Question about Lexmark X7170 All-In-One Scan/Copy/Fax and Photo Printer
How to scan multiple pages onto computer - Lexmark X7170 All-In-One Scan/Copy/Fax and Photo Printer
  • Official Brand Answer
  • 3,344 Answers
Perhaps the Lexmark X7170 printer User's Guide will be able to help you. Just click on this link to download the User's Guide: http://bit.ly/c8EHEn. Scroll to Scanning for the instructions on scanning multiple pages or images. Thanks.
Posted on Aug 04, 2010
SOURCE: Scanning multiple pages
Use paper port software which is part of brother software suite but under different menu (check out under start - programs - paperport
Posted on Apr 08, 2008
safenude
  • 124 Answers
SOURCE: scan multiple pages to email
Do you have Microsoft Office?? If you do try this:
First, gather the paper you want to scan. If your scanner has anADF, you can load a stack of pages at a time. The first time you scan,Document Imaging detects the ADF for you.For more information about the ADF and whether your scanner has one,see the documentation that came with your scanner.
You will also want to sort your paper; if you have color pages thatyou want scanned in color, sort these in a separate stack from theblack and white pages. Load your first page, or first stack of pages(with an ADF) in your scanner.
Then, start Microsoft Office Document Scanning (the scanning component of the Microsoft Office Document Imaging program.)
  • On the Windows Start menu, point to All Programs (Programs in Windows 2000), point to Microsoft Office, point to Microsoft Office Tools, and then click Microsoft Office Document Scanning.
Tip If Microsoft Office Document Imaging is already running, you can start the scanning component by clicking Scan New Document on the File menu.
Set up your scanning optionsIn the Scan New Document dialog box, do one or more of the following:
  • To view your scanned file(s) in Document Imaging after they have been scanned (recommended), select the View file after scanning check box.
  • If your scanner is equipped with an ADF, click Scanner, and then select the Use automatic document feeder check box.
  • If your scanner is equipped with an ADF and you have double-sided originals, select the Original is double sidedcheck box to scan both the front and back of multiple pages. Place thepages in the feeder so that the page fronts are scanned first.The Microsoft Office Document Scanningdialog box will appear after each scan, allowing you to turn the pagesover and scan the page backs. Document Imaging automatically collatesthe pages in the correct order after scanning is complete.
  • If you have a true duplex ADF (one that automatically scans both sides of the page), do not select the Original is double sided check box. Instead, in the Scan New Document dialog box, click Scanner, and then select the Show scanner driver dialog before scanning check box. When your scanner driver dialog box appears during scanning, select the proper duplex settings.
  • If you want to scan pages manually, select the Prompt for additional pages check box. Office Document Imaging will pause after each page is scanned, allowing you to place the next page in your scanner.
  • By default, optical character recognition (OCR) is performed onyour document during the scanning process. Although performing OCR addstime to the scanning process, it also has the following benefits:
    • When you open the scanned document in Microsoft Office DocumentImaging, you can search for recognized text in the document, copyrecognized text in the document to another document or program, andsend recognized text in the document to Microsoft Word, withoutperforming OCR manually.
    • You can have your scanned files saved with an automatic filename based on the first words on the page (this is the default.)
    To turn off OCR during the scanning process (you can perform OCRmanually in the document in Document Imaging after scanning), do thefollowing:
    1. In the Scan New Document dialog box, select the preset you want to use, such as Black and white.
    2. Click Preset options, and then click either Create new preset (and then type a name for the preset), or click Edit selected preset.
    3. On the Processing tab in the Preset Options dialog box, clear the Use OCR to recognize the text of the scanned image check box.
Select location, name, or file type for the scanned filesPart of the scanning process is to save a scanned page to a file. Bydefault, when you scan multiple pages, the pages are saved in one file.If you want to save each scanned page as a separate file, select thenaming convention for the scanned files, or change the location or fileformat of the scanned files, do any of the following:
  3. Do one or more of the following:
    • To save each scanned page as a separate file, select the Save each page as a separate document check box on the Page tab.
    • To change the location for the saved files, click the Change button on the Output tab, and select a location.
    • To select the way the individual files will be automatically named, click one of the File Name options on the Output tab. (If you have turned off OCR during scanning, you will be unable to use the Auto name based on first words on page option.)
    • To select the file format the scanned pages will be saved in, click the Advanced button on the General tab, and select the options you want.
  4. Click OK.
Scan your pages
  1. In the Scan New Document dialog box, make sure the preset you want to use is selected, and then click Scan. If you selected the Original is double sided check box or the Prompt for additional pages check box, the Microsoft Office Document Scanningdialog box appears periodically to let you know that the scanner hasfinished. You then have the option to continue scanning (place anotherpage in a scanner that doesn't have an ADF) or turn your page or pagesover to scan the other side. Arrange your page or pages as desired, andselect the option you want to continue scanning.
  2. When all pages, all sides have been scanned, click Done in the Microsoft Office Document Scanning dialog box.
  3. To scan additional pages, review the Get started section above, and then repeat the instructions in this section (Scan your pages.)
Organize pages in the saved file(s)Now that you've finished scanning, it's time to take a look at theresults. If your scanned pages are not open in Document Imaging, do thefollowing:
  1. On the Start menu, point to All Programs (Programs in Windows 2000), point to Microsoft Office, point to Microsoft Office Tools, and then click Microsoft Office Document Imaging to start Document Imaging.
  2. In Document Imaging, click Open on the File menu.
  3. Locate the file you want to open (by default, the scanned page(s)is saved to the My Documents folder with an auto filename based on thefirst words on the page, such as Page1of.tif) and then click Open.
  4. Repeat steps 2-3 until all of the files you need are open.
You now have an online version of your stack of paper. Here are a few tips to get you started organizing pages.
