Question about Audiovox Audio Players & Recorders
WHEN YOU KEY THE MIKE ALL IT WILL DO IS SQUEEEL. CHANGED THE BATTS. Bill Kasley
  • 677 Answers
Hi, it's usually caused by either the speaker or the ball capacitor that controlls the sound from the hard way.
If you can replca your self,please contact a skilled personnel for help.
Take care.
Posted on Aug 04, 2010
Did Mike Pence sign a bill that would jail gays for applying for a marraige license
It would appear so. Although this link suggests the law existed, the bill he signed changed the penalties. https://www.reddit.com/r/lgbt/comments/5b58gm/in_2013_mike_pence_signed_a_bill_that_made_it_a/
Nov 03, 2016 | Cars & Trucks
I have an '02 Buick Rendezvous with a problem with the charging system. I got a new battery but haven't changed the alt. Some people have told me its the alt wire that charges the batt. Please help.
Yes that is true BUT
most of the time this is simply a dirty cable to battery connection.
Did you clean the cable connection down to silver color inside when you changed the batt? Folks buy new batts all the time when all they needed to do was clean and tighten them.
With the engine running put volt meter test leads one to ground and on each side of of alt out wires one then the other. should be 13+ volts
then put them on each side of battery and it should be the same. If not take it to the Auto PARTS store and have them check the alt for free.
Hope this helps Mike
Mar 06, 2016 | Buick Cars & Trucks
I have changed the backup battery, i have charged it for about 22 hours, but when i turn off the electrical supply, it goes off! ( the ups) MUSTEK POWERMUST 800
Remove batts, Check battery connector, fuse and batt volts, if you have dummy load (car headlight etc) check batts are working and measure voltage under load.
Also check if UPS needs to be told there are new batts read manual or check support for maker.
Let me know what you find, hope this helps
Thanks for using FixYa
Jul 30, 2010 | Mustek PowerMust 800 (POWERMUST800USB) UPS...
Key mike no hears me but shows meter
You didn't mention if you hear the other radio. If not, here's a common problem and solution.
That's usually a defective amc stage that produces RX audio and TX modulation. It's an integrated circuit that will require a tech fixing it. You will have a transmitted carrier with no modulation, and no sound in your speaker. However, make sure you have a good mike plugged in first, and substitute a known good mike to verify it's not the mike.
However, if you hear them, and they see your signal, but no talk (modulation), then the problem is usually your mike. Try another one in this case. Thanks, Bill
Jul 27, 2010 | Cobra 19 Ultra II CB Radio
Logitec mouse stopped working. Changed batts,
If light on bottom does not come on can only be one of 2 things
A Duff batteries
B Mouse is a bin job.
Aug 31, 2009 | Logitech Cordless Mouse
Hi, my 320D remote key fob was working. It slowly stopped working, firstly it would only unlock and then it would do nothing. It would manually unlock/lock and start the car. I have managed to obtain the...
The battery in your remote key fob can be changed.But the spare key has to be programed to work.Take your main key to the dealers And have them do it for you.
Jul 06, 2009 | 2002 BMW 3 Series
Cant start my 3 series BMW, its become immoboilsed, replaced batts in car and key,
All I can say it's either your spark plugs or something, check your spark plugs, go to like AutoZone and get them changed. If you do it yourself, then you're gonna need a long socket wrench to take them out and replace them.
Jan 30, 2009 | 2004 Lexus SC 430
LX7 Mouse False Low Battery Reading
I have found that sometime these Rodents seem to have a "Taste" for a certain "Type" of AA or AAA cell, one needs to get the Highest Discharge rate one can get. Often the "Brand" of Batts supplied are the "Only" ones that seem to work 100% alla time? I have had similar problems with customers B4, and I find the Varta series of battery to be great. & remember just because you bought them "New" don't mean the Batts are always "Fresh", get batts from a place that has a high turnover.
Aug 10, 2007 | Logitech LX7 Cordless Optical Mouse
85 people viewed this question
Top Audiovox Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Chinmay Joshi
Chinmay Joshi
Are you an Audiovox Audio Player and Recorder Expert? Answer questions, earn points and help others
