Question about Elna 1010
Finding a manual for elna lotus 1000
Help please
I can't figure out how to refil my bobbin
Is there a trick to it?
thanks
I have the same problem! Did you find a solution?
Posted on Jan 27, 2011
    Problem Solver:
  • 4 Answers
Check out the site sewingmanuals.com and see if they have your manual there. it's not free, but for about $8-10 you can download the manual and have it within minutes....another site that i was able to find my manuals was in sewusa.com. try that way if you haven't figured out how to refill the bobbin.
Posted on Apr 26, 2008
Elna Lotus bobbin wont insert
YOu have got to get the bobbin case out. Turn the flywheel with great strength to make it bring the needle up. Take the foot off and the needle out.
Dec 01, 2017 | Elna Sewing Machines
Having trouble replacing the bobbin case
Elna SP ST SU sewing machine repair tips - YouTube
? 2:25
https://www.youtube.com/watch?v=TqrbimZyP1U
Oct 24, 2011 - Uploaded by Absolute Sewing
More Photos on replacing gears and some repair ti... ... I amhaving trouble with my Elna SU 62 skipping stitches when I sew on knits. ... Elna Lotus SP bobbin case repair - Removing a cotton jam from a Elna Sewing machine ...
Amazon.com: Bobbin Case 627569106 - Elna, Janome ...
Jan 12, 2016 | Elna Sewing Machines
Winding bobbin on old elna lotus
I can help you with this, the Elna Lotus has a pretty simple bobbin winding system, the bobbin winder is top right of the machine, drop bobbin with holes to the top onto the spindle. Now Lotus have a dial on the right side which switches between bobbin winding, stitching and locked for transport, turn it to Bobbin symbol. Take the thread from the spool pin at the back across to the metal eyelet at top front (it sits inside the accessory tray when transporting so you may need to pop open the tray lid and flip this eyelet out)
24421001-h4211ohbpts0t3j0sbmab0vm-2-0.jpg Now take thread across and through a hole on top of the bobbin and holding the tail, put your foot onto the foot control to get a couple of winds onto the bobbin to hold the thread. Now place your finger or the handle of a pair of scissors onto the top of the thread spool to apply tension so that the thread winds evenly and slowly wind the bobbin until about 3/4 full, making sure it winds evenly. Tension onto the spool is the key here, Lotus doesn't have a tension device to control the thread tension as it winds so you need to do this, critical to getting a good stitch out of these lovely machines.
Hope this helps you out.
May 14, 2014 | Elna Sewing Machines
Where can I find the Mandal for an old portable Elna Sewing machine?
you could start at sewingpartsonline.com, they have a list of Elna models with manuals and spare parts. You will need to find the model number however, it should be on the right side panel, a little plate with Tavaro SA and a two digit code number. If its a Lotus code might be 15, 25, 35 or 36. Also, if you do have a Lotus, please go to my solutions and find mine regarding winding a bobbin. The Lotus has no tensioner on the bobbin winding so it is critical that you tension the thread by applying your hand or scissors to the top of the thread spool as the thread winds off it and use your finger to nudge the thread so it feeds onto the bobbin nice and evenly. If you bobbin has wound without tension then the thread will be loose and uneven and you will never get a good stitch from it. Also, check that you are clicking the bobbin thread into the tension spring on the bobbin case. I'll attach an image to assist.
Apr 18, 2014 | Elna Sewing Machines
Thread from the bobbin is not getting looped
If the bobbin case rotates freely it is probable that the pinion gear is broken. Replace the gear, retime machine and voila it works again. Trouble is tough to find the gear anymore good luck it is a good machine and worth the effort
Jan 09, 2014 | Elna Sewing Machines
I inherited my mother's Elna Lotus SP sewing machine. She had the sewing guide inside the machine, but not the instruction manual. I need to know how about the bobbin and how to thread?
Hi Jeanne, you might want to check out my tip on early Swiss Elnas,
http://www.fixya.com/support/r10602655-acquired_early_swiss_elna_sewing
it should help you get the Lotus going. Lovely machine. If you are in the USA you may also want to contact White Sewing Center as he may have this manual available for sale or a copy of it. www.whitesewingcenter.com.
Remember to use the Elna 7 hole dished metal bobbins, there are 7 holes on the top, and looks like this11_7_2011_6_23_57_am.jpg
Always wind it and insert it into the machine this way. Don't use any other bobbin. Standard needles 130/705H, flat shank to the back.
Check out my other tip on bobbin winding too, it is important to keep tension onto the thread spool that you are winding thread off as the machine doesn't tension the thread for you. So you need to apply pressure to the top of the thread spool as you wind off, use the curved handle of your scissors on the top of the spool.
Feel free to connect to me and ask if you have any other questions, I have a Lotus TSP at home and its almost identical to the SP. Happy stitching.
Oct 30, 2011 | Elna 2007 Mechanical Sewing Machine
I have an elna lotus sewing machine and have refilled the bobbin but cant remember how the bobbin goes back into its place. the machine will sew for awhile and then the cotton gets tangled .can you help...
Is this a Swiss made Elna Lotus with top loading bobbin (check machine plate on right beside power inlet for manufacture details) ? (the original Lotus was released back in 60's but that name has been reused on a number of different models since, some made under licence elsewhere) If yes, then the following applies:
Bobbin should have holes on one side only, always wind it with the holes on top and load it into the bobbin holder the same way so it is rotating anti clockwise when you pull the thread.
Drop wound bobbin into bobbin holder and, while holding the bobbin still with one finger, pull the thread tail towards you into the tension spring, then press down on the thread until you hear it "Click" into the tension spring.
Then hand wind the fly wheel towards you while holding the top thread tail to catch the bottom thread and bring it up to the top needle plate, close the back sliding plate over the bobbin.
Other thing with these machines is ALWAYS hold the two thread tails firmly when you start a new seam so the threads don't get pulled down into the bobbin holder area. Really important.
You can dowload a manual from www.arizonaexpressionz.com for most of the Swiss machines.
If it is not Swiss made one, then your bobbin may be vertical front loading (like the Brothers).
There are threading diagrams for lots of machines at www.sewusa.com, there might be one there that covers your machine.
May 22, 2011 | Elna Sewing Machines
Part for sewing machine
Raceway drive gear and I think you can only get them from an Elna dealer.
Nov 06, 2009 | Elna Sewing Machines
What bobbins will work with a vintage Elna Lotus SP sewing machine?
I did a search and found this post for you. I hope it will help.
The best-known Elna guru is Ray White, aka "Elnaman". He teaches classes on sewing machine repair but his speciality is Elnas. You can order parts or contact him at his website:
http://www.whitesewingcenter.com/index.p…
or you can contact him directly at:
Ray White
White Sewing Machine Center
PO Box 73
Bellview, MO 63623
Phone: 573-697-5841
elnaman@whitesewingcenter.com
You can also join the yahoo group "elnaheirloomsewingmachines" where very knowledgeable Elna owners/collectors share information and answer questions. Enjoy your Lotus!
Sep 02, 2009 | Elna Sewing Machines
Sewing Machines Logo
1,135 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
