Question about Haier 45-Pint Dehumidifier
We just purchased a Haier Model DE45EJ-L 45 pint dehumidifier from Walmart last night and it came with a manual that does not have the digital controls directions in it. The manual that came with it is directions for a knob controller. So we don't know what all the buttons do. Is there somewhere I can access the correct manual? Thanks.
SOURCE: I have a Danby Premiere
did you put the plug into the drain hole inside the top of the unit???
Posted on Jul 08, 2008
  • 2976 Answers
SOURCE: I have a 45 pint
It's for when you dump the bucket. You put the cup in to catch the drips while you're dumping it.
Posted on Jan 31, 2009
milten1
  • 1304 Answers
SOURCE: Used our new Haier 45 pint dehumidifier for a
what time of year is it,
dehumidifies are almost usless below 55 degrees
Posted on Oct 09, 2009
Testimonial: "Thanks!"
james3751
  • 614 Answers
SOURCE: I have a brand new Haier 45 pint Dehumidifier. The
Most of the time you set @55% RH. But on most Portable dehumidifiers you dont have a setting that tell you percent. Set about 1/2 way and see how much water it put out. That is about 60%. Go from there. Rus
Posted on Oct 29, 2009
Testimonial: "Thank you. I will give it a try."
  • 4736 Answers
SOURCE: Haier 45 Pint Electronic Dehmidifier Error Code E2
Jason, currently the only 45 pint dehumidifier that Haier sell is Model # DE45EK or DE45EK-L or EK-T. If any of those matches the Model Number of yours, you can down load and print the Owners Manual from the link below. However, the model numbers I listed make no reference to Error Code E2. If your Model Number does not correspond to any of those numbers, your unit is probably no longer manufactured or available.
http://www.haieramerica.com/en/asset/product/4ba7175e54
With that said, there are two things you can do. First, turn the Master ON/OFF Switch to OFF. Unplug the unit from the wall outlet and wait 12 - 15 minutes. Then, plug the unit back in and turn the Master On/Off Switch to ON. Did the Error Code clear itself. If so, set the controls as you normally would.
If that didn't solve the problem you can contact Haier Customer Service at 877-337-3639 and they will advise you what to do, to clear the error code.
Hope this helped you to solve the problem.
Posted on Apr 15, 2011
How many watts is a DE45EJ-L dehumidifier?
There is a review website that claims the unit draws 590 watts. The refrigerant this one uses is R-134a.
Haier 45 Pint Dehumidifier Review
A slightly larger unit is also available from Haier, the DE65EJ that uses R-410a, which is a more efficient refrigerant and allows the unit to be perhaps 20% more efficient. That larger unit is rated for 65 pints a day, and uses 710 watts. It is a bit heavier than the DE45EJ also.
Jul 01, 2014 | Haier Dehumidifiers
Model DE45EJ-L Fan works , does not take humidity out of the air
clean the dust off of the condenser in the front or the filter if it has one. no air flow results in overheating and no condensation across the evaporator coil.
May 07, 2012 | Haier 45-Pint Dehumidifier
I have lost my instruction manual and cannot change te temperature and humidity settings. How do you do this?
Here is a link to an Owner's Manual for a Haier 45 pint dehumidifier. Not sure if yours exactly like it or not, as you didn't mention a model number. You can download and print the manual for future reference.
http://www.haieramerica.com/cool-heat-air-quality/dehumidifiers/45-pint-capacity-electronic-control-115-volt-dehumidifier-de45ek-7
Look for the download in the left hand lower left on the page.
Hope this helps and thanks for choosing FixYa.
Sep 11, 2011 | Haier 45-Pint Dehumidifier
We just bought the DE45EJ. We removed it from the box and plugged it in....nothing. No lights, no beeps, no hint of life. The power source is good. The room temperature is normal. The bucket isn't full...
If you just purchased and it won't turn ON, don't waste time trying to fix the unit. Return it to the place of purchase for a replacement unit or a refund.
Thanks for choosing FixYa.
Sep 10, 2011 | Haier 45-Pint Dehumidifier
DE45EJ-T When you put tray in it won't turn on. If you push the lever with your finger it works without tray
That's because when you reinsert the bucket into the bucket holder, it's not making firm contact with the bucket safety removal switch. When you reinstall it, be sure that the bucket fits "squarely" into the holder from top to bottom. Once it's inserted properly, it just not tilt down on the bottom.
Jul 14, 2011 | Haier 45-Pint Dehumidifier
The dehumidifier runs for a few minutes and then shuts down. The humidity indicator shows that the humidity is 75% high in the room that it sits and I have it set for 40%. I'm thinking that it's a timer...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Apr 12, 2011 | Haier 45-Pint Dehumidifier
Haier dehumidifier model de45ej-t What does code e2 mean? Unit does not run.
Dehumidifier (DE45EJ-L) shows only E2 on the display -- no "buttons" work. Had been working perfectly -- we turned it off a few days ago. Any suggestions??
Jan 09, 2011 | Haier DE45EAL Dehumidifier
How do I use my dehumidifier
did not receive a manual for my humidifier DE45ej-t
I would like to have one
Nov 23, 2010 | Haier 45-Pint Dehumidifier
I'm searching for an owner's manual for a 45 pint model #DE45EA-L purchased in 2009. Please, advise.........Thanks!
try www.LGE.com
then you can sort through to the owners manual, it didnt solve my issue, and it wouldnt let me upload the service manual
Jan 22, 2010 | Haier 45-Pint Dehumidifier
Haier hdn455 45 pint overflows
Float switch is stuck, has a broken spring or the actuator arm is bent
Aug 19, 2008 | Haier HDN455 45 Pint Dehumidifier...
Haier 45-Pint Dehumidifier Logo
365 people viewed this question
Top Haier Dehumidifiers Experts
Steve
Bill Long
Jim Thurston
Are you a Haier Dehumidifier Expert? Answer questions, earn points and help others
