Question about Whirlpool Refrigerators
Not cooling and freezer not freezing - Whirlpool Refrigerators
    Genius:
  • 1,478 Answers
If your refrigerator is not cooling, the problem could be any of the following, follow the steps below one after the other to fix the problem of your refrigerator not cooling.
First of all, the most simplest thing to do is to check the temperature. It might have happened that the temperature control may have been turned off unknowingly, which is the reason for the problem. So if that's the issue, just set the refrigerator at 37 degrees and you are all set.
Poor coiling leads to a heavy frost build up on the evaporator coils. A frost build up, specially on the ceiling of the freezer, is a sign of problem in the self defrosting system or damaged gaskets of the doors. Therefore, check if the refrigerator is facing such a problem and defrost the refrigerator. It would not cool well if the defrosting is not happening properly.
A dirty condenser may be the culprit for your refrigerator not cooling well. What will happen in case if the condenser is dirty is that it will cut off the extra load. That work is done by the thermostat on the side of the compressor in case the refrigerator heats more than usual. To rectify this problem clean the condenser coils using the vacuum cleaner. These are either behind or beneath the refrigerator
In case the refrigerator is not leveled, that too can lead to the refrigerator not cooling properly, because if the level is not right, the door of the refrigerator may not close correctly, causing cooling problems. If this is the case, it might be necessary to ensure that refrigerator is at level and is slightly tilted back. Do some adjustment to get that correct level using a wooden block or see if the screws on the leveling legs need some looking into.
Check out the door seal. If the door seal is worn out, it will definitely result in frost build up and that won't allow the door to close properly, thus the problem of refrigerator not cooling. In addition to that there can be a problem in the door even if the level and other things are fine. You would need something to do about the door then. May be loosen the hinges and fix them in order to get the correct position of the door. Eventually tighten the hinges.
The food and freezer sections will go dysfunctional if the evaporator fan is not working properly. This is because then there will be no airflow to the freezer or the other sections of the refrigerator. Confirm if both the fans are working well by listening to the sound emitted by them. There is a possibility that one may work and the other wont. For that, may be you would have to look for a blockage or something in the one which is not working. Even after doing this you do not find any problem in the fan, you may need to replace it. This are are the general procedure for troubleshooting refrigerator not cooling. with all this, you should be able to identify and fix the problem.
Take care.
Posted on Aug 04, 2010
My freezer will not freeze or cool. I checked the compressor and us cool to the tough but the copper is very hot??? Help please
Repair for a Freezer That Is Running But Not Freezing ...
homeguides.sfgate.com > ... > Other Types of Mortgages
Also, using a freezer to cool hot items or opening the freezer frequently will affect the... the freezer is running but not freezing is improperly packing the contents.
Fix a freezer not freezing but still cold - YouTube
? 1:34
www.youtube.com/watch?v=hCUewYVyiFQ
Aug 19, 2013 - Uploaded by Dave Here My freezer wasn't doing a good job freezing but there was ice on the back ... If not, approximately how often will I need to repeat the process?
Oct 19, 2015 | Refrigerators
Fridge won't cool but freezer working fine
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Oct 31, 2011 | Refrigerators
Fridge not cooling.
Oct 23, 2011 | Candy CPCA240FFK Bottom Freezer...
Refrigerator is not cooling
Oct 23, 2011 | Refrigerators
My amana refrigerator is not cooling, freezer is working
Oct 22, 2011 | Amana ARB2217CSR Bottom Freezer...
Fridge not cooling... Freezer is fine
Sep 12, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My freezer is working but the refrigeration part is not cooling enough
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start.In your case freezer is cooling, then freezing, but its not defrosting.Thats why fridge section is not cooling.------- Click this link below and follow the troubleshooting:---- http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html ----------- This will help.Thanks.Helpmech/.
Aug 19, 2011 | Amana ARB1917C Bottom Freezer Refrigerator
My Magicchef fridge is not cooling but freezer works perfect..How do i find the problem
Jul 28, 2011 | Magic Chef CTB1502AR Top Freezer...
Freeze run cool but want freeze water on the floor under the upright freeze
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost TimerProblem
Water Runningin refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jun 21, 2011 | Kitchen Ranges
Not cooling or freezing
bimetal switch not working. change it.
Aug 02, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
