The bases of a trapezoid are 22 and 12 respectively. The angles at the extremities of one base are 65 degrees and 40 degrees respectively.Find the two legs.
  • 29 Answers
SOURCE: A tree 65 feet high
-tan(65/41)
58
Posted on Dec 12, 2010
SOURCE: X2gen MG19E monitor
It DOES tilt...hold the screen by the sides and tilt up or down.
Well, my MW19U (X2gen) does.
Posted on Feb 19, 2008
SOURCE: Parts Availible for EDU_SCIENCE 24508 02524A
You can purchase a tripod on the internet-- BUT it will probably be more expensive than the telescope you have.
See if you can rig something up using wood and fittings from your local hardware store.
Posted on Jan 11, 2009
  • 8 Answers
SOURCE: Airport Extreme Bases Station not detectable with utility
This depends... Reaching them wirelessly may be unreliable for a number of reasons, so, I'll proceed on the assumption that you are attempting to test in the simplest lowest-variable situation:
First, make sure that you have the latest Airport Utility for your Mac.
Connect your Mac to the Airport via a single Category 5 (or 5e or 6) cable. Factory-reset the Airpot and then wake up the Mac. If the utility still can't discover your airport, it's probably time for a trip to your local Genius bar as you most likely have a hardware problem.
Lather, rinse, repeat for each of the two airports.
Posted on May 30, 2009
gemmy23
  • 346 Answers
SOURCE: WE NEED A NEW BAS PLATE ANGLE/TILT LOCKING KNOB.
Here is a home page for the vanguard company. Try contacting customer support to find those parts. Good luck...hope this helps.
http://www.vanguardworld.com/gfa/index.php
Posted on Jul 11, 2009
HOW FAR CAN THE PEDESTAL STAND 'SWIVEL'? I CAN GET ABOUT 15 DEGREES EITHER WAY - IS THIS THE LIMIT OR CAN I ADJUST TO INCREASEDEGREE OF 'SWIVEL'?
I believe this is the limit, physically altering the engineered base for this television may put it in danger of falling or breaking. It's a 40 inch LED TV and really not that heavy, perhaps you could look for a lazy Suzann type of base that you could put beneath the TV to give you more extreme swivel capability.
Apr 17, 2015 | Samsung LE40R73BD 40 in. HD-Ready LCD...
I have a Minerva 44" Fan. I have Vaulted Ceilings with a 12-12 pitch. The down rod is 3/4 in. What slope ceiling adapter is recommended ?
Mike, a 12/12 pitch is 45 degrees. You may have to use a little math to figure out how far down to hang the 44" fan to keep from hitting the angle of the ceiling. Geometry specifically. Remember the A sq + B sq = C sq for figuring the hypoteneuse of a right triangle?? If the ceiling fan is 44", the base (A) of the right triangle is 22" with NO CLEARANCE to the angled ceiling. A 45 degree angle dictates the base and the height are equal, so height (B) of the triangle is also 22" with NO CLEARANCE. If you want a few inches of clearance, extend the height by 4" and there should be enough clearance to allow the fan operation.
I would suggest playing with the figures before you buy the extension rods though. The simple answer to you question remains however...45 degrees.
Mar 08, 2015 | Dryers
If an angle of a parallelogram is one- third of its adjacent angle, find the angle of the parallelogram
Since the two adjacent angles of a parallelogram must add to 180 degrees, the two angles have to be 45 and 135 degrees respectively.
Nov 02, 2012 | Office Equipment & Supplies
How do i lower 65 rear suspension on type 1 beetle
Not too hard, but time consuming. You need standard and socket wrenches,
a length of chain, and a floor jack.
It would be best if you referred to a Bentley manual for the actual
torsion bar procedure. The only tricky part of the process is getting
the spring plate off of its lower stop. It's under a lot of pressure, so
you chain the base of the floor jack to the chassis, then lift the spring
plate enough to pry it out with a big screwdriver. Installation is the
reverse of this.
The torsion bars are splined with 40 splines on one end and 44 on the
other. You can turn the spring plate in 50 minute (5/6 degree)
increments by turning the chassis end one spline in one direction and the
spring plate end one spline in the other direction. You adjust in the
angle you want.
