I am gtting two line of red and yellow colour on my monitor and red colour is not showing on the monitor anywhere.
    Sergeant:
  • 235 Answers
Try the monitor on another computer and if it works then it's your video card. If it does the same thing then you know for sure it's your monitor. You could also try another monitor on your computer and if it does the same thing then it's your video card and if it works then it's your monitor. More than likely it is your monitor.
Posted on Aug 04, 2010
MFC-9840 printing Yellow/Red/Blue strips in background. Any ideas why?
This is caused mainly by leaving the Corona Wire sliders anywhere other than where the arrows on the slider meets the arrows on the Drum Units. This leaves solid lines of colour down the length of the page (one per colour with the slider in the wrong place) if it is leaving more than the single line on the page it is probably leaking cartridges.
These particular cartridges are known for their ability to leak badly (OEM and Remanufactured cartridges do it). The only option for a leaking cartridge is to replace it and clean out the machine with a lint free cloth preferably a 'Toner Grabber' cloth. If you nee one of the toner grabber cloths then talk to your local cartridge refilling place for one. If they refil toner cartridges there then they probably have them or can suggest a different option.
Aug 12, 2014 | Brother MFC-9840CDW Laser Printer
How can i play ps2 on lcd without having a black and white screen ? how can i connect the cables ?.....when i look at the back of my lcd i find three ports (red white yellow) when i use them the screen is...
1) The set of input (Yellow= Composite video, Red= Right channel audio, White= Left channel audio). This set of input is for composite video.
2) The set of input (Red= Red video signal, Green= Green video signal + sync, Blue= Blue signal, Red= Right channel audio, White = Left channel audio (the Red and White will be grouped close together). This set of input is used for Component video for HD signal.
You should try using composite video source (Yellow RCA jack) from DVD player and feed to the monitor and see if it works OK with all color showing that way we acn find out if it is the video source problem or the monitor video signal processing problem. Try the PS2 on the TV if it works OK also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Aug 20, 2011 | Samsung SyncMaster 940MG 19" LCD Monitor
I have A Compaq monitor,edited
omg an antique monitor
a relic CRT monitor?????really?
is it really MV320????or a typo.
MV500s are CRT (heavy cathode RAY TUBES)
you model is rare now, no photos of it by you.so...
if not a CRT pig.
then it must be a flat screen monitor
the first ones, up to year 2010 used crapppy
CCFL back lamp tubes that are bad now. all are.
(unless never used)
call CCFL fail these ways.
dim.
white now yellow
dead.
blinks, or is intermittent,or strobes.l
the backlamps CCLF tubes are dead. all do that, or just die .
crt monitors
are junk and a fire hazard, trash it.
CRT fails more ways
sure dim,sure dead.
but it has 3 guns , RGB , red green blue.
the red gun loves to go weak first , red phosphors
are weak (a physics deal)
one trick (long long ago is to up the red gun levels, to compensate.
or lower Green/blue guns.
gun means "electron gun" deep inside the CRT neck
The CRT has even more bad effects, failed.
a huge endless list , if you want.we have it.
with photos
Jan 23, 2018 | Compaq MV 520 Monitor
My monitor is not displaying colours.... its only showing bit of blue and yellow colour.... please give me solution.....
CRT monitors can fade over time. try resetting factory settings and degaussing, if you have that option. If not, you need a new monitor. Buy an lcd.
Feb 18, 2011 | HP mx705 17" CRT Monitor
Monitor is changing color when power on:- red, green, yellow, violet, white, blue etc......repeating continuously ...... more tha ten times switch off monitor but the problem remain the same... VGA...
1706,
the monitor is bad if OSD , menu shows bad colors
try the reset in the OSD menus,,
google, HP L1706 manual, read it.?
some newer hp monitors even have test pattern in the OSD pages. (on screen display) try that.
Oct 04, 2017 | HP L1706 17" LCD Monitor
Red colour problem
Try it on other PC, also try new VGA cable, then post back. This model may be still under warranty.
Apr 08, 2010 | Samsung SyncMaster 2233BW 22" LCD Monitor
POWER SUPPLY 24 pin slim line colour code ,hp compaq dc 7100
normal white wire....?
white with red....?
brown....?
Mar 31, 2009 | HP Compaq dc7100 PC Desktop
My monitor was not red colour
Change the vga cord of your monitor. red,geen and blue signal from cpu to color monitor pass tru vga cord. if one line is cut for example red line is cut 100% there is no red color in your monitor.
Jan 06, 2009 | Computers & Internet
Colours on TV Panasonic TX-32PL10 5/6 years old
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
Feb 11, 2008 | Televison & Video
The monitor hjas lost its original colour,It potrays images that are a bit red and yellow.Its a Compaq V570
It's probably not a matter for adjustment, it's probably in need of electrical troubleshooting to find and replace defective components. It may be the CRT itself. One way they often fail is to show or lose one particular color more than another. These days a common 15" CRT monitor is probably not economical to repair by a brick-and-mortar service shop.
Jan 06, 2007 | Compaq V 570 15 in.CRT Conventional...
Computers & Internet Logo
18 people viewed this question
Alun Cox
David Payne
David Payne
