Question about Sharp 13VT-R100 13 in. TV/VCR Combo
What are the causes of the screen been dark but the power light is on
  • 32 Answers
Your tv can have one of two problems:
- your CHROMA-IC is bad and need to be change
- your flyback screen potentiometer is defective.
either way you need to replace them
succes and enjoy
Posted on Aug 23, 2010
Blinking power light
Computer went to sleep on you. Set movie watcher app to stay awake while playing video.
Mar 31, 2014 | Computers & Internet
Monitor comes on but the screen gets dark after a 3 sec
if the power indicator at the front panel stay lit but no screen display or black screen, it could be a sign of bad power inverter board or screen back light. now to ensure if it was the cause you can do a voltage checking, at this time you will need a digital tester. you need to know if their is a bl_on voltage at the power inverter board around 3-4.4v to turn on the inverter board that supply the back light.if the power inverter board has 12v dc and has bL_ON voltage then the cause will be a bad inverter board. you must check also for a dry joint connector going to back light.
Nov 15, 2012 | ViewSonic VG2030wm LCD Monitor
Tv wont turn on
does the light stay or blinking and how about the screen display totally black or a white screen. you can see in a dark room if their is a white screen. if totally black screen then with sound the cause is could be bad inverter board or screen back light. if a white screen it was the t-con board not working good.
Oct 04, 2012 | Insignia NS-L32Q-10A 32 in. HD-Ready LCD...
Our 42" lg tv is
no. there's some problem on its display circuits that it need to be corrected, picture becoming dark has some problem with the inverter power supply circuits that responsible for lighting the small lcd flourescent light. maybe some loose connection in the components cause that to happen
Feb 06, 2011 | LG 42LC2D 42 in. LCD HDTV
Dell ADAMO 13 w/Vista 64 Random power failure...goes dead in 1 second. Battery fully charged. Happened with external power and when on battery. I have latest BIOS v6.0. I ran pre-boot diagnostics...
If the power totally fails (i.e. power is cut off, LEDs turn off, fans stop, ... etc), then this more likely to be because of a short circuit developing in a failing semiconductor component, or a power supply problem.
However, if the laptop is still running & only the display on its LCD is cut off but the laptop itself stays powered on, then your laptop might be experiencing a failing screen inverter board, a failing screen backlight lamp, or a failing LCD screen cable.
TYPICAL INVERTER FAILURE SYMPTOMS
1. When you turn on the laptop, the screen lights up for a short period of time and then goes dark. You still can see an image but it is very dark, almost invisible and definitely not usable. When you restart the laptop, the screen lights up and then goes dark again. The laptop works fine with an external monitor.
2. Your laptop turns on but the screen remains dark all the time. You still can see a very dim image outline. The laptop works fine with an external monitor.
3. The laptop screen works fine for hours or even days, but sometimes it goes very dark as it mentioned above. When you restart the laptop, the screen works fine again.
Inverter failure symptoms are very similar to backlight lamp failure symptoms and in most cases you cannot tell which one is causing the problem until you replace either the inverter board or the backlight lamp. From my personal experience, inverter boards fail more often than backlight lamps. If you have to guess, replace the inverter first.
Feb 07, 2010 | Office Equipment & Supplies
Charger makes my screen dark
GO into the control panel and check your power settings. You might have it set to use less power when plugged in.
Oct 03, 2009 | Compaq Presario Notebook
LG L1717S has no light
Hi, this is a common problem. One thing you want to observe is that the screen works, what's going on is that the screen LCD illumination doesn't work while the screen display is active. LCD's have screen lamps behind the screen, they are often called CCFL, (Cold Cathode Flouroscent Lamps). The inverter board in the monitor supplies High Voltage power to the lampls, so the colored wires should lead you to the lamps. This is the problem causing the screen to dark. You can research the model lamp type for an accurate replacement. Usually there are 4 or 6 lamps in LCD Monitors.
Apr 23, 2009 | LG L1717S-BN 17" LCD Monitor
Dark Blotches
This is probably caused by dust, either on the mirror, lens, or possibly inside the light engine. There is a 5" dia hole on the side of the back of the tv where you can take out one screw and take the door off. this is just big enough for you to put your hand through to clean the mirror and lens. Hope this helps.
Mar 30, 2008 | JVC HD-61FN97 61" Television
Acer Aspire 3000 pc screen problem
Have u tried re-installing the video drivers?
Nov 27, 2007 | Acer Aspire 3000 Notebook
Display light is dark
I have seen this problem before this is caused by a failure of the backlight which provides illumination for the LCD screen. You may also want to check the inverter also since it fails often and interacts with the backlight.
Sep 04, 2007 | Shinco SDP-1750 Portable DVD Player
Sharp 13VT-R100 13 in. TV/VCR Combo Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