Jan 24, 2010 | Volkswagen Beetle Cars & Trucks
How to use the SIN botton EX: 25 x SIN(65)
Before starting to enter the angle measure to calculate the value of a trigonometric function (sine, cosine, tangent) you must make sure that the current angle unit (degree, radian, grad) the calculator is configured to be using is the same that your problem requires. For instance, if you are solving a problem in which the angles are given in degrees you must verify that the calculator is configured to work in degrees.
When calculator is turned on, the angle unit is reset to degrees, but just to make sure it still is, look at the display: It should show the indicator DEG. If the display indicator is not DEG press the key [DRG] once or twice until you see the DEG on the screen.
The angle unit being taken care of, we turn to the actual calculation
Usually, to calculate the sine of an angle, you enter the angle value, press the [SIN] key and hit [=]. As you can see the sine function eats the number stored in its current register and calculates its sine.
To make sure that the calculator is taking the sine of 65 and not of 25*65, I would enter the calculation as follows
[65 [SIN] [*] 25 [=] : the result should be 22.65769468
or
25[*][ ( ] 65 [SIN] [ ) ] [=]
In the last key sequence, the use of parentheses forces the calculator to pause all previous calculations and wait for the closing right parenthesis. When the right parenthesis is entered, the calculator takes care of the contents of the parentheses first, then resumes the operations entered before the parentheses.
Importance of checking the angle unit before a calculation
Let us perform the calculation with angle unit
  1. in degrees : 25* sin(65) = 22.65769468
  2. in radians : 25 *sin(65) = 20.67071699
As you can see, the two values are not very far apart and since you are expecting a value that does not exceed 25 you might want to check your result.
Hope it helps.
Thank you for rating this solution
Dec 12, 2009 | Texas Instruments TI-30XA Calculator
Intermittent: car will not accelerate when cold. No diagnostic code
1. Inspect the 2 wire harness for the 7x Crankshaft Position (CKP) sensor in the rear of the block.
2. Wiggle tug test the harness and inspect the harness for being melted from the exhaust manifold. Tests/Procedures: 1. Verify fuel pressure climbs to over 40 PSI during cranking and reads about 35-40 PSI at idle. Potential Causes: Insufficient Fuel Pressure
Tech Tips: The Powertrain Control Module (PCM) will idle the engine at a normal speed when the Throttle Position Sensor (TPS) voltage returns to the learned base idle value. This is also called 0% throttle angle. If this throttle angle is 1% or more at idle, the PCM will assume the engine is actually off idle and raise the engine speed to prevent a deceleration stall. Note that another sensor using the same 5 volt reference as the TPS can momentarily glitch the reference voltage low. This will cause the TPS to send a lower base idle voltage to the PCM, which the PCM quickly records as the new learned base idle voltage. When the reference voltage returns to 5 volts, the base TPS signal voltage increases to it's previous value. The PCM now interprets this as being off idle. This will cause the throttle angle to increase to 1% (or more) and idle the engine at a fast speed
Oct 13, 2009 | 1998 Pontiac Grand Am
Hobart lx 18 warewasher what hatco booster heater product compatable with it
The answer to this question will be based on the incoming water temperature that is supplied to the booster heater. The standard sizing for a booster heater is based off of a 40 degree F rise (140 degree F incoming water temperature) or a 70 degree F rise (110 degree F incoming water temperature). For a 40 degree F rise, a Hatco model C-5, S-5, or PMG-60 will supply the needed amount of rinse water for the LX-18 Hobart dishwasher. A 70 degree F rise would require a Hatco model C-9, S-9, or PMG-60 to supply the same Hobart model number.
Oct 11, 2008 | Dishwashers
Open the modem door
The modem door does not open beyond a 45 degree angle to the base unit. Damage to the modem door will occur if forced open beyond a 45 degree angle.Open the manual for additional details.
Sep 14, 2005 | NEC MobilePro 900 Handheld
Computers & Internet Logo
357 people viewed this question
Alun Cox
David Payne
David Payne
