Question about Toys
I need screws for simplicity crib 8621 prc. This simplicity crib was NOT recalled. The crib can be converted into a toddler bed.
2 Suggested Answers
  • 16 Answers
SOURCE: i need a manual for
simplicity is no longer in business and it is on recall. bring it back to the store you bought it from and get refund or exchange it for a different company
Posted on Oct 03, 2010
I lost my manual, I need to know how to transform the crib into a toddler bed
Converting a Simplicity Crib into a Toddler Bed:
Please note, Simplicity has gone out of business and the Simplicity Cribs should NOT be used as cribs. They were sold at Walmart, Target and BabiesRUs. The word on the street is that Walmart is the easiest to deal with when it comes to returning them. Those who wish to return Simplicity cribs don't need a receipt, they can just take them to Walmart for store credit. BabiesRUs was apparently giving about $65 while Walmart was closer to $190. Again, this is just what I have heard from others.
You can find the specific information on the Simplicity recall here.
If you do want to use your Simplicity crib as a Toddler Bed, I have not read any warnings against this. Again, I might just take it to Walmart anyway and get a store credit and perhaps buy a new convertible crib. You can get some great ones on Amazon for around $150 with delivery included.
I would pack it up, take it in for store credit, and get a new crib!
You can get some great deals these days on cribs, there's a great one on Amazon for $150 with free shipping so it's kind of a no-brainer.
As I have heard, Walmart will take it back, no questions asked and no receipt necessary and you can get a brand new one with brand new parts, brand new instructions and no recalls or risks!
Good Luck.
Here's one of my favorites:
mkd123_2.jpgGraco Sarah Classic 4-in-1 convertible bed
If you still want to convert it, here is what you need to do:
1. Remove the front panel of the Simplicity crib. Use an Allen wrench and 45mm bolts (there should be extras underneath the crib, along with an Allen wrench, but if there aren't then you can pick some up at your local hardware store.)
2. Check the mattress support. It needs to be in the lowest position available, which will allow the toddler to get in and out of bed easily. It is also the only position that will make the rails line up properly with the pre-drilled bolt holes. To lower the mattress, unscrew the four bolts from the four corners of the mattress support and slide the support down. The holes for the lowest setting are just about the bottom wood panels. Use your Allen wrench to reattach the mattress support with the same bolts you pulled out when the mattress was in the higher position.
3. Attach the toddler bed rails to the crib frame. Use two 38mm Allen bolts on each rail. There are pre-drilled holes in both the rail and the crib frame. Line up the holes and then loosely screw the bolts into place. The bottom of each rail has a metal L-shaped hook. This will slide under the mattress support. Use a 19mm Allen bolt to attach this piece to the mattress support. When everything is lined up and screwed in loosely, go back and tighten each bolt. Repeat on the other side.
4. Check the entire crib frame for loose bolts. Use the Allen wrench to tighten all the screws. Toddlers can be rough on their beds, so it is important to make sure the bed is safe. You should recheck for loose bolts often. Jumping and climbing on the bed can easily loosen the bolts and screws.
5. Don't forget to hang onto the front panel and store it carefully, you will need it later to convert the bed into a full sized bed.
Jan 23, 2011 | Simplicity for Children 4-in-1 Convertible...
I need a manual for the simplicity for children crib/bed model # 8621 prc
Oct 03, 2010 | Toys
8994W Crib: How do I convert a Simplicity, Inc crib model #899...
There is a recall on thin crib you can take it to the store were you bought it and they should refund your money. I have one and Im taking my to the store tomorrow.
May 17, 2010 | Simplicity for Children 8994W Crib
I would like to convert my Simplicity crib #8748 from a crib to a toddler bed.
It is very simple to convert a crib to a toddlers bed. You just need to remove the side railings by folding them under the bed. It would be automatically converted to a bed that a toddler can use
Mar 02, 2010 | Simplicity for Children Ellis 4 in 1 Sleep...
Graco 3-in-1 crib instructions
Check this CPSC link.
Most if not all of the simplicity brand cribs have been recalled reguardless of whether they had wood or metal mattress supports.
There were 2 different recalls on the wood version but both were recalled for the drop-side issues.
This link specifically includes the Aspen 3 in 1 cribs and model #: 8740
We took ours to our local walmart last summer (we purchased it in a different state almost 8 years ago). I brought to cpsc report with me. They had not issue with the recalled information we has matching it to our crib. It did take the clerk a bit to find our crib in their system because it was older, but once she did we recieved a full refund, without a receipt.
As far as changing them to a toddler bed. When we converted ours to a toddler bed we simply removed the drop-side from the crib. The drop-side parts can be unscrewed from the side rails. Then we screwed the toddler rails to the bottom of the crib. Ours had screw holds for the toddler rails on the mattress support. If you do not have the holes for it, then you may have put the mattress support on backwards ie with the side that has the holes for the toddler bed rails on the backside of the crib.
Dec 04, 2009 | Graco Apsen 3-in-1 8740 Crib
I need instructions on how to convert the 8996 simplicity crib into a toddler bed.
Certain cribs are going to the crypt. Simplicity Inc. is now out of business. As of July 12, 2009 at least 13 children have died in cribs and basinets recalled by Simplicity.
Because of this it may take some time. Please be patient.
Sep 01, 2009 | Simplicity for Children 4-in-1 Convertible...
How to convert simplicity ellis {8676} 4 in1 crib
My granddaughter uses the same bed ... I have scanned the manual.
BTW, this model was NOT on the recall list and Simplicity is no longer.
Good luck getting any parts for this model. I understand that this
still can be found at several stores.
The manual can be downloaded @:
http://users.waymark.net/crude/Simplicity_Ellis_Manual.htm
Hope this helps
Crude - D10 Escapee 12-26-06
Sep 17, 2008 | Simplicity for Children 4-in-1 Convertible...
Simplicity 4 in 1 Crib combo
i have lost the directions to my 4 in 1 simplicity crib, we are trying to convert it to a twin or the daybed but do know how, the manafacturing code is 3804cw and the vender item # 8994w, if u have any info on this bed please let me know.
Aug 16, 2008 | Simplicity for Children 4-in-1 Convertible...
Helppppppp!!!!!!!!!!!!!!!!!!!!!!
These cribs were recalled, so call simplicity at 888-593-9274 about the recall to be sure but yours is on the list of model #'s. They are sending new hardware and can send indtructions as well. Good luck!
Jul 13, 2008 | Simplicity for Children 4-in-1 Convertible...
Toys Logo
163 people viewed this question
Top Toys Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
