Question about Sabrent Mini Stick USB 2.0 TV Tuner / Video Capture Box with Remote Control (TV-USBST)
Sabrent usb digital tv atsc/qua/analog stick will not operate, the divice is not ready, please check whether your divice is connected correctly. it is, check device manager and Microtune ATSC and NTSC capture device and usb audio interface states (Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)
3 Suggested Answers
pgh_pa_guy
  • 2992 Answers
SOURCE: Is My TV ATSC or NTSC?
Yes, you will need a converter box if you are currently getting TV off-the-air with a rooftop or indoor antenna. This TV does not have a digital tuner. You don't need a box if this set is being used on a cable or satellite system (unless your service provider tells you otherwise).
Posted on Dec 11, 2008
pumpkinman
  • 1165 Answers
SOURCE: I need a driver for my Sabrent USB 2.0Video capture creator with audio controller
The driver is on the cd. it explains with the CD cover its in the file folder drivers on the CD, you have to open the CD. for software code open file SN.TXT -ON THE DVD .DVD:\Folder\SN.TXT put DVD in drive and look youll see it. here a youtube tutorial also. watch this video and you got it.. hope i helped. http://www.youtube.com/watch?v=oKtdJDA4cE4
Posted on Apr 01, 2013
I have a DMR-ES35V DVD/VCR. Yesterday I recorded a TV show on the VCR and when I tried to play it back there was only snow. The TV is also Panasonic (TC-P42S1).
The DMR-ES35V only has an analog tuner (NTSC). Most TV channels now transmit in digital format (ATSC). Since the remaining analog stations are associated with low-power tuners, the tuner may not have picked up the signal. If you have an aerial antenna directly connected to the DMR-ES35V, it probably didn't find a signal. In that case, you need an OTA ATSC to NTSC converter or a stronger signal for a station giving an NTSC signal.
However, if you tried to record from a set-top box (cable/ OTA ATSC to NTSC converter), then check your connections. Several cable boxes will not transmit the analog signal if it is also sending a HDCP signal (high definition copy protection) to another monitor. (Thus if the TV is connected to a set-top box by an HDMI cable, no analog signal is available on composite video or RF outputs.)
Please add a comment to indicate what your TV source is and whether the source is connected to the DVD/VCR and TV separately or in a daisy-chain fashion.
I hope this helps you identify your recording problem.
Mar 05, 2018 | Panasonic Televison & Video
Sebrent usb 2.0 tv tuner & vidio capsher box wolnt work with windows 7
This page has all of the Sabrent drivers available. I could locate the exact driver if I knew the particular model # of your box. Is it the TV-USB20 or the TV-USBHD with digital and analog tuners?
http://www.sabrent.com/downloads.php Do you need the video capture software?
Jul 10, 2014 | Philips TV Tuner Video Capture PCI Card -...
Drivers usb digital tv atsc/qam/analog
Try the following:
http://sabrent.com/drivers/TV-USBHD/CD-USB_ATSC_NXP_ArcSoft3.5.rar
or
http://sabrent.com/drivers/TV-USBHD/CD-USB_ATSC_MT2063_ArcSoft3.5.rar
Sep 30, 2013 | Sabrent TV-USBHD ATSC & Digital USB TV...
Is jvc av-32d503 digital ready or do I need to buy a converter box for use with an outside antenna system
Looks like you'll need a converter.
Here's some background info:
Analog TVs were made up until 2007.
Digital tuners for over the air signals are called "ATSC tuners".
To tell if your TV has one:
-If the TV was sold as a "HDTV" or "DTV", it's supposed to have an ATSC tuner built in to it. "HD ready TVs" do not have a digital tuner.
-Check the specs in the owners manual or google the make & model of the TV to see if it has an ATSC tuner.
-If your TV's menu has an option for scaning for digital channels, then it has an ATSC tuner. If it dosen't have a way to scan for digital channels, then it doesn't have a digial tuner.
