Question about Garland X60-6G24RR Gas Range
Griddle temp too hot on lowest setting. - Garland X60-6G24RR Gas Range
2 Suggested Answers
  • 183 Answers
SOURCE: Griddle top replacement
well this is different, but sounds like fun. I would just Repair the gas griddle you have. from the sound of it you need to replace the 3 or 4 tstats that control the griddle. If you are in a Metro area you can find a dealer for Robert Shaw and get the parts you need. but you may also start at http://www.garland-group.com/. everything there will be newer but you will be able ask about where the data plate is and then get parts lists. call a small comercial kitchen repair company and ask for help there too.
Posted on Jan 30, 2012
Why is water hot all time even if you set thermostate low
the lowest setting for a hot water system is around 65 C
that temp is just bearable to the hand
75C is starting to burn
Mar 28, 2017 | Cars & Trucks
Jan 29, 2012 | Garland Ovens
How do I season the griddle that came with my new gas stove?
This is taken verbatim from page 11 of my Frigidaire Gallery range:
"Seasoning, using and caring for the griddle Before first use: -Wash griddle in hot soapy water. Rinse and dry completely. -Apply a thin coat of vegetable oil to the entire surface (front and back of griddle). -Preheat your oven to 350*F. Place the griddle on the upper rack in your oven. -Bake griddle for 1 hour at 350*F, then turn oven OFF and let cool before removing. -The surface may have a tacky feel to it from the seasoning process. If desired, wash the griddle in hot soapy water, rinse well, and dry completely.
Using the griddle: Remove the center burner grate and carefully replace with the griddle (some models). Preheat the griddle for 5 minutes on medium to medium low setting. Slow preheat ensures even heat distribution during the cooking process. DO NOT preheat the griddle on HI setting. Preheating on HI may warp the griddle and prevent even heat distribution.
After each use: -To prevent rusting, store in a dry place and keep uncovered. -After each use, clean with a stiff brush and hot water only. -Do not clean griddle in the dishwasher. -Dry immediately and apply a light coating of vegetable oil to griddle before storing.
Sep 20, 2010 | Frigidaire 30" Self-Cleaning Slide-In Gas...
Power vent 50 gal tank flashing code 2-3
1. Turn off power vent blower and set water heater temp to vacation (lowest temp)
2. Turn on power vent blower
3. Turn the water heater temp from vacation (lowest temp) to hot (highest temp) four times.
4. Set the water heater temp to normal
Aug 21, 2009 | Rheem Water Heaters
Can you cook hamburgers and pork chops on the griddle hot plate?..if so, should there be a drip pan beneath the holes in the griddle to catch the grease?
There should be a drip pan already but remove the griddle and line it with aluminum foil that way you can just roll up the foil and throw away and you don't have to clean the drip pan. If you cook pork you need to cover with a lid and you want to make sure you get the meat hot enough to be safe, get a thermometer from Wal Mart and it will have a probe and the temp the meat has to be in order to be safe. Chicken is 160 beef is 140 and I don't eat pork and don’t know the exact temp for it but the problem will have it on it. If this helped please rate me.
Aug 07, 2009 | Jenn-Air JGR8850 Gas Kitchen Range
Blower not turning on
push the priority button unplug the unit for 1 min,, plug it back in set the temp to the lowest setting it has to start on the lowest setting turn on a faucet on the hot side, turn it on set the temp after it comes on and it should stay on,, if not check the vent make sure there is nothing around it on the outside it can not have anything blocking it,, all the flue connections have to be in the same way they lock into position and it can determin thru the computer if they are not together it draws in the exhaust fumes and shuts it self down
Apr 10, 2009 | Rheem Tankless Hot Water Heater...
Maytag Front Load Intellisense 6.5kg
washer may not be detecting water temp but water flow ..if you never use hot water may try hooking cold water to a Y-connector and then hooking to both hot and cold inlet valves ..however it is also possible washer is detecting inlet temps in which case you're out of luck ..i suspect the latter
Sep 01, 2008 | Washing Machines
Garland X60-6G24RR Gas Range Logo
26 people viewed this question
Top Garland Kitchen Ranges Experts
Marvin
Marvin
John Tripp
John Tripp
Dennis Boxerman
Are you a Garland Kitchen Range Expert? Answer questions, earn points and help others
