Question about Pride Mobility Products Pride Jazzy 600
My Pride Jazzy 600 right side drive wheel just stopped opperating while I was using the chair. Have checked the freewheel and it is properly engaged and the batteries are fully charged. It appears that all of the connections are tight. Any Ideas?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 346 Answers
Hello,plase rate me for my answer,as in thumbs up 1 to 4. im disabled my & do this cause i care not for money.Please visit:www.alldatasheet.com & type ur info of product,download the troubleshooter as a PDF File to use with Adobe Reader,you can also print it off for future Ref.Hope this has got ya mobile,take care Colin.
Posted on Aug 04, 2010
Jazzy 600 stops all of a sudden while driving, chair icon and wrench icon on romote appears
Likely 2, 3, 4 or 5 bar flash code. If motors are made by a company like "ELE...." then motor wiring is likely bad inside wire insulation where wires go into motor cap. Rebuild motors and try again. This is a common problem with these motors.
Jul 27, 2014 | Pride Mobility Jazzy 600 Power Chair -...
My jazzy pulls to the right what is wrong
Does the chair only pull to the right when you are going up an incline or over a threshold? If it appears to be working fine on a flat surface then you may have a motor getting weak. If this happens on all surfaces you may have a few issues. The brake on the right side may not be releasing completely and is dragging. Replacing the brake should fix that issue. The other issue may be that the freewheel engager is disengaged. Engage the wheel and you should be fine. If this fixed the problem and it comes back then you might need a technician to look at it. I have found that the customer had someone else look at the chair/motor to save some money and took the motor off the chair. Normally there are no serviceable parts but if they forget to replace or lose a small spring under the motor engager lever you will experience the chair disengaging under load. If none of this helps. You will need to get a qualified tech to look at the unit.
May 26, 2014 | Pride Mobility Products Jazzy Select
How to engage freewheel mode
Push down freewheel levers behind each wheel. Rock the chair back and forth if the levers are difficult to move.
Mar 29, 2013 | Pride Jazzy Select 6 Indoor Power...
When i turn the power on, the lights on the battery and the speed keep flashing very quickly. they do not stop.
Archie the only thing I can think that causes this problem is one or both of the motors are in freewheel. Check that both levers are in drive mode. then turn the chair on to see if the flashing stops if not call Pride @ 1-800-800-8586 ask for Jazzy tech support and explain the problem They should be able to lead you in the right direction Hope this helps you
Mar 20, 2011 | Pride New Jazzy 600 Power Wheelchair by...
I have a Jazzy 1103 Ultra and the lights are all on like it should be but the chair will not move. I am in Mississippi visiting my daughter and would love someone to help me. Thanks!
It could be a few things.
It might be on freewheel. To solve this: 1. Turn the chair off. 2. Locate the freewheel lever just behind the drive wheel, and on top of the motor. 3. Push the lever inward to engage the motors. 4. Repeat steps 1 and 2 for the other side. 5. Turn the chair on and see if it works .
If not, it the circuit breaker might need to be reset because of heavy strain on the motors and batteries. To solve this: 1. Turn the chair off. 2. Find the circuit breaker on the front of the case, off to the right side (you will see a hole in the case) 3. Press the circuit breaker button. 4. Turn the chair on and see if it works.
if not, the battery may need to be disconnected and reconnected To do this 1. Turn the chair off 2. Release the friction lock lever under the seat. 3. Remove the seat. 4. Release the rear shroud fastener and the yellow fastener under the front shroud. 5. Remove the shroud. 6. Disconnect and reconnect the battery connector (the big plug) 7. Replace the shroud and seat. 8. Turn the chair on and see if it works.
If not, contact your provider.
Feb 23, 2011 | Pride Jazzy 1103 Ultra Indoor Power...
I have a wheelchair using a DL 5.2i controller.when switched on it shows all lights blinking every 2 seconds and no power to the wheels.
Make sure that you are not in freewheel. If you can push the chair and the chairs rolls easily you are in freewheel, look for the freewheel levers and place them in the drive mode. If you are not in freewheel then you could be in sleep mode If you have a manual see if it tells you how to get out of sleep mode. If not within 10 seconds of turning the chair on try pressing the horn button twice and then turn off then back on to see if you stopped the blinking lights. I don't know with the older joysticks how else to get it out of sleep mode. If you are still having problems you can call Pride
Mobility @ 1-800-800-8586 on Monday ask for Jazzy Tech support and they should be able to help
Hope this helps you
Feb 04, 2011 | Select Jazzy Used Electric Wheelchair
I have a fairly old 1121 but cannot find any levers to go into freewheel. I have seen a modern one and can see them in that. Can you help?
Jackie I looked on the Pride Website and threy showed them behind each drive wheel above the motor facing the rear of the chair. Lift to place in freewheel and push down to engage. I hope this helps you
Oct 12, 2010 | Heavyduty Jazzy 1121 Standard & Heavy Duty...
Replaced battery in jazzy 600 wheelchair and the light comes on, but wheelchair will not do anything.
Make sure that your drive wheels are engaged and the power chair is not in the freehweel position (so it can be pushed).
Sep 09, 2010 | Pride Jazzy Select 6 Indoor Power...
Chair won't go. Lights flash
Check your freewheel levers. They must be engaged or the lights will flash and the chair will be inoperable. These levers are under the shroud behind drive wheels. (One on each side)
Apr 30, 2010 | Pride Jazzy Select 6 Indoor Power...
Pride Mobility Products Pride Jazzy 600 Logo
133 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Robin Hill
Robin Hill
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
