Question about Honeywell Heating & Cooling
I THINK THE AC UNIT IN MY ATTIC IS BROKEN. IT SOUNDS LIKE ITS GOING TO BLOW UP WHEN THE UNIT COMES ON. OUT OF THE BLUE LASTNIGHT IT STARTED MAKING A REALLY LOAD NOISE AND THE NOISE HAS ONLY GOTTAN WORSE
  • 407 Answers
This is more than likely the fan blower motor on the inside of the unit. You could get lucky enough to just have something get sucked into the return and has wrapped itself in the fan blades causing it to become off balanced, but most of the time it is either the motor bearings going out or the bracket that holds the motor in has broke. You can check any of these by shutting the power off to the unit and opening the blower motor compartment (usually just the front cover of the unit) and while the fan blade is no longer moving, and trust me, they can spin forever, feel around the blades to see if anything is in there and while your there, you can check the play in the wheel by grabbing it and try to moved it left to right. If there is play in the wheel, it will need to be taken out and either tightened back onto the shaft or the motor replaced. You can also check the bracket that holds the motor in, this should just be a visual check to see if any of them have broke or cracked. I hope this points you in the right direction and good luck!
Posted on Aug 05, 2010
I am having Sanyo room AC model SA185 DX6. The AC was working when all of sudden it stopped working. I checked & found Circuit breaker had tripped. I turned on the Circuit breaker and started again,...
Hello, sounds like the compressor is shorting to ground, this means that one of the windings is making contact with tje shell of the compressor and making the breaker trip. The only option is to replace the compressor, you can check the windings by taking the cover off the compressor which holds the terminals, make sure the unit is unplugged and take one meter lead to each terminal and the other lead to a ground such as a screw you should have no resistance if the compressor is good, if the compressor is bad you will read resistance.
Apr 29, 2011 | Sanyo Heating & Cooling
No power to ac unit
Check the breaker for the unit or check to see if the disconnect by the unit in the attic has fuses that may be blown.
If the breaker is tripped or the fuses blown, then check to see what caused them to blow...
heatman101
Aug 01, 2010 | Bryant 463AAC008BA Air Conditioner
I have a Weather King AC/Furnace in the attic that's dripping water into the drain pan. When we purchased our new house it came with this unit and it never dripped ater. Now, the water is dripping towards...
I assume it is dripping water when the AC is running. If you look at the attic unit, there should be a PVC pipe running from the unit - probably an insulated PVC pipe. This pipe probably goes across the attic to the edge of the house and drains outside. The drain pan may also have a drain pipe, but the one on the AC unit is the issue, and is probably plugged. Go outside and see if you can locate the AC drain pipe. See if the ground is wet below the pipe and if water is steadily dripping from the pipe (with AC running). If the pipe and ground are dry, the pipe is plugged. If you have a wet/dry vac, try connecting it to the drain pipe outside to see if you can **** the pluggage out. If you can get it clear, water should start dripping out of the pipe. This same thing happened at our house. I decided to cut the pipe in the attic, and add in a PVC isolation valve, tee, and water hose connection with plug, so I can valve out the AC unit from the pipe, remove hose connection plug, and hook up a water hose and flush the line to outside. Lowe's sells all of the PVC pipe fittings. The water pressure from the hose will always flush out the algae and crud to the outside of the house. I can also remove the plug and pour a cup of bleach down the drain pipe every couple of months to keep algae growth in check. I also cut out the trap (u-leg) from pipe in the attic and purchased a ready made trap a Lowes (the contractor who built our house had made a lousy homemade trap). I purchased a few PVC elbows and installed the trap on the drain pipe outside. By the way, our AC drain pipe comes out of our wall outside and drains near our outside unit. Our secondary drain pan drain pipe comes out outside from an eave on the side of the house. I don't know what you drain line looks like (it may have a port to add bleach, or some cleanout provisions, maybe not). If you choose to modify/improve it, then make a sketch of it, go to Lowe's and get the PVC parts you need + PVC pipe primer and cement. PVC cement dries fast. Remember, the pipe must flow downhill from you AC attic unit. You can use a regular wood saw to cut the pipe. I hope this helps you. You need to keep the drain line clear as algae will continue to grow in it. Pouring bleach in the line every month or two helps. You also need to check maybe once a month that the line is draining properly (check to see if dripping outside). You can get some serious water damage to your ceilings if the water backs up and overflows. I discovered that our drain line was plugged just in time as our drain pan drain line was also partially plugged and drain pan was about to overflow.
May 08, 2010 | Weather King 12AJA4201AH Air Conditioner
Rudd 2.5 combo ac/heat unit
This could be due to a freon leak or the condenser unit needs cleaning also the evaporator in the attic should also be cleaned and inspected. If cold sweat is not seen outside on the large line going into the outside unit I believe you may have a freon leak. Sea Breeze
Aug 27, 2009 | Ruud UAMB Air Conditioner
Blower in attic & AC unit outside continuously run
Sorry to hear about your miss-fortune, you are right it is an wiring problem. Can you turn off the blower with the thermostat (cool-off-heat) or what happens when you switch the fan to (auto or on) When you say the outside unit is "rigged" is it mechanically being jammed or electrically? If its mechanically that should be removed (what a crappy thing to do) other wise it will run continuously as you may already know. That is what it sounds like, you should just be able to shut the entire system down by turning off the switch to the furnace. If it is electrically being held closed, he changed some of the wiring around in the attic unit, you better hope he was lazy and jammed a stick in the contactor in the outside unit or else you may need to learn more about HVAC wiring, none the less I would double check the thermostat wires going to the attic furnace there should be nomenclature on the unit or at least somewhat marked. This was probably disturbed when the new blower was installed, by the way that was your initial problem. Good luck and becarful
Aug 17, 2009 | Ruud Matching Split Air Conditioner
AC unit in the attic is making a loud squeaky noise as it's going off
You may need to oil the fan motor. Most fan motors have an oil port at the shaft. It will be a yellow plastic cap that you pull out. once this cap is removed you need to oil the motor with an oiler that has a extending spout such as the ZoomOiler brand purchased at your local hardware store
Jul 08, 2009 | Heating & Cooling
Climate control
the ac system on those vehicles are vacuum operated so they can change with acceleration. however it sounds like the head unit on your may be allowing for vacuum to bleed off.
Apr 24, 2009 | 2003 Mercury Grand Marquis
Blank/Black Laptop screen on HP DV-6000 notebook
Please have a look at this article and consider updating the BIOS: click here
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Apr 03, 2009 | HP Pavilion dv6000t Notebook
Hello :)
1. Switch off the AC first for a few hours
2. Remove the power connector
3. See that the Compressor is cool first
4. check the air tube and the blowers
5. Reconnect the same and connect the power cables
6. Swith on the AC then
If your problem solved plz rate me
Feb 24, 2008 | Heating & Cooling
Blower in Attic not running
inside unit has fan control relay , either on control board or can be separate ,except for the 24 volt transformer and the t-stat the units operate separately concentrate totally on the inside unit this is where the problem lies
Oct 23, 2007 | Ruud UAMB Air Conditioner
Heating & Cooling Logo
79 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
