Question about Samsung Televison & Video
Hi I have a SAMSUNG AH59-02131B remote n I need the code to tune it in to my samsung tv
SOURCE: virgin media tv remote control
what you have to do is ring virgin and ask then to send the code.
this code is done stight to your set top box
Posted on Feb 08, 2008
SOURCE: Remote Codes
i lost the codes of my remote and now it's malfunctioning.. the brand is CHUNGHOP RM-88E..the Brand of my tv is Goldstar.. can you help me with this or can you just give the codes?
Posted on May 19, 2008
SOURCE: Need vizio code for Samsung remote!!
I have a 37 inch vizio and had the same problem. After a little web research, I came across a suggestion that the LG codes might work. I tried it and found that the code 19 worked. You might try that. If 19 doesn't work for you, one of the other LG codes might (they are 06, 21, 22, 23 or 78).
Posted on Dec 29, 2008
SOURCE: Need Comcast Remote Code for Samsung LN32A330 TV
I contacted Comcast and here are your codes for the three way remote with DVR Samsung 10812, 10766, 10814. I have the same TV Samsung LN32A330 and it was the very first code for my TV! Hope this cuts down your frustration!
Posted on Feb 04, 2009
  • 325 Answers
SOURCE: i need to re tune my samsung tv but have no remote
you can always use the button on your Tv itself.
ie menu = Menu
Channel up/down = take you up and down
volume = goes left and right.
follow these steps
Menu,
channel down button to CHANNEL
press the volume button along
channel down button to AUTO STORE
press the volume button to Start the scan.
right now you have your telly tuned in. What you could do it get an old sky remote off a friend/ neighbour. or buy from argos etc ( a lot cheaper then getting a replacement samsung one)
press the following buttons on the sky remote to program it to work with your samsung tv.
TV,
RED + SELECT
TV.
0060
try the volume if this works press SELECT to save this code if it doesnt press Tv then try the volume again. repeat this step until the volume works your telly. once it doest dont forget to press the SELECT button to save.
Now you will be able to change your volume use the number keys. if you also press the HELP button on the sky remote this will also change your AV / SOURCE I hope this post helps you out. When it does please leave a thumbs up for me Please
Cheers Little Dish Fitter
Posted on Sep 21, 2009
How do i tune my AA59-00310 remote into my TV
HI you will need the code for the model tv you have here is a link to the codes just reference the list by the tv you have and it will give you the code.
http://ars.samsung.com/customer/usa/jsp/faqs/faqs_view_us.jsp?PG_ID=-1&AT_ID=5716&PROD_SUB_ID=0&PROD_ID=41
Feb 04, 2010 | Samsung BN59-00455A Remote Control
I need help programing my rca remote to a samsung television
Hi
Ideally I need you to clarify a few details on your exact RCA remote model and number and also whether this is a Samsung TV or other unit like a DVD etc.... that you wish to program
However assuming it is a Samsung TV here is a list of the common RCA codes for this TV. You will need to go through each one individually until you find one that works.
Code 1004 for Samsung TV Code 1005 for Samsung TV Code 1006 for Samsung TV Code 1012 for Samsung TV Code 1013 for Samsung TV Code 1015 for Samsung TV Code 1017 for Samsung TV Code 1019 for Samsung TV Code 1082 for Samsung TV Code 1104 for Samsung TV Code 1105 for Samsung TV Code 1106 for Samsung TV Code 1171 for Samsung TV Code 1172 for Samsung TV
Hope this helps. If so please do rate my answer.
Otherwise please post up additional details as outlined and I will see what I can find.
Many Thanks.
Sep 06, 2009 | RCA ACC-RCAURC Remote Control
Samsung Remote Control not working
any samsung remote will work any samsung television. Samsung use the same code for all television's as do Sony
Samsung remotes are quite expensive you could always buy a Sky digibox remote and tune that in to work you tv that would be a cheaper option.
how to tune in the sky remote to work your samsung tv
TV,
RED + SELECT ( blinks twice)
TV,
0060
TV,
SELECT.
Job done
Hope this helps you out.
Cheers
Little Dish Fitter
Sep 02, 2009 | Samsung LE26R74BDX 26 in. HD-Ready LCD...
Side by side Samsung TV's need remote control solution
If possible turn one off and tune the other. Then turn the other off and tune it. Then turn on the other. That is your only option at this point.
Feb 16, 2009 | Samsung PN50A650 49.96 in. Plasma HDTV
Samsung remotes
is there a text center
Aug 19, 2008 | Samsung TV Remote Control
Sky remote tune to samsung
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Samsung Code: 0060
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
Aug 13, 2008 | Samsung WS32Z308P 32" TV
Thomson top up tv remote codes
need sequence to tune in remote controller
May 13, 2008 | Televison & Video
Televison & Video Logo
380 people viewed this question
Jerry Greenberg
Jerry Greenberg
