Question about HP LaserJet P2015dn Printer
Hp lj p2015d printer
One printer in hp lj p2015d ,prinetr control panel six leds is there
the problem is first two leds are blinking
  • 2 more comments
  • tamersherif May 18, 2008
    turn off and turn on , sometime i get the Jam Led and the Toner led both together in a solid state
  • Anonymous Jul 02, 2008
    My problem is three error light on continuously (paper jam, toner, paper load). I need the solution of this problem.
  • Anonymous Dec 05, 2008
    giving white paper
  • Anonymous Mar 25, 2014
    hp lj 2055 continuously intilizing and half circle,exelation mark led both are continuously blinking.
    Problem Solver:
  • 11 Answers
GO TO THIS SITE:
http://www.fixyourownprinter.com/forums/laser/48992#22
THERE IS A KNOWN PROBLEM FROM HP IT NEEDS TO GO BACK UNDER WARRANTY.
THE EPROM IS BAD !
Posted on Nov 12, 2008
  • 47 Answers
Yes , there might be a problem wit the formatter. Try this: turn powerswitch to off, press and hold "go button" while you turn powerswitch to on, keep holding "gobutton" untill all leds are on, could take up to 50- 60 sec. Release the "gobutton" and printer might reboot. If it does go to ready, try upgrade firmware
Posted on Nov 04, 2008
This could be your formatter board problem.. might need replacement
Posted on Nov 03, 2008
I have installed driver for win 7 64 bit but it could not print double-sided
check duplex unit fixed properly,Do cold restart( hold the go button switch on the printer after all LED are once blink release the button ensure that don"t hold the button more than 15 sec)..Check the drivers..
Sep 09, 2011 | HP LaserJet P2015d Printer
Why continous below led hp lj p2015d
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken . Sometimes it is possible that the head is not reacting to the need of the PC command
Jul 01, 2011 | Office Equipment & Supplies
I want the driver of HP LaserJet P2015d Printer please provide the same. thanks
You can download the HP printer drivers from their supportWEB site. Please click on this link and select your model printer to download:-http://welcome.hp.com/country/us/en/support.html
Feb 10, 2011 | HP LaserJet P2015d Printer
Hp lj 2015dn problem for top 2 LED standard ON in my printer
check your printer motherboard it could be the communication cable from the power board is bad or the mother board that is why it can not scan. that is the problem
May 23, 2009 | HP LaserJet P2015dn Printer
Lj p2015d paper jam light on, no jam
You probably have a jam in the fuser. Very hard to remove. Reply if you want to attempt dissasembly
Feb 27, 2009 | HP LaserJet P2015d Printer
The figure 8 light with the check, first symbol on my Hp Laser Printer P2015d is blinking. The printer will not print
the figure 8 light means paper jam.
check all of the paper path, from the paper try to the output, and fromt the manual feed tray to the output.
Dec 08, 2008 | HP LaserJet P2015dn Printer
HP Laserjet 1320n Error Lights not in Manual
hi friends......
shivachadra is here.....just i faced this problem "Attention, Ready, and GO LEDs are on solid"
and i got solution in troubleshooting....just vi refixe the connetion of laser scanner........its the error of comunication between laser scanner and formatter....
May 27, 2008 | HP LaserJet 1320 Printer
HP laserjet P2015D , JAM LED in a solid state ??
Dear gentlemen,
Hope this helps you sort out the problem. Please check paper jammed pieces of paper remains from paper in to out paper path. Check if the paper is properly picked-up, else check rubber roller pick-up and the solinoid motors that control to fed on and off the tray to engage pick-up. Check paper path sensors if possible. If you can determine when is the paper Jam happens please advice. Other means you can also refer your manual and machine diagnostic menu which part of the operation the paper will jam.
Best regards,
Rosener Guyano
Jan 10, 2008 | HP LaserJet P2015dn Printer
Hp 9500hdn has error 8388D4 EIO devise 3 disk not funtional
Try the following steps to reinitialize the HDD:
1 Turn the printer off.
2 Turn the printer on.
3 Press and hold PAUSE/RESUME (LJ 9500) or START (LJ 9500mfp) on the control panel during the
memory count.
4 Hold PAUSE/RESUME (LJ 9500) or START (LJ 9500mfp) down until all three error lights illuminate
steadily.
5 Press (the 5 button on the MFP) until INITIALIZE DISKS appears on the display panel.
6 Press (the 6 button on the MFP).
7 The printer begins initializing the disk (this might take a moment). The control panel displays the
HP event logo and eventually displays READY.
Oct 02, 2007 | HP Color LaserJet 9500HDN Printer
HP LaserJet P2015dn Printer Logo
466 people viewed this question
Seeker5211
Seeker5211
