I have a Mitsubishi TV Receiver CS-40503. The problem is when the power is switch ON a BLUE HORIZONTAL LINE at the middle of the TV is coming out wisth no sound.
  • 934 Answers
No sound is probably because you're not on the right input but the horz line is a failure in the vertical circuit. Could be the vertical Ic itself Ic401 (LA7833) or the feeder caps just in front of it... In either even it in itself not an expensive repair. Be aware though that's an old unit and it is likely that several caps going bad through-out the unit. Make sure that you ask the tech to go through the unit with an ESR meter and test all the remaining caps in the power supply, horizontal, HV and regulation circuits. A little preventative and that set will still be running long after I'm dead and gone...
Bill
Posted on Apr 26, 2008
Ok i have a problem, while i was playing my ps3 on it there was a sudden large hum then a big black bar went through the middle, then color distortion just ingulfed the tv, and on the sides of it there are...
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
My name is Bruce
Jan 17, 2011 | Mitsubishi CS-40503 TV
Actually the model is cs-313050. its quite old. the problem is that the tv won't work in the way that when you turn it on (it won't even turn on anymore) there is nothing but a white or blue lineright in...
you didn't mentioned if it is a horizontal line but i think it is.
It seems that you have a faulty vertical I.C. that scan vertical line.Because you it is defective you've lost the vertical scanning thats why you have only a horizontal line on the screen.
You will confirm it by powering on the unit with your cable signal present.When the sound is present on every channel it is confirm that you have a problem on the vertical section. You must look for a qualified technician to solve the problem....
Jan 02, 2011 | Mitsubishi CS-40503 TV
Remove parental lock on a mitsubishi CS-40503
model# cs-40503 default parental code is 6629
Nov 16, 2009 | Mitsubishi CS-40503 TV
Mitsubishi CS-40503 TV previously had discoloration in the corners and lines at the top of the screen. Now I have no picture at all. Is it worth trying to fix?
no picture?do you see a white horizontal line in the mid?or black out?
its up to you if its really worth fixing. if its really old then ,i think its time to buy a new one, if not try comparing the cost.
May 18, 2009 | Mitsubishi CS-40503 TV
Mitsubishi CS-40503 Zapped by high voltage
the only option is to bring your x-former as sample or take a pic of it and post it.
Mar 26, 2009 | Mitsubishi CS-40503 TV
Narrow blue horizontal line across screen on intial power up
You have trouble with the vertical deflection circuitry. Probably something in the driver circuit or power supply to the driver. Maybe even a cold solder joint since it comes up after a little warmup.
Jan 17, 2009 | Mitsubishi CS-40503 TV
Mitsubishi CS-40503 Horizontal Picture Problems
Your trouble is with the vertical deflection circuitry. You'll need to have it serviced by a professional.
Sep 13, 2008 | Mitsubishi CS-40503 TV
Mitsubishi CS 40503
it is repairable and can be fix,,
Jul 30, 2008 | Mitsubishi CS-40503 TV
1995 Mitsubishi 40" Television - Worth Repairing?
there are bad solder connections on the vertical deflection IC resolder them and you will be fine
Mar 13, 2008 | Mitsubishi CS-40503 TV
CS- 40503 No Power
There is no external reset, and if the set is completely dead (not even a click when the power button is pressed) then there is probably an open main fuse or defective stand-by power supply. If the main fuse is blown then there is usually a heavy short in the main power supply, and either way the set should be looked at by someone with experience in Mitsubishi sets.
Jul 04, 2007 | Mitsubishi CS-40503 TV
Televison & Video Logo
51 people viewed this question
Top Televison & Video Experts
Electro Med Services...
