Question about Skil 6237 04 5.0 Amp 3/8 Inch Keyless Drill
How do I remove the bit from skil power drill 4.5 amp?
5 Suggested Answers
  • 1214 Answers
SOURCE: how to change drill bit
Grab the end of the chuck in one hand, and the outer ring of the chuck nearer the motor, and twist the chuck end. try both directions until it loosens.
Posted on Jan 28, 2009
  • 3 Answers
SOURCE: How do I change the chuck on a 5 amp skil drill. It is keyless.
If it's anything like their other drills, there is a safety screw with left-hand threads inside chuck.
  1. Turn it clockwise until loose.
  2. Then insert the short arm of a 3/8" hex wrench and tighten.
  3. Strike long arm of wrench sharply counter-clockwise and chuck should loosen to unthread from spindle.
Posted on Jun 24, 2009
SOURCE: Bit or chuck type for a Skil 717 hammer drill
I have a Skill 717, too. It has a hex shank. Here are a couple places that I've located that carry (some) parts:
www.icscuttingtools.com (pages 155 & 157)
www.bamanufacturing.com/page_15.htm
also try:
www.ereplacementparts.com
www.toolpartsdirect.com
Posted on Mar 09, 2010
wentlanv
  • 710 Answers
SOURCE: how do i take out
Hi ladogers,
Welcome to fixya!
This drill has a keyless chuck. To remove the bit, just turn the chuck to the right (looking from the handle to the front) to open the jaws. To put in another bit, tighten the chuck to the left to close. You have to use both hands. You will see where the ridged portion of the chuck is in two sections. Hold on to the back section with your left hand to keep it from turning while you turn the front section with your right hand.
A lot of the time I just push the button to put the drill in reverse, hold on the front section of the chuck and turn it on. It will loosen by itself. Then when you put the new bit in, put it in forward and hold on to the chuck and press the switch. The bit will be in nice and tight.
Good luck,
Please place a vote when you accept this solution.
Thanks,
Handie Andie
Posted on Aug 16, 2011
How do you tighten bit?
Not 100% sure about SKIL cordless, but try turning a collar part just behind the chuck. It may be a friction chuck. Others use a hexagonal female shaft, which has a magnet inside to stop the bit falling out.
Nov 05, 2017 | Skil Drills
How do i take out a skil 12 volt battery drill bit. i havent used the drill in a year or so and i forgot please help, or not
Hi ladogers,
Welcome to fixya!
Good luck,
Thanks,
Handie Andie
Aug 16, 2011 | Skil 12 Volt Drill/Driver with Built In...
Putting new bit in my skil9. I'm relatively new with my drill and i'm trying to hang curtains so I need a bigger bit in my drill
Hold the black part on the end of the drill with you hand firmly and then run the drill in reverse...that will loosen the bit...
Place the next bit into the drill and then holding the end run the drill forward till the bit is tight...
heatman101
Dec 05, 2010 | Skil 2566 02 120V 14.4V Cordless Drill Usa
Have a skil 597 T8 thats lost its grip - is it neccy to change the chuck - and if so can I replace the chuck with one that can open far enough to accept some larger bits?
I couldn't find your particular drill model drill. If this is a corded drill with a 1/4 inch chuck, you would do better to just buy a corded 3/8 drill. But otherwise, yes, change the chuck if you can find one to fit at a reasonable price. Drill chucks are sized to hold a straight bit of the maximum hole diameter that the drill has enough torque to drill into mild steel. If you find a larger one that will fit on your drill, it will work fine, but if you overload it you will burn it out. If you don't drill into steel with any larger bit than the original chuck, then this won't be a problem.
Jun 29, 2010 | Skil 3/8IN DRILL CHUCK/KEY
I have a old skil electric hammer drill with a 3/4 inch hex shaft i cant find any new masonary bits with that shaft
Go to a tool rental place with your drill and see if they can match you up with a proper tool for it.
Thanks for your interest in FixYa.com
Feb 11, 2010 | Drills
also try:
Sep 12, 2009 | Skil Drills
Skil charger & batteries won't charge
The only thing I suggest is taking your Skil driver to a Bosch service center (Skil is now owned by Bosch) and they will replace the charger under warranty if the driver is less than a yr old. If not those chargers are not that expensive. Either way you need a new charger because they are not repairable.
Jun 10, 2009 | Skil 2362-01 Factory-Reconditioned 7.2V...
Jun 06, 2009 | Skil 6237 04 5.0 Amp 3/8 Inch Keyless...
How to change drill bit on black & decker plus pivot cordless drill How to change the bit on a Skil cordless screwdriver 2362 with a keyless check?
Jan 28, 2009 | Drills
SKIL 18V BATTERY PACK
There are three visble screws and one hidden. Use the right size torx driver if you have it, or a small allen wrench works too and undo the screw that is visble on one side of the pack. Snap the false bottom off of the pack and reveal two more screws to remove. One screw is behid a plastic cap over a fourth obvious screw location. Drill the cap and unscre this screw also. Be sure there are no lables holding the two side together. Pressing down on the battery holdin clasp makes the sides easier to separate. Watch for falling parts. That's it!
Nov 28, 2008 | Skil 2887 05 18 Volt 2 Speed 3/8 Inch...
Skil 6237 04 5.0 Amp 3/8 Inch Keyless Drill Logo
64 people viewed this question
Top Skil Drills Experts
epangan29
 steve
steve
Are you a Skil Drill Expert? Answer questions, earn points and help others
