Question about Lowrance LMS-332C GPS Receiver
Installing an old used lowrance fish finder
I bought an old used fish finder. It came with a screen, transducer mount with the chord, a speed thing with a wheel, and a smaller looking transducer. My question is ??? the power chord was cut and I noticed four color wires in it, black for -, red for +, a green one and a white one. Whats the green and the white wire for and do I need it? Also, can I just use the transducer without using the speedometer and the other transducer looking thing?
    Guru:
  • 597 Answers
I don't think your old fish finder is the LMS-332C GPS Receiver listed above in the description. You don't need the speed wheel for the fish finder to function just the transducer and transducer mount. You should mount that on the back of the boat towards the center but not too close to the motor and not too close to the side of the board. Don't let it hand below the level of the boat. That should keep it from getting hit by the trailer or dragging on the bottom. Try to make it as level as possible. The green and white wires may be for the speed wheel but i'd need a model number for clarification. Hope this helps.
Posted on Jun 02, 2009
How to connect Humminbird fish finder to Motorguide trolling motor
I would use slip rings to tie existing cable to prop motor support shaft and mount transducer to motor housing. 'slip ring'--metal ring a little bigger than shaft with a nipple the size of the cable. OR call the bird at 1-800-633-1468 or www.humminbird.com/Category/Company/Contact-Us/ and use some southern/country slang when talking. Best of luck 'you all'.
Oct 03, 2016 | Humminbird Boating
How much torque on the transducer mounting bolt?
I install these and other Lowrance systems.
For me there is no specific amount of tourque, it's primarily your best judgment.
You want the bolt tight enough so that the transducer doesn't pivot while on plane but if it were to collide with something it would pivot up out of the way.
May 22, 2015 | Lowrance Lcx 28c Hd 7" Gps Fish Finder...
Doesn't work on fast flowing river
Many depth finders don't work when the transducer sees a little turbulence. My only suggestion is to try different locations for the transducer, trying to guess where there will be the least turbulence beneath it. This is easy if your transducer is mounted inside the hull and reads through the hull. Not so easy if it is a through-hull mount. Be sure it is mounted correctly to the hull if it is mounted inside the hull.
Dec 03, 2017 | Lowrance HDS5x Fishfinders
Lowrance Elite 4X fish finder that reads between 1.5' and 2.5'
Hey Anon
The transducer installation is more important than anything.. next to correct wiring! You must make sure the mounting is good,,, if its outside the hull, make sure its sitting 1/16th below the hull with no obstructions.. if its inside the hull, the medium you used to fix the puck to the hull must be porosity free and the puck sitting as level with the WATER as possible..
Now, take the manual to the lake with you and DO NOTHING but read the manual and apply what you read to the unit,,, read -repeat - read-repeat.. forget about fishing... now read-repeat and learn... IF nothing seems to be reading correctly.. its probably the transducer installation.. YOU DID use a/the transducer specifically for this unit!!
Jun 24, 2017 | Lowrance Elite-4x Fishfinder
My depth finder keeps loseing the bottom and just flickers the last reading
Hi, if this happens when stationery check the angle of the transducer, if it only happens when moving check the height of the transducer also. Regards Phil
Jul 02, 2012 | Lowrance Lcx 38c Hd Fish Finder Gps (200...
Transducer loses bottom at any type of speed greater than trolling. Worked fine last year with all the same setttings. All I can think of is , maybe the battery is low. The boat just came out of storage...
Check the transducer for any damage on the front part. Also make sure there isn't any damage on the bottom of the boat that is causing air bubbles to cross the face of the transducer. If it works at slow speeds there is definitely something causing air bubbles.
May 08, 2010 | Lowrance Lcx 27c 7" Gps Fish Finder Combo...
How to splice cables for my fish finder
Man, As much as I hate to say it, you need to call up Lawrance and order a new one. I have tried but have never been able to repair cut transducer cables.
Jun 27, 2009 | Boating
False fish readings
False fish readings are commonly caused by electrical interference such as alternator noise, and by air bubbles flowing across transducer.
For starters make sure your fishfinder is on an independent circuit and not on one powered by your ignition switch. In other words, you should be able to turn your fishfinder on, even though the engine is turned off. Ideally the fishfinder should be wired directly to the battery with an in line fuse.
Try running the boat at a speed slightly higher than trolling speed, then kill the engine, as the boat slows down to trolling speed do you still see false echos? If yes then the problem probably lies with how the transducer is mounted, or where it is located on the hull.
If you don't see the false echos when the engine is off, it may be necessary to reroute the transducer cable to keep it away from the boat's ignition wires. You can get transducer extension cables if necessary. Also there are filters that you can buy that suppress alternator noise buy attaching between the battery and the engine.
Another common cause of false echos from electrical interference is a transducer cable that has been cut and spliced.
I hope this information helps. Please reply if you have any questions about my response.
Feb 25, 2008 | GPS
Lowrance LMS-332C GPS Receiver Logo
963 people viewed this question
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Wbix
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
