Question about Toshiba Televison & Video
Can the Toshiba SD-38VKR be tuned into a TV channel as I am unable to do so is there a problem with the unit
5 Suggested Answers
SOURCE: Toshiba D-VR650KU can't "see" digital channels
On the Notification screen with Cable highlighted I found that left clicking on Cable gave a drop down menu with TV on it for selection. The manual says that while Cable is highlighted, use the up or down arrows to get TV to be an option and then select it and Yes and enter. Hope this helps. I have other problems with my monitor on Line Out, the screen oftens turns blue indicating low or no video using Line 1 or 2 inputs.
Posted on Mar 09, 2008
ginko
  • 19396 Answers
SOURCE: Toshiba rd-xv47kb auto tune
Check that you have the arial plugged in correct input otherwise it will not tune up.
Posted on May 11, 2008
jubag14
  • 89 Answers
SOURCE: Tune in remote to Toshiba Tv
you cant tune a difernt remote to a differnt tv but what you can do is take it back to the place that you brought it from and see if they can give you a refund and i would buy another tv. sorry.
please rate my help to you.
thank you.
Posted on Apr 25, 2009
  • 273 Answers
SOURCE: unable to tune in my LG Electronics TV (model 37LC2d-ec) to receive digital channels. Bought in UK, now living in Australia.
use a scart lead connected between your digital receiver to your tv
Posted on Jun 03, 2009
Unable to tune into any channels
It's much more likely to be the antenna. How old is the TV? Check whether the antenna connection is loose. Check whether the antenna cabling is all connected. Did anything change just before the TV stopped working, like someone doing work outside? If you're receiving cable TV check the connections to and from the cable box.
Nov 16, 2013 | GPS
Toshiba TV, I can't tune channels, when I go to
Check whether the input is selected to AV. In AV mode, no tuning is possible. It it is in this mode now, switch it to TV mode.
Jan 13, 2013 | Televison & Video
Just bought a new Toshiba 40KV700B television. When first switched on it gave the option to switch antenna on and to search channels. Not realising the arial was not in, I pressed ok to that option of...
This is a very complex device with many options.
It should have a user manual. There may be terms in the manual that you are not familiar with, but will need to learn to use the device successfully. there may be a service nearby that will assist you in setting up the television based on the source of your television signals. Hope this helps a little.
Oct 04, 2017 | Toshiba Televison & Video
Cannot Tune TV through VCR
I need model number and brand of your VCR and TV to suggest solution.
Thanks.
Jun 12, 2009 | Panasonic Televison & Video
Unable to tune the channels into the tv.
send me a picture of the front panel I will tell you how.
Apr 28, 2009 | Televison & Video
Feb 21, 2008 | Toshiba D-VR650
Tuning problem
Your TV is set to Antenna. You need to go into the menu and change it to Cable. Then do an autoprogram.
Jan 30, 2008 | Symphonic ST419E TV
Tuning programmes on Toshiba 30HF83 30" TV Problem
Hello Skinno, Frist of all make sure that you are set to Antenna input and then connect your antenna to the TV this will pull in the VHF ansd UHF channels. Then perform the auto channel select. If this does not work perform a manual channel selection this should clear up your situation.
Sep 03, 2007 | Toshiba 30HF83 30" TV
Televison & Video Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
