Question about Frigidaire FEF352 Electric Kitchen Range
Turning dial for small element - sparks flew out and it blew a breaker - could not shut dial off
    President:
  • 1,430 Answers
This could be the heating element, receptacle or infinite switch. I would first check the element and element receptacle if it checks out good check the switch. Here is a couple links that will walk you thru this.
http://appliancehelponline.com/elementreceptaclevideo.html
http://appliancehelponline.com/infiniteswitchvideo.html
Posted on Aug 04, 2010
My 4H.P. 25 gal. air compressor doesn't work, when i plugged it in it blew the beaker and the outlet. Now it's dead?
Check motor reset on end of motor. Check cord for damage, insure insulation isn't cut. If you've reset your breaker for receptacle , make sure switch for compressor is off, plug in , then flip switch. See if motor attempts to run. If the problem repeats, motor could be shorted if cord is ok.
Sep 29, 2015 | Air Tools & Compressors
Frigidaire FEF365BGWC bake element went out when pulling out I forgot to unplug from wall. Sparks flew . Now nothing is working. It's getting power from wall.
Check all of your high limit safety switches. Possibility you may have fried the transformer on the main control board
Apr 17, 2015 | Frigidaire Ovens
How to troubleshoot the expandable element in frigidaire gallery professional stove. I have a model fes388wgct and one of the expandable element just turn on the small element.
Good Afternoon Hector,
I understand that the expandable element on your Frigidaire range, model# FES388WGCT, is only turning on the small element. I suggest resetting your appliance, be either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and try turning the expandable element on. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 25, 2014 | Frigidaire Kitchen Ranges
Kenmore stacked laundry unit. when it was plugged in sparks flew and small parts of the heating element fell and the power cord is ow black. can we replace cord and be ok
Heating element must be replacedas well as the cord. Make sure the drum screws were not screwed into anything electrical.
May 18, 2013 | Kenmore Dryers
While baking there was a spark and smoke that blew out the breaker
Sometimes there are two breakers, one for the 110v and one for the 230v. The 110v works the light and the clock and such, and the 230v handles the heater elements. If the breaker blew, you might need a repair though. Also always be careful when working with electricity please.
Dec 20, 2011 | Frigidaire Kitchen Ranges
I hit 350 and start on my range and sparks flew out of both sides and now the oven does not work. The stove works but not the oven. can you tell me how to fix this.
It sounds as if the bake element has failed. They cost around 8 to 20 dollars. You will need to unplug the stove first. (Shutting off the stove breaker is good to do before unplugging the stove as an added precaution). On the back of the stove there is a metal
cover with a couple of 1/4 inch hex screws. remove this cover and unplug the bake
element. Then remove the two hex screws inside the oven and slide out the bake element. The model number is located below the oven door behind the drawer to
purchase a replacement. Hope this helps.
Jul 13, 2011 | Frigidaire Kitchen Ranges
I hace a 2003 Kenmore Electric Ran ge #790-95682. Five minutes after turning the oven on to preheat, I heard a loud poppong noise and spark near the left side of the burner controls on the display panel....
your bake element blew look at it to see if it is broken. if it is replace. the main breaker blew in breaker box .most likely .or a wire is burnt take off back panel and look .unplug first .good luck
Aug 23, 2010 | Kenmore 95822 / 95824 / 95829 Electric...
Oven erupted like a blow torch why?
The broiler element burned into. Look at the top element and you will see a spot where it is rough, melted or burned. Replace the element by removing the two screws at the back of the oven and pull the wire out a little and unplug the element and plug the new on it.
Dec 26, 2009 | Kitchen Ranges
Poping sound, sparks shooting out and 220 circuit breaker out
Did you move the breaker fully off before turning it back on? make sure the offending burner is off.
It sounds as though the element shorted out.
Mar 17, 2009 | Jenn-Air JED8430 Electric Cooktop
Frigidaire FEF352 Electric Kitchen Range Logo
125 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Justin Duby
Justin Duby
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