  • Rearrange pages within a document In the thumbnail pane (thumbnail pane: Presents the current scanned document as one or more small images.), select one or more pages to move. Click any selected thumbnail and drag the selection to the new location in the thumbnail pane.
  • Copy a page to a new document In the thumbnail pane, select the page you want to copy. On the Page menu, click Copy Page. Switch to the Document Imaging document into which you want to insert the copied page. In the thumbnail pane, select the page that precedes the location where you want to paste the copied page. On the Page menu, click Paste Page.
  • Delete a page In the page pane or the thumbnail pane, click the page you want to delete. On the Page menu, click Delete Page.
For more information about scanning or organizing pages, see Microsoft Office Document Imaging Help.
The papers that were once cluttering your desk have now beentransformed into electronic documents. Within these documents, you canarrange pages, move pages to different documents, delete pages, printpages, add annotations, copy text to other Office programs, or send apage to someone in email. And still have room on your desk for yourcoffee.
Posted on Jan 27, 2009
bruxy
  • 98 Answers
SOURCE: scan multiple pages to one file
Hi Clint...
There are several programs available for downloading that work as print to pdf... some free some not. You can try pdf creator it's free and works well for me, the download isn't very long and the install is super easy.
after you install the program, you should see a pdf printer in your printer selections. You don't want to try to save your file, you have to select print and then select the pdf print to file option in your printer selection. Print the first file to a file you create to save it as a pdf. for the subsequent files you will need to choose Append to an existing pdf file and select the file you have created.
Test the file to see that both of your scans are in there and that they are in the order you want them to be in. If all that works find, you can follow the same procedure with each scanned page and they should all end up in one file.
the pdf print to file is also a great way to save webpages in one single file :)
hope that helps!
bru
Posted on Jan 29, 2009
  • 11 Answers
SOURCE: Scanning Multiple pages into one pdf
Typically it is possible, in advanced settings for scanning it will typically give you an option to scan multiple pages into one document.
Posted on Jun 26, 2009
  • 1121 Answers
SOURCE: does HP 8500 scan multiple pages into one file?
yes if you use a pdf editor or office suite.
Posted on Dec 25, 2009
I am scanning multiple pages at once however I want them to all save as separate pages onto my computer. how do I set this up? It doesn't seem to be working for me.
when you feed multiple pages i guess you are hitting the star button
in order to save them as separate pages you will need to select finish key not the start key this finish key is added with firmware if it is not on your copier already you may need to have a technician do this for you. good luck hope this helps.
Feb 19, 2014 | Konica Minolta Bizhub C224 Color Copier...
How do i scan multiple pages and sav it to my documents. It seems like i am only able to scan and save one page at a time
Hi
If you have a Top feeder on the scanner, you can scan mutiple pages. Change the setting of the scanned file to pdf file (not JPEG) by going to the scanner icon and change the type of file you want to scan. Scan it as PDF FILE and then it will scan multiple pages. Regards
Jun 16, 2011 | Computers & Internet
Can't scan more than one page under one file
you need to check for updated drivers from the manufacturer's website as the "old" drivers may not be completely compatible with windows 7.
this often happens when changing operating system to a newer OS
Jun 19, 2010 | Epson Perfection V500 Flatbed Scanner
I have an Epson Office Bx300F - I have a CV of three pages and want to know how to scan the three pages into one scan file Can you advise ? As you imagine having to scan three times means I then have to...
I have a different all-in-one but the tool used for scanning may be similar. When installing the printer, the MF Toolbox utility was also installed. If I want to scan multiple pages into a single document, I have three options for "Save as type". One is "PDF", another is "PDF (Multiple pages)" the third is "PDF (Add page)". I use the second option for multiple pages. Once the first page is done, a dialog box will appear and prompt me to insert the next page in the scanner and continue.
See if the tools installed with your printer have something similar.
Sep 03, 2009 | Computers & Internet
HP C6180 will NOT scan multiple pages into one file
If you want to scan multiple pages, go to HP Scan Pro, click on the SCAN menu, and then make sure that "Documents" is checked under "New Scan." This will allow you to scan multiple pages and it will scan black n white or color...whatever you place on the glass.
Jun 21, 2009 | HP Photosmart C6180 All-In-One InkJet...
Scanner is not reading multiple pages...
Check your scanning software settings. If you are getting only one file output, then you must have chosen 'multipage' option.
S. Mohan
Jun 12, 2009 | Canon DR-2580C Path-Through Scanner
Can't scan multiple pages into 1 document
Be kind m'53. Maybe you can scan to a folder, then use print setup to compile all the data on one page, if it's not much data. You'll have to do all this with the computer, don't expect the scanner to do that. There is always lots of software out there to do this kind of stuff.
Apr 02, 2009 | Brother MFC 7420 All-In-One Laser Printer
Touble scanning more that one page as a document
If you are scanning using the Scan to PC button, the unit will scan as you described. In order to scan multiple pages into one document, you need to go go through the Smarthru software, or whatever scanning software your unit includes. Since your unit is manufactured by Xerox, you can go to www.samsung.com and download the SmartThru software of your choice for free.
Sep 16, 2008 | Samsung SCX 4521F All-In-One Laser Printer
You cannot scan multiple pages into one file if your C350 doesn't have a HDD installed. Same problem for me, still trying for a workaround...
Jun 12, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Scanning...
What do you mean scan? Is it from the printer to the computer? Or just plain copy? When you want to scan to the computer, you need a software that can scan multiple pages. HP's document feeder can copy and fax multiple pages, so if the software supports multiple pages scanning, then I'm sure it can.
Jan 04, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Lexmark X7170 All-In-One Scan/Copy/Fax and Photo Printer Logo
361 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
