Question about Power Acoustik TS1440-2 Car Audio Amplifier
Odd behavior of power and protect
Ok guys ive got a quite a bit of experiance with car audio,but this ones got me stumped
ts-1440 power acustik will work when connected to a 12 power supply (ie: 120v ac to 12v dc converter) but when connected in my 99 ford f150 the power light will not come on unless the rca line is connected but comes on in protect mode when they are. any idea's?
  • shadowc2d May 04, 2008
    I've come to the conclusion that my ground wire (which was installed w/ a previouse amp) had lost good contact with the chassis, reseated the ground, and cleaned the contacts. amp works fine now. thanks for the input pbabin
  • 631 Answers
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connectes to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Do this with no RCA or speaker wires connected. Let me know what you find.
Posted on Apr 26, 2008
No power to one outlet in bedroom.breakers are ok.
I would think that if the other outlets that are on the same circuit are still working, then I think I would try replacing the outlet in question.
Nov 15, 2014 | Leviton 15A Decora Electrical Outlet Light...
Tip
How to convert TS video for Mac?
TS format is one of the HDTV (high-definition) video format, the video quality is joyful, but TS video is not accepted widely by portable devices (iPod, iPhone, PSP, Zune...) or multimedia players such as QuickTime.
So, If you want to put a TS Video to your iPod, TS Video to iPhone,TS Video to PSP... and so on players, or you get some problems in putting TS video files (HD video), taken by our digital cameras or downloaded from Blue-Ray DVD, to your mobile players or playing them with Quicktime on your Mac,you need this wondershare Mac Video Converter.
Here is a step by step guide on how to converter TS video for Mac:
Step 1: Add TS Video Files to TS Converter for Mac on MAC OS X
Click the Add button, and the program will let you browse your computer hard drive. Then select the TS videos you want to convert and click 'OK'.
ts-video-converter-1.jpg Step 2: Output Settings for TS video on Mac
Select an output format from the Format Drop-down List. Just select an format according to the player which you want to put your video/audio on.
ts-video-converter-2.jpg Step 3: Conversion for ts video on Mac
Click the 'Start' button to start the conversion.
Addtional Tips:
1: If you want to convert all the added TS video files into one format with the same encoding parameters, you can just click the "Apply to All" button.
2: You can check the "Merger into one file" option to convert all the added TS video files into a single file.
3: Click the Settings button to set encoding settings including video resolution, frame rate, bit rate and video encoder, audio encoding settings including sample rate, channel, bit rate and audio encoder.
4: Click the Browse button to specify an output folder to save the converted files.
5: If you want to edit your TS video, you can switch to the Mac Video Converter official user guide for more details.
more information:dvd ripper for mac,mac ipod converter
on Jul 08, 2010 | Computers & Internet
My power acustik 1200 watt amp is on protection mode how do i fix it
Check that no speaker wires or some other wire come off, If they all look okay, There is a internal problem with the amp, It will have to be taken in for repair,
Oct 30, 2012 | Power Acoustik Car Audio & Video
Power acoustik bafm2000/1d no power coming from channel
HelloAny one channel circuit of the amplifier has any sort of trouble, the amp will go to protect mode. It may be a direct short in it he output circuit. This is the common fault for these type of amps. A through check should be done to find out the reason. You must have sound knoledge in electronics, and experience to do this work by yourself. In most cases, unlike TVs, amps circuits are quite complicated and user cannot do it by themselves. OK.
Dec 19, 2011 | Power Acoustik BAMF2000/1D Car Amp
50 volt regulator
Most techs offer a warranty. Contact him and ask him if he will look at it again and ask him if he's going to charge you to troubleshoot it. If its the same problem and it's not a problem caused by incorrect installation, shorted speakers, shorted speaker wires or an incorrect ohm load, he'll probably warranty it.
The main thing is to be polite. If you are rude or accuse him of ripping you off, you can be pretty sure that you'll have to pay to have it repaired again.
Let me know if you have any other questions.
Sep 28, 2008 | Digital Audio 2000 WATTS SINGLE CHANNEL...
Speakers inop. on kenwood reciever
The speaker protection circuit sounds to be engaged. This protects you speakers form damage if a fault condition occurs inside the amp. Generally speaking, unless you have good experience at fault finding electronics, then this may be a job for a repair guy. If you want to know more about diagnosing the problem, get back to me here. Good luck :)
regards
Graeme
Feb 15, 2008 | Audio Players & Recorders
Lanzar Vibe 1200D protection light
You will need to show it to a service technician as it seems the output section has blown so it remains in protect mode. One reason (could be) that the input to the amp was high and may have been clipping for some time before the amp decided it could take it no more
Jan 14, 2008 | Lanzar Vibe 1200D Car Audio Amplifier
Tube turns on nothing else does
If the Tv turns on (power supply is ok), screen lights up (inverters are ok) but don't get a blue screen, menu options, source options, or audio, it's most likely the main board (aka Motherboard) is faulty. If a DVD player is hooked upto the TV, check whether you can get audio from that (change the source using remote), in such a case it could be a problem with LCD Interface board. My $3 is on faulty Main board.
Jul 27, 2007 | Sanyo Vizon LCD-15A2 Television
Protection light on
i had one of these amps, if you don't have a good ground, the protection light will come on.
May 09, 2007 | Power Acoustik TS1440-2 Car Audio...
My amp quit working
ok I thought I anwered this one but first thing to try is disconnect all your speakers and see if the light goes out if it doesnt then your gonna need a schematic and a working know how on solid state amplifiers. first check al the outputs for the speakers for dc If theres dc on an output then that output device is shorted or leaky. Ive have open drivers as well as current control transistors leaky or shorted to that made the protection come on.. Good Luck
Apr 07, 2006 | AudioBahn A6004T Car Audio Amplifier
Power Acoustik TS1440-2 Car Audio Amplifier Logo
129 people viewed this question
Top Power Acoustik Car Audio & Video Experts
Tygh Duval
Tygh Duval
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
