Question about Hoshizaki KM-630M Crescent Cuber Ice Maker
We have a KM 630 MAH the code that we are recievein is three beeps in three seconds the freeze back up timer where is it located
  • Hoshizaki Master
  • 1,266 Answers
It's programmed into the control board. It is something you do not replace separately. I'd look for what is causing the issue. Probably not a board. Look for water valve leaking water thru. Turn machine off and see if water is still running into the machine. If you have filters, be sure they are clean and you have no less than 20 psi during the fill cycle. Let me know if I can help further
Posted on Oct 12, 2010
The KM-500MAE has 3 beeps in 3 seconds after 2 consecutive cycles. What should I check?
Hoshizaki has service info on line in pdf format on servicing and trubleshooting. The machine itself has info on what three beeps message is. Sorry, no pinpoint fix
Aug 25, 2015 | Freezers
Hoshikazi km 630 makes beapin sounds
beeping sound is an alarm. the number of beeps tells you what the machine has found as an issue. count the beeps and get back to me,.
Aug 02, 2013 | Hoshizaki Kitchen Appliances - Others
3 beep alarm, machine is clean, has new float ***. but still locks out after dumping ice
Did you clean the float switch water tube going into the water trough when the switch was replaced?
Does it make 1 drop of ice,then shut off immediately?
What is the age of the machine?
3 beeps every 3 sec. = Freeze Back Up Timer. Freeze > Specified Setting
Yellow LED marked "F Timer" energizes. Check for F/S stuck
closed (up), WV leaking by, HGV leaking by, PM not pumping, TXV
not feeding properly, low charge, or inefficient comp. Dip switches 9
& 10 allow for factory adjustment of this back up timer feature.
Aug 10, 2011 | Hoshizaki KM-1300S Stackable Crescent...
I have a Hoshizaki model Km-250baf it beeps three times.
3 beeps means it has been in the freeze cycle too long. A stuck float switch can cause this as well as a leaking water valve. Look for that first. Let me know if you need more info.
Feb 06, 2011 | Hoshizaki Freezer Commercial Ice Machines...
3 beeps every 3 sec
3 beeps every 3 sec. = Freeze Back Up Timer. Freeze > 60 minutes.
Yellow LED marked 60 MIN energizes.
Check for F/S stuck closed (up), WV leaking by, HGV leaking by, TXV not feeding
properly, low charge, or inefficient compressor.
Jul 15, 2010 | Hoshizaki Commercial Freezer KM-500MAH
3 yr. old Hoshizaki km630 mah, Had a hard freeze(24 degrees) at the shop and checked the ice maker that sits outside main bldg. Main water supply line inside that joins the copper pipe to the plastic...
There should be a reset button on your control board inside the electrical compartment.
Turn the system on to ice mode and depress the reset button. This should clear out any and all faults stored in the board and the machine should at least attempt to come back to life.
Look on the outside of the electrical compartment cover. There should be an explanation of what your error code means. I can't remember it off the top of my head. But the list there will tell you what 1 beep every 305 seconds means and the procedures to take from there.
Jan 13, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki km-1300skf 3 beep error code
The 3 beeps indicates that the freeze cycle is longer than 60 minutes. with the suction pressure at 20, it sounds like low on charge (freon). I believe this is an R 404-A unit. Other things to look for are: Stuck float switch (in the up position), Water valve leaking, hot gas valve leaking, txv not feeding properly, weak compressor. Look at high side pressure too. It should not go below 210 psi during the freeze cycle. Low pressure should be in the middle to upper 40's psi.
Let me know if you need more.
Jan 02, 2009 | Freezers
ERROR CODE C630 ON KYOCERA KM-1510
this is a fuser error meaning that the fuser has overheated. In most cases the thermal fuse or thermostat blows and will need replacing. especially if you get the 630 code, and switch the machine of and back on and get a 610 code.
Oct 13, 2008 | Kyocera KM-1510 Copier
Hoshizaki ice machine model KM-250BAF SERVICE MANUAL
km-450mwb hoshizaki problem is machine strate is ok but to long time ice making , not dropping, two beeps every three seconds what problem i don't no pleas help mi
Jul 30, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki Ice Machine Model KM-500MAF
(Quated From Hoshizaki Technical Bulletin)
An alarm code of 3 beeps
every 3 seconds means that the control board has shut
down on the 60 minute freeze cycle back up timer.
The “E” control board has a 60 minute timer that starts at
the beginning of the freeze cycle. If the float switch fails
to open and start the next harvest within 60 minutes, the
board will automatically start the harvest cycle. If this
occurs in two consecutive cycles, the control board will
shut the unit down on the manual reset, freeze cycle
back- up timer. The yellow fault LED marked “60 min.”
will illuminate. This safety is designed to help prevent a
freeze up of the evaporator.
Once you have identified the 60 minute alarm, there are
several things to check. Reset the alarm by depressing
the white reset button to the right of the fault LED’s.
This must be done with the power “ON”. Now check the
float switch to see if it is stuck in the up position. A stuck
float can occur if scale is present on the reed switch
shaft inside the housing. To check it, drain the water
reservoir, unplug the black float switch connector (K5)
from the control board and check it with an ohm meter
for a closed switch (zero ohms). If the float switch is
sticking, clean it with ice machine cleaner or replace it as
necessary.
An inlet water valve which is slowly leaking by during the
freeze cycle can cause a 60 minute alarm. If the inlet
water valve is stuck wide open, it is unlikely that any ice
will form on the evaporator. Check for a slow leak by
allowing the unit to cycle into the freeze cycle and
disconnecting the hose at the outlet of the water valve. If
water leaks by during the freeze cycle, the water valve
diaphragm is likely damaged or the small diaphragm bleed
port is clogged with scale. Clean the bleed port or replace
the diaphragm or entire water valve as necessary.
(I Recommend to get a refrigeration tech for this part).
Another possibility is a refrigeration system problem. You
should use normal refrigeration diagnosis procedures to
check for one of these problems. If the thermostatic
expansion valve is not feeding properly or the refrigerant
charge is low, the evaporator will not form ice as it should
and a long freeze cycle will occur. This could also be the
result of the hot gas valve not closing completely during
the freeze cycle or if the compressor valves are weak or
inefficient. An inefficient compressor however, will
usually show up first on the KM model through a longer
than normal harvest cycle. This is because of cooler
than normal discharge gas. Use proper refrigeration
practices to repair a refrigeration system problem.
While these are not the only reasons for a 60 minute
freeze cycle, they are the most common and should be
checked to resolve a 3 beep/yellow fault LED alarm.
Feb 27, 2008 | Hoshizaki Commercial Freezer KM-500MAH
Hoshizaki KM-630M Crescent Cuber Ice Maker Logo
149 people viewed this question
Top Hoshizaki Refrigerators Experts
Tom Donaldson
Level 1 Expert
J Rosado
Marat Brikov
Are you a Hoshizaki Refrigerator Expert? Answer questions, earn points and help others
