Question about Peerless Industries Peerless& Single Handle Tub & Shower Faucet
I have a Peerless 8700 series one handled shower and tub combo. The tub downspout leaks continously. What should I do to fix this problem?
4 Suggested Answers
  • 152 Answers
SOURCE: Leaking water from tub spout
First you should obtain a parts brake-down instruction sheet, contained within the owners manual or downloaded from the manufactures website. With that you will have a detailed description of the removal and re-installation of that units cartridge, which upon removal you may see a build up of debris at the inlet ports or a ruptured O-ring in need of replacement.
Before any dis-assembly, turn off the hot and cold supply to the unit.
Good luck
Aduz
Posted on Mar 27, 2009
  • 49 Answers
SOURCE: Installed a new 88976 handle but still have a leak
replacing just the handle cannot fix the leak and common sense should tell you that.... try turning off the water to the diverter (thru access panel on opposit wall or main water valve for the home) and then replacing the stem or cartridge inside the diverter -- this is what controls water temp, pressure, and is responsible for any leaks you may have...
Posted on Sep 03, 2009
  • 5 Answers
SOURCE: i just change the whole cartrige, and i'm still
You may also have to replace the "seat" google good luck. that will stop the leak .
Posted on Mar 05, 2010
My showerhead leaks when I fill up the bath tub, do you have any suggestions as what will correct this?
Hi nanbooboo...
Sorry
Your problem shower control valve is ok, but the shower pull that turns on the shower is non-repairable.
Replace your shower controller with a new one if you want to solve this leakage problem.
Please take time to rate me
Mar 18, 2011 | Peerless Industries Peerless& Single...
We want to remove the shower unit. its a single handle unit. how to remove from the front? there is no screw holding the handle.
Look on the bottom side of handle and see if there is a allen head set screw. Loosen screw and you should be able to remove the handle, Thank you.
Nov 22, 2010 | Peerless Industries Peerless& Single...
Shower drips - seems to be increasing
Need to replace your internal seals inside the shower valves.
Go to Home Depot, Lowes,etc. and make sure you take your model number and maker of your shower and they can get you the parts to repair the valves to stop your leak.
If you do not repair it soon, the water leaking by will cut your metal seat and it will never stop dripping, you will have to replace the valve and it is a MAJOR job.
This is a free answer, Please rate me
Oct 16, 2010 | Peerless Industries Peerless& Single...
I just installed a single handle tub & shower faucet, when I checked for water flow there was barely a dribble. I suspect there is blockage in the valve. I would like to take out the valve unit, to...
If you soldered the faucet without removing the cartrige you may have damaged it. they have to be removed before soldering. if not, too much solder while soldering may plug port.
Sep 10, 2010 | Peerless Industries Peerless& Single...
Just had a contractor give me an entire new bathroom. The Peerless Single Handle Tub And Shower Faucet will only go from 90 deg down on the cold side to straight up. it want go to the hot side. What is the...
if u have the paperwork for the unit--in it will explain how to adjust the anti scold settings single handle units are shipped in cold setting u have to adjust the hot -- remove handle and on shaft will see blue and red clips adjust the red till hot water is to ur liking replace handle
May 18, 2010 | Peerless Industries Peerless& Single...
Instruction manuals
http://www.peerless-faucet.com/customersupport/requestliterature.html
Click on the link above and you can request the literature you are requesting. Peerless is made by Delta.
Mar 18, 2009 | Peerless Industries Peerless& Single...
I have a peerless tub diverter and I need to replace it because it leaks. Where can I find a replacement unit?
the kit to rebuild the peerless diverter is very common. take the cartridge to any hardware store and ask the plumbing clerk to assist you in getting the correct kit. good luck
Jan 19, 2009 | Peerless Industries Peerless& Single...
Peerless Industries Peerless& Single Handle Tub & Shower Faucet  Logo
1,098 people viewed this question
Top Peerless Industries Home Experts
Joe Lamb
Joe Lamb
john h
Steve Wood Plumbing...
Level 1 Expert
Are you a Peerless Industries Home Expert? Answer questions, earn points and help others
