Question about Garmin 12CX GPS Receiver
Replacing memory battery for Garmin 12cx
Having the same problem with most Garmin 12cx and to both of mine. i want to openit up myself n replacethe internal memory but have no clue how to open the unit. Soldering is no problem. Cant find a recharegable lithium battery though - where to get one?
3 Suggested Answers
KingDWS
  • 1606 Answers
SOURCE: Replacement Memory Battery
The Garmin GPS III and III plus use a tabbed lithium coin battery. Its is a Panasonic BR-2032. You can buy these for about $2 from larger electronic suppliers. The problem is that the shipping or minimum order will make that $2 battery cost you about $25. For you cheap guys there is a solution. You buy a CP-2032 and a coin holder. $2-3 for the battery and $1-$2 for the holder. 6 screws to open the case, cut the wires close to the battery as possible. Solder the wires to the coin holder (good idea to heat shrink or cover the solder joints), put in the new battery and you are done the easy bit. You will most likely have to trim away some of the plastic on the holder such as legs or other things sticking out. Unfortunately you can't really do this with out fitting it in the case and you don't want to do that until you have the holder on the wires so it will be in the right place. Once you get that, simply play with it until you can put the screws back in. And tighten gently. Not too much or the gasket will be squeezed too far out. Put tAA'sx AA's back in, take it outside so it has an unobstructed view of the sky, set it down and go for a long coffee or three. It will now download the almanac and any other data which can take 15 minutes or more depending on the satellites. You should see a low battery error and other errors such as saved data lost. Ignore these. You can put it on a external power plug or just leave it off with the AA's and in 5-7 days it will have reset the error as it figures it it now charged. You get the battery error even with a new fresh charged battery. I think there is a Garmin reset code to force this but none of the codes I have tried have worked.
Posted on Nov 13, 2008
SOURCE: What sort of internal memory battery is in my garmin 12xl?
You can find the battery here:
http://www.mouser.com/Search/Refine.aspx?Keyword=658-VL1220-1VC
To open the case, scrape the sealant in the grove around the unit; then use a flat screwdriver, as wide as possible, that fits in the grove. Place the screwdriver on all sides and different places. Rotate the screwdriver gently until the glue tears and both gps housings can be separated.
To replace the battery you will need to be handy in soldering in tight spaces.
Posted on Mar 30, 2009
Garmin fr60 footpod
Read this BEFORE you buy a new Garmin footpod because of non-detection issues after replacing batttery.
My battery died and after changing it with a new one I've not been able to detect the footpod with my 910xt until now. I notice that in the cap or lid of the footpod where the battery sits before closing it sits a white piece with contacts for the battery. I had inadvertently taken this out when replacing the battery, which is fine BUT you have to put it back in a certain position. If you look very closely at the cap where the battery sits you will notice there are tiny grooves where the contacts should sit into. As soon as I line these up with the white contact piece, voila! Footpod was immediately detected. Try it if you are having issues after replacing a new battery.
Aug 28, 2012 | Garmin Forerunner 50
How do the 4 batterys install
Remove the battery cover by turning the thumb loop at the bottom of the GPS 1/4 turn counter clock wise. Insert the batteries and replace the batter cover.
For more info view the manual, page 1: http://www8.garmin.com/manuals/GPS12CX_OwnersManual.pdf
You will need Adobe Reader to view the file: http://get.adobe.com/reader/
Feb 03, 2011 | Garmin 12CX GPS Receiver
I am getting a Memory Battery is Low - how do I recharge or replace teh memory batter. I only load AAA batteries into the equipment?
The memory battery is normally charged by the AA batteries. Leave the batteries in for 5 days. If this doesn't recharge the memory battery then it needs replacing. It's recommended that you send the unit back to Garmin to have it replaced. The memory battery is a Panasonic VL 1220. If you want to attempt changing the battery yourself there's some information on how to do so at http://forums.groundspeak.com/GC/lofiversion/index.php?t38975.html
Nov 08, 2010 | Garmin GPS 12XL GPS Receiver
Replacing memory battery garmin gps 75
The battery inside is a panasonic 3v Panasonic
Battery, Lithium, 3v, 190ma, Coin
cell
884-0301 BR2032
You need a clip too
Keystone Electronics
Battery Holder, Coin-Cell; 20
mm; 0.896 in.; Glass Filled
Nylon; 1; 1 AWG
Remove battery pack. Open unit by the six small screws in the back. The coin battery is in the bottom right (mine had a blue cover) The original ones are soldered/pressed in. Replace with the holder and rewire. Cheers
Apr 12, 2010 | Garmin GPS 12 GPS Receiver
Nuvi 200 power plug loose - only if cord pushed to right will it accept power from cord. Want to open unit to fix.
Please see this link for more information on this problem. Please do not attempt to take your unit apart and you might cause additional damage to the unit.
http://www.sharc.net/gps_charger_repair.htm
- Jim
Sep 11, 2009 | Garmin 12CX GPS Receiver
Garmin 350 no sound
Please read this article I wrote on this problem.
http://www.fixya.com/support/r1091233-no_sound_or_garbled_sound_garmin_nuvi
Taking apart the Nuvi requires the right tools. There are delicate flex cables for the LCD, touchscreen & antenna inside. They can be easily damaged if your not careful.
Having worked on Nuvi's, I have never found a loose wire for the speaker. It's possible, but not probable. More likely you have a intermittant voice coil. Please read my article to further diagnose your Nuvi problem.
- Jim
Oct 02, 2008 | Garmin 12CX GPS Receiver
Memory Battery Died in my Garmin GPS 12XL...Can I replace it?
Wildstreak, same happened to my GPSMAP 180. Its old and no longer supported by Garmin. I did call them and they gave me the model and number of the battery (mine is a Panasonic) Also advised that units are heat sealed so I am taking mine to a local electdronics shop that also sells Garmin and have them replace the battery.
Seadrive Joe
Aug 29, 2008 | Garmin GPS
Motorola pebl wont turn on
take it to a reapir store close to you to have it check....try using a new battery and see if it turns on if that does not work then have it check
May 11, 2008 | Motorola Mobility PEBL U6 Cellular Phone
Garmin streetpilot c340
It sounds as if the battery may be defective. I would contact Garmin and they can assist you in getting a new battery installed.
Jan 09, 2008 | Garmin 12CX GPS Receiver
Garmin 12CX GPS Receiver Logo
98 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
