Question about NAD Audio Players & Recorders
I have a NAD CD player C 521BEE which up until recently has worked perfectly. I now have the problem that it won't recognise/read the CDs, and therefore makes it unusable. On occasion it works fine, but 9 times out of 10 I have problems. I have tried a lens cleaner, but this doesn't improve matters as it appears not to get read either. What could the problem be? Is it the laser? Can this be fixed? Thank you.
  • NAD Master
  • 1,910 Answers
If your cd player gets older there can be a timing problem by several causes like a slipping belt, or a dirty mode select switch somewhere or a microswitch that is not functional by the slipping belt too long time to take the cd to inside and push up the platter and mechanic to give the focussing of the laser to read the table of contents on the cd , that the cause in 90% microswitch cleaning by contact spray under the tray and on the beginning point wheren the laser begins its start cycle to focussing and give a turning respond to the spindle motor thereis a little microswitch it pushed in or an other switchable point also under or near the cd tray another where the detection is the start that the cd tray is closed and the laser start to focussing on the cd surface and give the cd a turn for the toc and then when its timed correct it recognized and displayed the track position highest priority is that rubber belt that driven the tray and the 2 or 3 microswitches or contacts you should find what have functions in the intake traject. in a short time all together. little suggestion whats meaning Denon DCD815 CD Player disk tray wont open or copy this link
https://www.youtube.com/watch?v=H9AbnvF1www
Posted on Jul 21, 2017
stoodleysnow
SOURCE: Every CD is skipping
If the cleaning cd does not work, try unplugging the player, taking the back cover off and manually cleaning the lens with cotton wool or cotton buds. If there is a stubborn smear on the lens, try methylated spirits on the cotton wool. Please note the following: Don't lose any screws You may need to take additional pieces of metal or plastic off to get at the lens; do not lose these or the screws that hold them and make sure they go back in the right order DO NOT TOUCH THE LENS WITH YOUR HANDS OR ANYTHING NOT CONSISTING OF COTTON WOOL OR METHYLATED SPIRITS! The lens will be quite fragile-do not apply excessive pressure Ensure everything goes back together the way it was, minus dust and dirt. hope this helps. stoodleysnow P.S. You can get methylated spirits at a local hardware or diy shop, or occasionally art shop.
Posted on Aug 30, 2006
SOURCE: Not Recognising a CD
I had the same problem with my C541 player, I solved it simply cleaning the lens area with cotton swabs. No other "no disc" fake messages so far... good luck! Luca - Rome (Italy)
Posted on Jan 28, 2007
  • 22 Answers
SOURCE: No playing CDs
go to website of bell computer 1. find the latest BIOS and download it to your computer 1. find the latest driver for your CD model and download it Good luck!
Posted on Feb 01, 2007
SOURCE: used lens laser lens cleaner & now player won't play.
Hi Mollins, did you ever resolved your DVD player issues. I have the same problem and I dont know what to do.
Posted on Mar 14, 2007
SOURCE: PD-H300 not recognising CD's
FOLLOWING ON FROM MY REPORTED PROBLEM I WAS DETERMINED TO FIX IT.
I REMOVED THE OUTER CASE ( AFTER UNPLUGGING THE UNIT ) AND WET CLEANED THE LENS WITH METHATED SPIRIT. THAT CURED THE DISC RECOGNITION PROBLEM BUT THE MOTOR WAS NOT STARTING EVERY TIME.
VERY CAREFULLY I MANAGED TO GET A LITTLE WD40 ON THE MOTOR SHAFT AND HEY PRESTO IT NOW WORKS OK EVERY TIME.
HOPE THIS HELPS SOMEONE.
Posted on Jan 10, 2008
Nad 502 CD will not recognise and play CD every time
HI.This will occur when the optical assembly becomes unstable. this ((Whole One Piece)), assembly incorporates the spin/load motor, optics housing /arm, tracking device and tracking rail. This is connected to the loading dock assembly. This 'NO Disc' or CD NOT PLAYABLE, code is the result of a failed or burned out lens, or misaligned loading mechanism. It is possible that you have a dirty lens cap. you can try using a cleaning disk in this case to confirm actual lens failure. if the cleaning doesn't restore normal reading capabilities, this will confirm my diagnosis.
You will need to have the optical assembly replaced in this case. once replaced, your unit will be able to read and track once more
Sep 14, 2009 | Teac CD-P1250 CD Player
NAD T531 - reading problems
Try taking the outer casing off and manually cleaning the laser lens with alcohol , this should work for you.
Aug 13, 2009 | NAD T531
NAD CD 5425 - No Spin - Sometimes
I've dealt with this type issue quite a bit.
Believe it or not the drawer belt needs to be changed.
If the drawer isnt drawn all the way into the unit...the disc motor wont spin and ....you get rejected
Dec 23, 2008 | NAD C521 CD Player
NAD 5000 CD player
I FIX MY NAD 5000 CLEANING THE LASER LENS USING COMPRESS AIR
Nov 06, 2007 | Audio Players & Recorders
Won´t read any Disc
I have the same problem since the early beginning after purchase. I'm very upset with NAD for the zero-value technical service in Italy. After 2 months they gave me back my C541 with new defects (the tray now doesn't work properly). They have tried - they said - different optics without fixing the problem. Does anybody know if a compatible optic / tray exists?
Thank you
Marcello
mcl.vlb@tiscali.it
Sep 25, 2007 | NAD C541 CD Player
Laser unit NAD 5100 Monitor Series
Hey, I think you can bye new laser here http://www.pltv.org.uk/laser.htm I have a nad 5300 monitor series, same laser as 5100, you can buy the hole cd player from http://www.miguelovitch.dk Laser work, but problems with cd transport. When i 'help' the cd transport, cd play as expected. And i agree, it is a nice cd player, also i have heard lot of nad cds on quad 405, sounds realy good. Try to visit my site, i also have a lot of free schematic for nad, denon, quad and mora. Also repair notes for amplifiers, tech videos, diy schematics and more.. Also at this moment i am working on a new 'nad cd service movie) including cleaning, maintenance, repair and more on nad 522, 501, 502 c521 and more see you best regards michael miguelovitch http://www.miguelovitch.dk
Aug 14, 2007 | NAD C521 CD Player
NAD C521 discs not spinning
The CD player has a sensor that is supposed to detect when a disc is inserted and spin it up etc. yours might be the problem, either it has some loose connections (that you haven't noticed) or it simply misbehaves. Another thing could be the motor itself that somehow 'misses' the spin up signal and needs a 'manual' boost. The best solution in your case is probably to bring it to some lab.
Sep 14, 2005 | NAD C521 CD Player
67 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