Most DTVs also have a digital QAM tuner that is used in some (but not all) cable systems.
Jun 11, 2011 | JVC AV-32D503 32" TV
Is the tuner built-in ATSC, or NTSC?
Your tv tuner is set to function on both NTSC and ATSC. See below for the reference
NTSC (National Television System Committee) is the analog television broadcasting standard used widely in North America. It is referred to as a 525-line standard, but actually displays only 480 lines. NTSC is to be replaced with new DTV (Digital TV) standards in the coming years.
ATSC (Advanced Television Standards Committee) creates the technical standards for the US digital television system (DTV). These standards are expected to be used in most new televisions, as the US television system shifts from analog to digital.
Nov 10, 2010 | Toshiba 57H84 57" Rear Projection...
We are in Ghana we need frequency and we update to get more channel
Your flat panel TV is probably factory set to receive ATSC signals (Hi-def DIGITAL TV), whereas
Ghana may not have converted from analog TV (NTSC) yet.
Digital TV's cannot receive analog signals. I'm just guessing about whether or not Ghana supports
Hi-Def broadcasts - you'll have to check with (any) TV channel in Ghana. The Analog-to-digital
conversion is an expensive one at the broadcast end, and may not have happened yet in Ghana.
The US conversion took place by FCC mandate June 12, 2009.
There are available $65 (USD) digital-to-analog converters, but what you may need is an
analog-to-digital converter, which doesn't exist. Your Flat-panel TV amy have to wait until Ghana
begins broadcasting a Hi-Def TV channel.
For a HD antenna, a regular old rabbit ear-type antenna will do.
Oct 15, 2010 | Televison & Video
Vhf is not picking up signal, no image
Well since all TV is now broadcast in High Definition that might be why you are no longer able to tune in a station. You will need the converter box.
Aug 19, 2009 | Casio Televison & Video
Digital Transition
It's analog.  You need to purchase a digital receiver.  I personally have a USB external digital tuner running in Media Center 2005.  Search Ebay for "ATSC usb".  There's a lot of different options and most of them are pretty inexpensive.  To use a digital tuner in Media Center 2005, you have to leave the analog tuner / tuners in also.  You should still be able to use your current remote control with the new digital tuner.
Jan 25, 2009 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
Does my Sanyo CLT1554 15 in. EDTV-Ready LCD have a digital tuner?
Your specs are here, http://reviews.cnet.com/flat-panel-tvs/sanyo-clt1554-15-lcd/4507-6482_7-32013875.html?tag=mncol;psum
unfortunately you have a
  • Analog TV Tuner NTSC
and
  • Enhanced Definition Television (EDTV) Monitor - EDTV Monitor refers to a monitor or display with the following minimum performance attributes:- Display Scanning Format: Has active vertical scanning lines of 480 progressive (480p) or higher- Aspect Ratio: None specified
You need a tv that has this:
Enhanced Definition Television (EDTV) Tuner - EDTV Tuner refers to a RF receiver with the following minimum performance attributes: - Receiver: Receives ATSC terrestrial digital transmissions and decodes all ATSC Table 3 video formats.
So Sorry, the tuner is not Digital.
Jan 05, 2009 | Sanyo CLT1554 15 in. EDTV-Ready LCD...
Sansui tv dtv2784
No this TV is not HD ready. However it is digital (ATSC) ready meaning now that most of the analog brodcasts have stopped it will receive the digital broadcasts so you don't need a converter box. Since it can only display 480i resolution it is not HD ready. You would need a TV that can display 720p or better to be considered HD ready.
Jan 04, 2009 | Sansui 27" TV
Sabrent Mini Stick USB 2.0 TV Tuner / Video Capture Box with Remote Control (TV-USBST) Logo
1,179 people viewed this question
Top Sabrent Televison & Video Experts
Lawrence Oravetz
pankaj rautela
pankaj rautela
Are you a Sabrent Televison and Video Expert? Answer questions, earn points and help others
