray arm directly over it to soften and eventually leak. When water comes out that leak it can spray at the bottom of the door, splashing water inside it and resulting in your leak.
3. if 1 and 2 OK, watch how you load the lower rack. If dishes or a bowl direct water from the lower wash arm to spray against the bottom of the door, especially at the center of the door bottom, the resulting splash inside the door allows water to hit the outer door panel and drip out a one or both corners of the door.
Dec 07, 2008 | GE 24 in. GSD2220Z Built-in Dishwasher
Leaking dishwasher
Are you washing cereal bowls or mixing bowls on the bottom rack? If so, are you placing them in front? Sudden leaks that form huge puddles can often be attributed to improper loading of the dishwasher. Most dishwashers don't have a seal across the tub front. The door closes over it and does a pretty good job of deflecting water back inside the wash cavity. However, if you place bowls in the front on the bottom rack rack they can divert the water right over the tub lip and onto the floor. This is usually the culprit that causes most leaks in dishwashers. Now, if you don't think you have a loading problem, remove the kick panel on the bottom of the dishwasher and check the drain line and pump housing for leaks. Check the door gasket for tears or cracks. Lastly, feel inside the bottom of the door with your hand. You should be able to feel the door insulation. If it is wet, then the problem could be a leak around your soap or rinse-aid dispenser. Depending on the model, some dispensers are mounted to the door with a gasket behind it. Sometimes this gasket can form leaks. I hope this helps.
Jun 05, 2007 | Maytag 24 in. MDB3700 Built-in Dishwasher
Maytag 24 in. MDB8600AW Jetclean II Built-in Dishwasher Logo
77 people viewed this question
Top Maytag Dishwashers Experts
Carmen Mikulic
Charles T Nevin
Charles T Nevin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
