Question about Electrolux Ovens
Replace oven fan motor - Electrolux Ovens
  • 24 Answers
Take out the shelves and side hangers. SWITCH OFF.
There is usually a panel at the back of the oven cavity, undo the screws around it to access the fan blade. At this point you should be able to determine if there is another panel that the fan mounts onto that comes out through the front. (unlikely). Undo the centre nut on the fan blade which is usually a left hand thread - turn clockwise to undo. Take off the fan blade.
Next you gotta get to the rear of the oven and remove the back panel to access the fan motor. Once inside note down where the wires go. Remove wires from motor.
Back inside the oven cavity you will find screws that hold the motor in place (often three). Have someone hold the motor while you undo them. The motor should now be withdrawn from the rear.
Replace motor in reverse order.
Posted on Aug 04, 2010
2 Suggested Answers
apart4u
  • 213 Answers
SOURCE: replace fan motor in an electric fan oven
For all Free appliance repair videos visit our VIDEO TUTORIALS
1, If the fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the NEFF element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your NEFF fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
Posted on Jan 14, 2010
Testimonial: "thank you very much very helpful"
The main oven fan in Hotpoint BD32B is sticking (tries to rotate but goes slow and stops). I need to either re-lubricate the existing fan or replace it. How do I remove the fan?
Remove the cover at the rear of the oven compartment, then holding the fan blade with one hand, undo the nut holding the fan on, it is a left hand thread, so turn the nut clockwise as though you were tightening it.
To remove the motor itself you will have to undo 3 screws securing the fan motor from inside the oven compartment, then remove the outer rear cover of oven to remove the motor.
May 10, 2011 | Ovens
Oven fan motor is burned. Can we rewire the oven to bypass the fan motor
No. The whole combustion process relies on the fan motor drawing combustion products into the cavity and out the flue. Get the motor replaced or rewound.
Feb 04, 2011 | Imperial ICV-2-H Turbo-Flow Electric...
Hello. My oven worked over xmas with no problems. If I start my oven the heating element heats up and the fan runs slow, the fan will not run fast anymore at any temperature can you please help??
Hi.
This indicates a problem with the fan motor, usually the only solution is to replace the fan motor complete.
You could try spraying the motor bearings with WD40, but this would only be a temporary solution, as eventually it would slow up again, and possiblt sieze up.
The danger is if you keep on using it like this, then in it will cause the element to burn out thriough overheating. so to be certain, I would replace the fan motor.
Jan 05, 2011 | Whirlpool AKZ159IX Oven
Fan in main oven does not come on when oven is switched on,there is a delay of sometimes up to fifteen minutes oven has often reached desired temp from element at back of oven without fan operating. When ...
The fan motor is obviously faulty, the only real solution is to fit a new fan, if you do not, then the element is in danger of burning out, do not delay replacing the fan motor.
Nov 06, 2010 | Hotpoint Ovens
FAN NOT WORKING,OVEN NOT GETTING HOT ENOUGH
1 How to change a fan oven element and How to change a cooker oven fan Motor
If you have a electric Cooker or Fan Oven which is not heating it could be one of the following problems.
1, If the
element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit i.e. broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven
Mar 04, 2010 | Ovens
My fan oven element( Neff U1452 )has been replaced
they should last 12 months minimum there could be a problem with your fan motor here is a standard fan oven check list.
You-Tube video "6QGurNvbI0Q" placeholder (do not delete)
For all Free appliance repair videos visit our VIDEO TUTORIALS 1, If the fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your oven thermostat
4, A quite common and easily overlooked answer is if your oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
Jan 13, 2010 | Neff U1452 Double circotherm plus Electric...
Replace fan motor in an electric fan oven
Jan 13, 2010 | Neff B1421 Electric Single Oven
Bosch oven loud fan noise
JUST REPLACED BOTH FAN MOTORS ON A DOUBLE BOSCH 755. DIDNT HELP MUCH.THE FAN IS LOUD COMPARED TO OTHER BRANDS.UNLESS YOU NOTICE A DRASTIC CHANGE IN NOISE, DONT WASTE YOUR MONEY ON A NEW FAN MOTOR.ITS JUST THE WAY IT WAS MADE.
Nov 26, 2009 | Bosch HBL 445 Stainless Steel Electric...
Neff oven fan not turning and element blown. Is the motor bad as well?
it might also be the timer For all Free appliance repair videos visit our VIDEOTUTORIALS Nefffan oven element video1, If the fan motor in the back of the oven is going round andthe temperature light is on (normally little red light), but there is no heatthen you will probably need a new oven element, these are generally very easyto fit and readily available from our website these can be tested with aelectric meter.
To gain access to the NEFF element you willhave to remove the back plate from inside the oven. Once removed you will seethe fan and element, if youlook closely at the element you willprobably see a small hole burnt in it where it has blown. Sometimes howeverthere is no evidence of a fault but the element is open circuit ie:broken inside the element casing, either way it will need replacing. Someelements will are fixed from inside the oven and some are held in place by nutsfrom the rear of the machine.
2, If your NEFF fanoven is getting warm but takes a very long time to cook or is burning the foodmore on one side than the other, then you need to check if your oven fan motor is working you willsee the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven thenyou need To replace the oven fan motor is a little moreexpensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heatingand burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: noheat and no fan then the chances are that someone has put the oven timer into AUTO mode,simply put oven back to MANUAL mode and all should be working again.
Jun 19, 2009 | Neff U1452 Double circotherm plus Electric...
I need to take off a fan from a neff oven,how do i remove the fan?
Remove inner rear panel of oven.
Unscrew nut clockwise that secures the fan blade to the motor, undo screws that secure the motor. and replace same. You may have to remove main back panel to access fan motor screws and terminals.
please leave a fixya rating for my solution.
Thanks.
Jan 25, 2009 | Neff U1421 Double circotherm Electric Oven
Ovens Logo
205 people viewed this question
Top Electrolux Ovens Experts
Mack Baxter
John Tripp
John Tripp
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
