Question about LG LSC26905TT Side by Side Refrigerator
I woke up to a loud buzzing sound from the freezer side, behind the automatic ice maker. Sounds like a fan? Model LRSC 26941SW.
    President:
  • 1,099 Answers
This is common. Unplug it or turn off the circuit breaker for a full 5 minutes. Then plug-in and follow instructions. Things will be good
Good luck!!!!!!!!!!!!!!
Posted on Aug 04, 2010
GE Side by Side Refrig - loud noise behind the ice maker section Model PSS25SGMB BS
it sounds like the evaporator fan blade is hitting some ice that has built up around the blades i have seen this happen a lot on g.e. SxS lately,if you can remove the ice maker and dispenser you can see the fan blade,if you dont want to do this then shut down the refrigerator and leave freezer door open and heat it carefully with a hairdrier to speed the process up to melt this ice then restart it and the noise should be gone
Aug 30, 2012 | GE PSS25SGNBS Side by Side Refrigerator
Model FRS23R4A - loud humming noise coming from inside freezer section at top behind the ice maker. What might this be?
Somebody hiding in your freezer? Na, I'm just kiddin! Sounds like an evap fan going bad on ya. Eventually you will need to replace the fan!
Thanks and please rate me!
Tips Provided by: www.HoustonRefrigeratorRepair.com Brian Gillespie (GOFAR Services, LLC)
Aug 26, 2011 | Frigidaire FRS23R4A Side by Side...
Ice is forming around fan in back of freezer compartment
The defrost system is not doing it's job. I bet if you took the panel off below the fan you will see more ice on the cooling coils. There should be a light coat of frost on the coils but not a heavy ice build up. There is a heating element at the bottom area of these coils which should be defrosting all this ice.
1. A defrost timer turns this heating element on.
2. The heating element melts the ice.
3. A thermo disc attached to the coils will turn the heater off.
One or more of these are not doing it's job.
Dec 16, 2008 | Frigidaire Refrigerators
Frigidaire side-by-side model # FRS26H5ASB4 making humming or buzzing noise
I had the same problem. I found the buzzing noise was caused by ice build up around the fan motor inside the freezer. I believe water must have leaked down around the fan during a defrost cycle. I removed the ice maker, the ice cube bin and ice dispenser auger motor. It sounds complicated, but it isn't too bad. The ice maker and auger are connected with quick connect plugs. So just unplug, remove the screws and remove them from the freezer. You will need to remove several other screws as well, I believe 11 in total as well as the top freezer rack. This will give you access to the white aluminum panel that runs from the top of the freezer to about halfway down the back of the freezer. After you remove the aluminum panel you will see the fan about half way down the freezer. I found a lot of ice around my fan. The fan blades were hitting the ice causing the buzz. Remove the ice and the buzzing is gone. It took me an hour to complete this repair. I hope this helps.
Nov 08, 2008 | Frigidaire FRS26H5AS Side by Side...
Loud Buzzing Noise from Behind Freezer
Sounds like the freezer fan blade is hitting on a build up of ice or frost. You may have a defrost issue, or it may be a one time thing, like the door was open for a long time (object holding door partially open) or also check the ice dispenser duct door to make sure it is closing. Sometimes a chunk of ice hangs up in the ice shoot, allowing moist air to enter freezer, resulting in the extra frost / ice near the freezer fan. You might also check the door gaskets, especially the bottom side where sugary liquid spills might cause a gasket to tear. #2: Long run times: If cooling is good, don't worry. Older refrig's often ran less time, but used much more electricity than the newer refrig's, even though new one run longer. (Like having a 40 watt light bulb on for 20 hours a day uses less electricity than having a 100 watt bulb on for 10 hours a day)
Aug 27, 2008 | GE PFS22SBSSS Stainless Steel French Door...
Ge eterna refrigerator loud humming
suspect you have a problem with the defrost system and hence the noise with the fan. take back panel off inside the freezer and if i'm right, melt ice off with a hairdryer. get back to me to say the results if you want
Aug 23, 2008 | GE Profile PSW26P Stainless Steel Side by...
Loud Buzzing noise
Sounds like the fan is hitting some ice build-up. If you can access the area of the fan motor you can try a hair dryer to defrost the ice out of it.
Apr 15, 2008 | Frigidaire FRS23R4A Side by Side...
GE profile side by side refrigerator
In this Video Im Replacing Evaporator Fan Motor.
Sep 03, 2007 | GE Profile PSW26P Stainless Steel Side by...
LG LSC26905TT Side by Side Refrigerator Logo
129 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
