Question about Frigidaire Affinity 5.8 Cu. Ft. Electric Dryer
Begininng two weeks ago, my Fridgidarie Affinity dryer will not spin, on any setting, with or without load inside. I've tried reducing clothing load, removing load, checking water level in open discharge pipe, leaning on top - nothing! Not only will it not spin as part of the regular wash setting, the 'spin only' option does not work, either. Frustrating!
  • collette001 Aug 04, 2010
    Oops. It's the WASHER that won't spin. Laundry fatigue has set in ...
    President:
  • 1,554 Answers
I believe this is a washing machine in contrast to the statement that it is a dryer. Remove the rear panel to check and make sure that the drive belt is not broken or has not slipped off the drum and the motor pulleys. Also check if the motor is running. If not, the motor speed control is the problem.
The machine has provision for error codes should a fault is detected. Indicate the fault if there's any to determine what exactly the problem is. You don't have to accept or reject and rate this post to add information or post comments and follow-up questions. Accepting a solution does not stop you from communicating with an expert. You can continue communicating with the expert as long as you need assistance regarding the issue stated herein.
Posted on Aug 04, 2010
Clothes are coming out wrinkled more and more, why?
believe the dryer has a wrinkle release feature which might help in reducing wrinkle if you leave the clothes in dryer for too long after cycle is complete. Check user manual for details. If you don't have user manual try to download from this website. http://www.manualowl.com/m/Frigidaire/FASE7073LW/Manual/174806
Jun 27, 2014 | Frigidaire Affinity FASE7073LW
Why is my Affinity dryer not heating as well as it was put new dryer hose in back just taking touble time to dry a small load of clother & I double spin the load also
Good Morning Friend,
I understand that your Frigidaire Affinity dryer is taking double the time to dry a small load of clothes. I also see that you have put a new dryer hose on the back of your appliance to try and correct this issue. I suggest making sure that you have also cleaned out the lint filter as well as where the lint filter sits. You can clean the lint filter by running it under the hottest water you can stand and using a cleaning brush, gently, to remove any build-up. You can clean where the lint filter sits with a small attachment on your vacuum. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 13, 2014 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
My Washing Machine is not spinning all the water out of my clothes.
Front loading washers are notorious for not spinning the water out of a small load of clothes. This is because there is not enough clothes in the washer to balance the tub during the spin cycle.
Try washing a slightly larger load with a minimum of six items or more. This is one of the downsides to front load models and no specific brand is immune to the problem.
Mar 17, 2013 | Frigidaire FAFW3517KN Affinity Series...
My front load washer wont go into final spin and clothes are soaked
What is the model number of the unit?
Try running it in a different cycle to see if it does the final high speed spin.
Post back the results.
Nov 08, 2012 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
My Frigidaire Affinity front loading washing machine model #ATF6000FS1 won't spin when loaded.What's the problem?
sounds like you have something in your pump stopping the water draining it will not spin with water try unblocking the punp
Sep 27, 2012 | Frigidaire Affinity Washing Machines
My dryer quit working this morning. The light and beep go off but the drum dies nothing.
I have the Frigidaire Affinity Washer and Dryer. A few weeks ago my Washer door switch went out I changes that with no problem. Now the Dryer has just stop quit working. Here are the symptoms on the ; 1>it's plug up and the power is fine 2> there is no errors on the panel 3> control operate fine. 4> close the door, set the controls, press start, No spinning. 5> when you press start you hear a buzzing sound for about 5 seconds, then nothing... Is it over for the dryer I bought 3 years with out extended warranty, or is the a simple fix? Thanks, Rob...
Sep 07, 2010 | Frigidaire Affinity AEQ6000WH Dryer
Dryer does not dry clothes but seems to be hot inside when i open the door
Most of these guys get a bad blower wheel. The heat melts the hub causing it to spin free and airflow is reduced. This makes it take fifty forevers to dry a load of clothes. More Here
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 18, 2010 | Crosley Dryers
How do I go to clean cycle-Frigidaire affinity ATF6000fs
I was doing a search for infor on how to clean my affinity front load washer, and came across this infor and this did not work for me either, but when I turned my dial to rinse and spin then hit clean the clean option appeared.
Jan 21, 2010 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Affinity 5.8 Cu. Ft. Electric Dryer Logo
Top Frigidaire Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
