Question about Akai DVDP5851 DVD Player
I cannot see the video when i plug the DVD Player to my TV set. The model is AKAI ADVC-7013
The dvd player shows that the disk is running and also the time is ticking in the display in the player. But i can hear no sound or See Video. Please help. I have tried to play many discs. It was ok until a week ago.
  • silentkiller Apr 26, 2008
    The make is AKAI ADVC-7013.
    Genius:
  • 1,554 Answers
Start with the sound , do you have some speakers or amp that can take rca connnectors if so plug in to audio out and if you hear sound then the video is presumed ok too , likely some setting or cable issue then.
if no sound the the proc amp is shot.
Posted on Apr 26, 2008
Video Does not work on New Magnavox TV
Hi, it sounds like your problem is that you've selected the wrong "video input" for your DVD player. Your new television most likely has at least 3-4 (sometimes 6-7) different inputs for video. With your DVD player connected and turned on, press the "Source" button on your TV to cycle through the different inputs. Be sure to wait 2-4 seconds between selections to give your TV enough time to switch inputs. If your DVD player has "color coded" output cables, it's most likely a "component" video connection. See if one of your video inputs on the TV is called "Component". Some other video types are Video, DTV, HDMI, SVideo, Component, Composite, RGB, PC Input, etc...
Jul 24, 2013 | Sylvania SDVD7014BJ 7 in. Portable DVD...
Can I use an Akai AD163x just as a DVD?
No! the DVD player is hard wired into your Tv combo and requires the DVD circuits to run the set making it a critical addition.
May 12, 2012 | Akai Televison & Video
My AKAI tv/dvd combo - DVD quit working.
Most times it's video read issue such as a dirty lens on the laser.If you smoke in the house or use a fireplace there is a lot of airborn stuff to leave a slight haze on the lens making reading the disk impossible.Try a standard cd or dvd lens cleaner.The on that looks like a cd and uses alcohol on one of the cleaning brushes on the disk you've got a 50 50 chance.
good luck
Rich
Jun 06, 2010 | Akai LCT2721AD 27 in. LCD Television
I need to know what channel to switch to in order to connect my dvd player. it`s an akai 25 inch tv, model cts 2550, serial # 39zta51280x. thanks for any help. louie
It is a general question just try my idea to connect to the DVD player channel.
In the remote you may find any of the below button, press it.
1. DTH 2. DVD 3. VIDEO
If not just call the customer care help line to assist through online..
(Before that remember one thing you have to connect the dvd player wire in the TV to activate the DVD channel)
Thank you.
May 08, 2010 | Akai CTS2550 25" TV
How to connect (yellow, red & white) to component video
Connect either DVD player or DTH with the TV. There is only one input on your TV.
May 27, 2017 | Akai DVD-3850S DVD Player
S-video setting on DVD not compatible with older TV
I recommend the obvious solution which is to plug it into an S-Video compatible TV, VCR or DVD player then change your settings. You could make it really for yourself if you want by looking for some software that you burn onto a CD which you make bootable and when you run it in the player it resets everything to factory default settings. But seriously make it easy on yourself and just plug it into an S-Video compatible device (TV/VCR/DVD, preferably a TV for ease, though it doesn't make any real difference). Best of luck to you anyway!
May 22, 2009 | Sungale DVD-2026 DVD Player
Akai tv/dvd combo = dvd player isnt working rite
My TV has good DVD player , but no video. I will sell you mine for parts or I will buy yours for parts.
Looks like no on will service these tv's.
jilted@earthlink.net
Feb 21, 2009 | Akai LCT3201TD 32 in. LCD Television
Dvd
Hi helen670,
I have two models to recomend, one is the Philips DVD R 357H/37 that has a hard disk for you to save TV shows and you can burn them later on CD's or DVD's, or you can burn them directly. It's around $290 and can also play any DVD or CD.
Another model is the Panasonic DMR-EZ27K that lack's of a hard disk, which makes it cheaper (around $200), but still can record CD's or DVD's directly from the TV.
Hope it helps.
Jul 12, 2008 | Philips Magnavox DVD/VCR Dual Player
Progressive scan
Approach 1: Try unplugging the DVD player from the wall for an hour, then plug it back in. It may or may not reset to the factory default settings, which might put it back to "interlaced" output.
Approach 2: When a DVD player is switched to progressive scan, it uses outputs different from the coax cable "TV out" and the COMPOSITE outputs (often yellow, white and red RCA jacks. If you have the proper cables, you can connect them to both the DVD player and the TV, then cycle through the AKAI TV's "source" settings to switch the TV to the new cable input location.
For example, if the DVD player has "component" outputs (marked Y, Pb, and Pr) hook up RCA plug cables between those jacks and the AKAI TV's Y, Pb, and Pr jacks. Connect the Y to Y, the Pb to Pb, and the Pr to Pr, of course. The LCT3285TA has two sets of these jacks. Either will do, but note if you use YPbPr1 or YPbPr2. Once this is done, push the source button on the side of the TV (or on the TV's original remote) until it shows YPbPr1 or (...2 if that's what you connected). If the DVD player is on, you should now see the DVD menu or the picture from the DVD. Now you can use the DVD remote to switch back from progressive to interlaced video. The picture may go blank at this step.
Now push the TV's source button again until you see "3" or whatever channel you had been using in the upper left of the TV screen. You should see the DVD output picture (menu) again. Back to normal.
If your DVD player doesn't have YPbPr connections, it may have a HDMI or DVI jack.
The AKAI TV also has a HDMI input, you *could* get and HDMI cable (or DVI to HDMI cable if the DVD player doesn't have HDMI), hook it up, then cycle through the TV's source inputs until you see the HDMI in the upper left... in the manner I've just described.
Final Note: The progressive scan output of your DVD will actually give you a much better picture on your AKAI TV than its interlaced output. To take advantage of that, you'll have to hook up YPbPr or HDMI cables between player and TV and switch sources when you want to watch DVDs instead of TV programs. You may need additional cables to send the stereo audio output from the player to the TV for the progressive source hookup.
Jan 05, 2008 | Akai LCT3285TA 32 in. LCD Television
Akai DVDP5851 DVD Player Logo
100 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
