Question about Philips 42FD9932 42 in. Plasma Television
Philips ftr9955 television receiver fault - Philips 42FD9932 42 in. Plasma Television
I have a 3in. vertical bar down middle of screen on Philips 42of television
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Line faults to all LCD screen; irrespective of its Brand and size, will be the same.
Jul 25, 2015 | Philips Televison & Video
Philips 37PF5521D green light flashes 1 long then 9 short
The fault code is '19'. Counting the flashes to philips TVs are given in detail by the link given below. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/ You can get details about the fault codes, blinking codes etc:
Nov 14, 2013 | Philips 37PF5521D 37 in. HD-Ready LCD...
Tv is flickering and screen goes all snow sometimes once we lost sound
Very difficult to predict, what might be the fault to your Philips TV. It will be best to contact the authorized service center for Philips. google.com/+GopakumarGopalan
Nov 01, 2013 | Philips 50PFP5332D 50 in. Plasma...
Fixing the Philips Turns/shuts off on its own problem
Hello
The power regulator board of your tV has the fault. It will be best to replace it as card basis. You can buy it from the Atuthorised Service Center for Philips at your town. OK.
Feb 03, 2012 | Philips 42PF9831 42 in. HDTV-Ready LCD...
Horizontal line on screen sometimes
Generally horizontal lines are caused by the panel failing, you can try a new tcon but I don't think it will help.
Mar 01, 2018 | Philips FTR9955-17 DTV Receiver
Philips model no 29pt8319/57r
Can you tell me some more then "power supply fault". I need some more information ...
Feb 23, 2010 | Philips Televison & Video
HOW TO HOOK MY SONY RECEIVER TO MY PHILIPS TV
Connect the Sony Receiver's HDMI output to HDMI in Philips TV.
You can connect a DVD player or STB to either HDMI In of Receiver or HDMI in of Philips TV.
Jan 02, 2010 | Philips 52 In. LCD HDTV
Red LED blinking after turn on the TV (Philips Plasma 42PF9631D
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Mar 28, 2009 | Philips 42PF9631D 42 in. Plasma Television
We have no picture, just rainbow pinkish effect, no sound either.
I have a Philips Matchine television which does a similar thing, the problem is in the receiver part of the set, where I have traced the Video signal with an Oscilloscope to a particular Chip (Integrated Circuit). By increasing the Contrast to maximum the picture can be brought back again, but still lacks contrast. The fault is varies as the chip warms up. Therefore you can locate the chip by cooling or heating it from a special non inflammable spray can.Have you tried the scart input which may work OK, then you can use the television as a monitor, as I do. Cost of repair is not worth it.
Nov 11, 2008 | Philips Magnavox 27MS343S 27" TV
Philips 42FD9932 42 in. Plasma Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
