Question about Alessi Al384730-640 Cordless Electric Kettle
Alessi Electric kettle
The switch will not stay on. As soon as it's engaged it turns itself off and has to be manually held on in order for the water to boil
  • Anonymous Apr 25, 2009
    My main problem is the switch won't stay on after lifting the lever. The light only comes on when the kettle is held firmly down or/and turned around its base. Cause is poor contact in a number of possible places which can be solved by sanding the contact points. Another problem is not switching off after water has reached boiling point. Cause in my case was a rusting metal thermo-spring plate (looks like a very thin washer) at one end of the plastic tube that works the cut-out mechanism. Needs to be cleaned and bent slightly more to be more sensitive!
    I have opened the kettle four times to rectify the above problems, but the first problem keeps recurring which suggests a design fault. This is unacceptable for an expensive kettle only 2 years old. Putting back the kettle base components is quite fiddly and the switch lever has become brittle and can easily break in the process.
    I am looking to replace the whole of the black coloured unit that controls the switching etc. Does anyone know where to find one? Alessi's official UK distributer is utterly useless and am trying to contact someone in Italy.
    JosephR
    I have a similar problem with an Alessi kettle not staying on without a lot of pressure or turning around its base.
    JosephR
    Genius:
  • 1,673 Answers
The switch is most likely defective and has to be changed. It is also possible that the heating element is pulling too much current and also has to be changed.
An appliance service tech would have the tools to test the kettle and determine the exact fault.
Jerry G.
Posted on Apr 29, 2008
Kettle not heating up water but electricity is reaching the kettle
How to fix an electric kettle part 1 - YouTube
? 4:51
https://www.youtube.com/watch?v=P4dcq5p0FyU
Apr 15, 2013 - Uploaded by Anthony Findlay
how to troubleshoot and fix an electric kettle. ... I am using akettle had small problem the switch was not working so I have tried to fix it but I am ...
HOW TO REPAIR ELECTRIC KETTLE - Fix Your Electronics ...
electronicsolutn.blogspot.com/2012/10/how-to-repair-electric-kettles.html
Oct 25, 2012 - Electric Kettle is a kitchen appliance that contains a heating properties used for boiling water, cook food etc. It is made up of a metal or plastic ...
electric kettle light but not heating Questions & Answers - Fixya
Dec 08, 2015 | Hamilton Beach 40996 Programmable 1.7...
Can I get element replacement
According to their website and the parts available no. Write to their customer service and protest that you don't want to discard a perfectly good kettle because the element has gone. These days kettles are classed as a throw-away item.
MG32 Electrical appliances Alessi
Nov 04, 2015 | Alessi MG32 Cordless Electric Kettle
It blew my fuse box, i have changed the fuse the light comes on but it is not heating up approx 5 years old
This happened to my Alessi kettle also. I changed the fuse in the plug but the kettle is dead! Red lights are on but the heating element in gone. From what i can gather parts are not available to fix it.
Feb 15, 2011 | Alessi MG32 Cordless Electric Kettle
My daughter bought me an Alessi cordless kettle for Christmas 2008. After 9 months it simply stopped heating water! The red light was lit on the base, so we knew the fuse hadn't gone, but it was completely...
Have you tried using it on a different socket outlet ? Possibly there is a problem with the wiring at this socket.
If the electricity supply "trips" at the consumer unit it is either the RCD which trips due to e.g. the base of the kettle becoming wet or alternatively the MCB tripping due to an overload which shouldn't happen unless there is a fault in the kettle.
When you got a replacement kettle presumably they replaced the base also?
Sep 01, 2010 | Alessi Al384730-640 Cordless Electric...
MG32 Cordless Electric Kettle: Power light shows on my kettle but water does not...
sounds like there's water in the element. Empty it out and let it dry out completely for a few days, and then try it again.
If the element is a concealed element (ie- you can't see the coils when you open the lid up) then there's probably a water leak into the sealed compartment.
Contact the manufacturer for a recommended repairer.
May 17, 2010 | Alessi MG32 Cordless Electric Kettle
Where can I get a new filter disc for my alessi bird kettle
Fill it with vinegar and leave to soak overnight/for two nights if really bad.
Any parts which are impossible to fill with vinegar - lids/spouts, soak a cloth or tissue in vinegar and wrap/wedge into....and leave to soak overnight.
Dec 07, 2009 | Alessi 9093 Cordless Electric Kettle
Kettle will not stay on
Sounds like the switch is weight sensitive. A safety feature to prevent overheat as contents run low? The baseplate is probably not moving freely enough to move accordingly.
Sep 13, 2009 | Alessi MG32 Cordless Electric Kettle
Alessi Tea Pot(not electric)
I do not understand why i must pay all I want to know is how to clean the greae from the Alessi non electric teapot so far I have tried 10 different produsts nothing works. thanks
Aug 29, 2008 | Alessi 9093 Cordless Electric Kettle
Alessi Al384730-640 Cordless Electric Kettle Logo
839 people viewed this question
Top Alessi Kitchen Appliances - Others Experts
Jerry Greenberg
Jerry Greenberg
Are you an Alessi Kitchen Appliances - Other Expert? Answer questions, earn points and help others
