Question about Sony VAIO VGN-FW145E/W Laptop
Installed drivers on to sony vaio Fw-11m, running vista. It wasn't plugged in just running off battery. Went to open it back up and the green power button was on but no power to keyboard or fan. But the optical disc still powers up. Every time i press the power button the charging light switches on? i've tried charging it but hasnt done anything...
  • 833 Answers
SOURCE: Sony Vaio VGN-SZ440n11-Blank Screen
You have a warranty. You should contact the appropriate people. Do not try to fix this yourself. If you return the machine for service, ask them to get any data off of it that you need. It is possible that your drive has crashed.
Posted on Jan 07, 2008
byteguy
  • 2229 Answers
SOURCE: power socket for sony vaio is broken how do I
On a Sony, many times the power socket is a separate piece that can be replaced. Unlike many laptop motherboards, these power sockets are a separate item the plug into the motherboard. \
Bad news is you have to dissassemble the computer to get at it.
Posted on Dec 22, 2009
  • 846 Answers
SOURCE: sony viao wont boot, battery light flashes amber
Move the power jack around while plugged in, does the blinking on the battery stop when you hold it in certain positions? If so, your dc-jack needs to be soldered, but i probably was loose already before you started using it. It could be a broken motherboard issue as well. You can try to open the laptop and check the dc connection. There is a Laptop Repair Guide that shows you how to take apart a laptop, the sony may be made in a similar way. Sony Repair NYC
Posted on Jan 17, 2010
EMKartha
  • 163 Answers
SOURCE: Sony VAIO VGN-FE770G only runs on AC power, battery not working
This looks like the system is not able to sustain itself on the battery power. I have a doubt here. Is it a new or an old laptop. Either Case we have to suspect the battery charging and battery condition. One another reason could be that the battery contact is not good. But this could be of the least chance as the manufacturing of such devices would be perfect in all standards. Lets check the battery power first.
A sony Vaio never operates if the battery is not detected or the battery is not charging, while the system is up and running, you can see a small picture of the battery in the system tray which is at the right bottom corner of the screen. Run your mouse over the same and you will find a tooltiptext message and you can see if the battery is charging or not. If not, your hardware has a problem. If its charging but the battery charge is not increasing, then you have a battery problem. If its a battery problem and that the system is under warranty, you can well get a replacement for free. Hope this resolves the issue. Good Luck.
Posted on Mar 14, 2010
Testimonial: "Thank you for your help - I really appreciate it! My computer is 3 years old, so I suspect the battery is defective. "
  • 56 Answers
SOURCE: sony vaio won't charge new battery
i believe it is a charger issue not a battery issue replace your charger
Posted on Apr 09, 2010
My problem is driving me crazy! I have a Sony Vaio FW 400 series. I switch my machine on, the green power light comes on, it then flashes orange and the machine goes off, then it comes back on...
Kindly try the following...
- remove the battery and power on the laptop using power cable.
- issue not fixed.. remove the power cable and make sure you have not installed the battery ...then press and hold the power button for 30 sec.. then check at the bottom of the laptop if you have access to memory card if so try to open the back cover and reset the memory card and check.
-issue not fixed.. if you have access to the wifi card try and reset the wifi card and check
-if the memory card and wifi card is inaccessible then you will need to visit service center or call support
Jan 27, 2018 | Sony VAIO VGN-FW145E/W Laptop
Power socket is loose
dc jack socket for Sony VAIO VGN-FW is very easy to loose, I think you can replace the cabled dc jack, no solder work, plug in and work, see this reference page: http://www.lapdiy.com/sony-vaio-vgnfw-series-power-jack-port-connector-dc-in-cable-p-2647.html
the above item is with ground cable, it is known that sony FW uses both harnesses with or without ground cable, you can cut the ground cable directly if your laptop does not use it, or order from this page for the one without ground cable: http://www.lapdiy.com/sony-vaio-07300012492a-power-jack-port-connector-dc-in-cable-p-2782.html
hope this can help you
Feb 04, 2010 | Sony VAIO FW Series VGNFW275JH
Sony vaio VGN-SZ430N/B
I'd suggest ring back Sony support and tell them that your OS is Windows 7 - not Vista. Therefore, you need the upgraded VGA driver because the Vista driver is incompatible with Windows 7. Hope it all goes well. If my suggestion works for you, please do rate me. Thanks
Feb 04, 2010 | Sony VAIO Notebook
Power socket for sony vaio is broken how do I
Dec 22, 2009 | Sony VAIO FW Series VGNFW275JH
Only strts up with the power cord connected, but takes me to a window that makes me pick safe mode, go to the prior set up, o normal estart up tried all but gets me back to that window
It sounds like your battery has died on you. If you start it up and when you can see anything pull the power cord out. if it just dies on you then that is your problem. A replacement battery is $70-$150 depending on where you get it from. It pays to shop around online and even around town.
The rest of your errors should just be caused by windows not shutting down properlly. When you get your battery fixed it should go back into safe mode once more and then reboot properlly into normal windows.
It is possible that windows has become corrupted but not shutting down which means it would need to be reinstalled.
Sep 15, 2009 | Sony VAIO VGN-TX750P/B Notebook
I am facing a problem ininstalling the driver in my Sony Vaio
There is no original driver for your model available now...
Feb 25, 2009 | Sony VAIO FW Series VGNFW275JH
Sony vaio desktop wont turn on
This type scenario normally indicates a power supply failure. Try connecting a known good power supply to your Sony Vaio desktop.
If you do not have a spare power supply, (many people do not) the alternative is to short the the black and green wire on the power lead connecting to the motherboard using a paper clip. This is not a desirable solution and very dangerous, but will help to diagnose the problem. Do not insert any objects while the power supply is energized. Ensure it is unplugged first.
Should the computer start with the green and black wire shorted, the problem is with the power supply. If not, the problem is likely at the motherboard level.
Hope this helps you.
Dec 29, 2008 | Sony VAIO VGC-RB42G PC Desktop
DRIVERS AND DUAL BOOT PROBLEM WITH SONY VAIO
if vista is ntfs thn you may be able to use paetition mgic to divide a chunk of drive to fat32 and install win2k i dont have dealings with vista yet.
Mar 29, 2008 | Computers & Internet
My Sony Vaio Laptop PCG-661R not booting
unplug from power and remove battery and plug back in.
Dec 12, 2007 | Sony VAIO PCG-K25 Notebook
Sony VAIO VGN-FW145E/W Laptop Logo
78 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
