Couldn't find any information on this exact unit, but this excerpt from repairclinic.com might be what your problem is:
There's water dripping inside the refrigerator
Self-defrosting refrigerators dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates. (See a more detailed explanation of this in the How Things Work section of our website).
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
Here's the website- it has a lot of good information on refridgerator repair.
Good luck, and hope this helps.
Thanks. It sounds like the probable solution. Where is the tube located? I did not see the website you refer to in your answer. Can you send it again?
Thanks,
Jay
Sorry, forgot the link, here it is:
http://www.repairclinic.com/Refrigerator...
Not sure where the hose is located on your model, but perhaps a local repair shop could give you an idea where to look for it. Good luck, and thanks for using FixYa.
tbreeze47,
Thanks so much for your help. I think we solved the problem. The hose was on the back and is now working. The good news with all of this is that we finally cleaned behind and under the refrigerator after many years of neglect. Thanks again.
Jay
Yes it was.
