Question about Kohler Model 10433: Fort® Single-control Pullout Kitchen Sink Faucet Wi...
I installed the faucet a couple of days ago and everything worked great. last night suddenly the hot water stopped working. The hot water supply is working. What could have happened.
  • 5,603 Answers
The usual cause is contamination of the valve. When connections are made, often it loosens debris. Also excess things like teflon tape can block the valve.
As a POSSIBLE quick fix, close the hot water stop. Remove the hot water hose from it and put it in a bucket to catch the water,
Now block the output spout of the faucet and open the faucet in center position. This SHOULD drive some cold water backwards through the hot hose you have taken off. This should blow out any debris.
Note: Occasionally when new faucets are installed, the initial surge can bring up LARGE debris into the stop valve on the wall where it actually blocks the water at the stop valve on the wall. These often require turning off the building water and cleaning the stop valve.
Posted on Aug 04, 2010
No hot water from kitchen tap
The hot side of the faucet is most likely plugged with something that came up thru the water system. The average thankless waterheater requires at least 1/2 to 3/4 gpm flow rate for the unit to sense flow and turn on. If there is not enough flow it will not fire and heat the water. Not sure about this particular unit but a few require at least one full gallon per minute flow. So chances are that if you fix the faucet, you fix the hot water issue at the same time
Jan 09, 2014 | Rinnai Water Heaters
Hot water will not work in kitchen
leave the cabinet doors open at night . place an electric heater in front of them an leave water turned on a little
Jan 06, 2014 | American Standard Plumbing
We purchased an American Standard kitchen faucet model 4040 an couple of years ago. Worked great after installation, but not long after water just started coming out, both hot and cold, at a trickle. We...
I had the same problem. You need a "diverter" (044264-0070A). It's available directly from American Standard at no charge. Lifetime guarantee! Phone: 1-800-442-1902.
Aug 15, 2010 | American Standard Kitchen Faucet 6310 020...
No cold water
Anti Scald Valves have an adjustment under the handle (remove handle) to allow so much hot water in no matter how far handle is turned. Its possible that the adjustment is set to allow only hot water in, this of course defeats the purpose of anti-scalding. Check to see if you can adjust this back. Good Luck have a Great Day. Please give a 4 THUMBS UP if this free answer was of any help.
Apr 01, 2010 | Ldr Industries 520 1300C ADJUSTABLE SHOWER...
My heater stops working in the middle of the night. I have to get up to re set it but it turns off by the time i get back to bed. By 10 AM it starts working again on its own. its done this for 2 years and...
the Model number you gave is for a Shower Head what do you mean it doesnt heat... it only conrtols the water temp by BALANCING the hot and cold water inlets does NOT heat anything if your water is cold then check another PLAIN faucet to see if your water is the same temp( cold) if it is the hot water from water HEATER is cold nothing to do with faucets
Nov 22, 2009 | Kohler K-T462-X4V-CP Memoirs Rite-Temp...
Hot water stopped working Cold is OK
may be the new facuet see if the hose is clogged detach it from the sink turn on the water and see if it comes out into a bucket if it does than its your new facuet
May 12, 2009 | Plumbing
The hot water stops coming out of faucet
if this is the faucet in picture, turn off water, pull out cartridge and inspect for any debris in cartridge or valve body, if not, turn on hot water to see if water is getting through valve body. May have kinked line or debris from or in angle stop line.
Apr 12, 2009 | American Standard Kitchen Faucet 6310 020...
Kitchen Faucet 6310 020 White - HOT WATER SIDE NOT WORKING
The faucet cartridge is more then likely blocked and the faucet will have to be disassembled in order to unblock it.
While it is disassembled you should slowly turn on the water lines to make sure the water ways in the faucet are clear. And thoroughly check the cartridge for damage. Replace if necessary.
Replacement Cartridges can be purchased at most plumbing supply houses or Big Box Stores such as Lowes or the like.
Dec 19, 2008 | American Standard Kitchen Faucet 6310 020...
Two handled faucet not working
could be 1 or 2 things either an air lock or a valve is blocked
Nov 18, 2008 | Plumbing
Low pressure and flow on hot water side of single handle faucet
It could be one of two problems, one simple, one serious.
  • Easy fix
  1. Turn off hot water angle stop under sink to faucet.
  2. Remove supply line from hot angle stop.
  3. Place end of supply line in a small bucket to catch some water.
  4. Turn on cold water for a couple of seconds and backflush debris from faucet.
  5. Reconnect supply line.
  6. Turn on angle stop and test
  • Complex fix
If you have steel pipes you may be experiencing reduced flow due to corrosion in your pipes. Reduced hot water pressure in the kitchen faucet is usually the first sign since this is the faucet that is most used in the home.
Repiping is a job for a professional. Another symptom you may need a repipe is orange colored or rusty water.
Nov 14, 2008 | Delta Faucet Plumbing
Kohler Model 10433: Fort® Single-control Pullout Kitchen Sink Faucet Wi... Logo
Top Kohler Plumbing Experts
Mike
Paul Carew
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
