Question about Cartier Santos W20056D6 Wrist Watch
How do i remove links strap to big - Cartier Santos W20056D6 Wrist Watch
Casio 3053 strap - I need to remove 1 or 2 links from the strap. How do I do this ? Thanks.
take a pish pin, inside had a arrow , that is the big head out , cotter pin. tap on pi opposit hole. pin comes out and pull . when inserting in pin tap down pin until it is in band.
Jun 17, 2011 | Casio A168W Wrist Watch
Its too big to fit my hand good but also i cannot shorten it enouph so it can fit me without being extremely tight. Is there an alternate way to shorten it. I noticed 4 holes where the clasp is and was...
Some clasps have holes in them to allow you to adjust the straps in smaller steps than removing links.
It sounds as though yours in one of these.
The pins are spring loaded just like the ones used to fasten the strap to the lugs of the watch, so you can apply a probe to one end of the pin with one hand, while applying a gentle force in the direction you wish the strap to go with the other hand.
Then do the same with the other side and repeat as needed.
Jan 05, 2011 | Breitling Bentley 6.75 A4436212.G573.970A...
I am trying to figure out how to shorten the wrist band on my Casio Edifice EFA-119.
mcdevito75 here, If your Casio has a metal band, you can remove 1--2 links, this takes a special tool called a link remover, best bet is to look for a small watch repair shop in your area. If your Casio has a strap, the buckle may be able to move up the strap to fit your wrist, if so, move the buckle up the strap to fit your wrist and cut offf the exccess strap. If not, you"ll have to replace the entire strap. Hope this helps.
Aug 03, 2010 | Casio Edifice EFA109-7AV Wrist Watch
How do I shorten my Ice watch strap?
mcdevito75 here, I imagine you mean a Band (metal) they can be shortened by removeing links from the band itself, you"ll need a specific tool called a link remover tool. they are available on ebay. However by the time you get the tool and the time to do the work, and if you don"t do any work on watches, the best bet is to look for a small watch repair shop in your area to remove these links. Hold onto the removed links for later replacement. If it"s a Strap (material) on your watch, say, leather, rubber etc. simply cut the excess strap at an angle with scissors.
Jul 17, 2010 | Watches
Watch strap a little big
mcdevito75 here, Maybe a link or 2 can be reoved from the metal band, or an adjustment at the clasp can be done. Look for a small watch repair shop in your area, they can help.
Jul 08, 2010 | Casio A168W Wrist Watch
Hi I have a quartz woman's watch that I bought at Big Lots store the other day.. the wristband is too big for me.. how do i shorthen it ? that band is metal...stretching whatever I call-- I need to remove...
Save your nerves and your money. Visit your nearest watch repair shop and ask to get links out. If you will try to do it yourself, you will loose your strap as you wont be able to put it back together. If you anyway decided to do it yourself, click on my profile and check out my solutions. I do explained all this tricky job to one customer about a year ago, so, you will definitely find it if you have enough patience to go through all my solutions. Rate me plz.
Mar 02, 2010 | Citizen Cortina Eco-Drive BM8194-50L Wrist...
How to make the strap shorter
Those are very difficult to adjust. Unless you adjust those often, then your best bet is to take it to a watch repair business and let them adjust it for you! :-)
Jan 07, 2010 | Citizen Watches
How to adjust a Rubber strap
well all i did was cut the strap
Aug 30, 2009 | Watches
Cartier Santos W20056D6 Wrist Watch Logo
283 people viewed this question
Top Cartier Watches Experts
k24674
john h
Are you a Cartier Watch Expert? Answer questions, earn points and help others
