Question about Maytag Neptune MAH6500A Front Load Washer
Washer spins and then stops seconds after start mah3000aww serial #2511XXXXUF replaced motor control board and motor with 12002039 conversion kit due to blown glass fuse on original board. Also replaced wax motor. Now when I start the machine, the drum rotates for a few seconds and stops. All else stays on (ie, water continues to fill). Putting it in spin cycle drains water, but again, drum rotates a few seconds and then stops. Any advice?
3 Suggested Answers
  • 109 Answers
SOURCE: maytag neptune mah3000aww spin problem
there are 2 wires going back to the board. They connect to a blue harness. Make sure their is continuity thru the harness. It connects to 3 out of balance swithches. Also check to see if lock light comes on.
Posted on Jul 07, 2009
SOURCE: Maytag Neptune washer model #MAH4000AWW,
we have the exact same probem. did you find the solution to this problem?
Posted on Jul 14, 2009
WILL NOT REACH FULL SPIN CYCLE, loud hum prior to spin, starts to spin, hits second speed but will not kick into full speed.
I would suspect that you have a Motor and Motor Control Problem. This washer has a three phase motor in it and it could have one phase out of it or the Motor Control board could be bad. However it is recommended that you replace both at the same time with a motor conversion kit.
Jul 15, 2010 | Maytag MLE2000 Front Load Stacked Washer /...
Maytag neptune mah3000aww spin problem
Jul 07, 2009 | Maytag Neptune Washer
Strong electrical smell with smoke coming out
Check the lower motor control board. See www.neptunehelp.com for disassembly pictures. It is possible you will need to replace the motor control board and motor if you have the original one as Maytag has redesigned these two components due to reliability issues. The new motor conversion kit is part # 12002039.
If there are any burnt components on this board then it will have to be replaced. There is also a 10 amp fusesoldered to the board. if this fuse blows the tub will not move anymore and the motor control board / motor will have to be replaced.
Have you noticed your Neptune's spin cycle getting loud? If so, the seal kit and bearings need to be replaced. See www.neptunebearing.com for more info on the special bearing tool kit you can rent that includes use of a DVD that shows you how to disassemble Neptune, replace bearings and install the seal kit.
Feb 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
Machine will start and then stop
It sounds like the motor control board is shot. Inspect the MCB for burnt components or a blown 10 amp fuse. This board is located down by the floor on the right side. See www.neptunehelp.com for disassembly pictures.
If you have a blown 10 amp fuse or there are burnt components then the MCB will need to be replaced along with the motor as Maytag has redesigned them to be more reliable. The new part number is 12002039, which is a motor conversion kit. It takes about an hour to install.
Feb 16, 2009 | Maytag Neptune MAH5500B Front Load Washer
MAYTAG MAH6500AWW-WASHER WILL NOT AGITATE/SPIN
Check out the motor control board near the floor on the right side. These have a high failure rate on the Neptunes. Maytag redesigned both the motor and motor control board to be more reliable. While inspecting this board, you are looking for a blown 10 amp fuse and /or burnt components. If you have either... then you will need the the new 12002039 motor conversion kit which includes the motor, motor control board and the wire harness.
See http://www.neptunehelp.com/index_files/Page667.htm.
This kit takes about an hour to install.
Don't forget to replace your door latch wax motor. See www.neptunehelpsong.com to hear a funny song explaining the faulty door latch failure.
Feb 07, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Washer MAH3000AWW
This is out in cyberspace Cant remember what or where. Do a search for "Maytag Neptune shuts off"
Sep 17, 2008 | Maytag Neptune Washer
MAH5500BWW model fuse blown
You probably need the motor conversion kit 12002039. This Neptune motor / motor control board has a high failure rate. To determine this you need to remove the front cover and inspect the motor control board near the floor on right side for burnt components or a blown 10 amp fuse. If you have burnt components or a blown fuse then your motor control board has failed and needs to be replaced. See www.neptunewaxmotor.com for Neptune disassembly pictures and other neptune information.
Dec 31, 2007 | Maytag Neptune MAH5500B Front Load Washer
Neptune MAH3000 Stops
did you just replace the fried part or did you get the board kit guest you may have a bad tacogenerator in the motor check the resistance of the motor
Dec 12, 2007 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune front load washer (top of the line)
some of the early washers had problems with a weak or faulty motor . take front panel loose and look at motor board it may look burnt on some of the resistors or look at the clear fuse at front of board it may be burnt if so use a motor/board conversion kit p#12002039.
Oct 26, 2006 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune MAH6500A Front Load Washer Logo
165 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
