Question about Philips Magnavox 27MS343S 27" TV
Locked tv my son lost the remote so he was messing with the buttons and set parent controls and locked the tv.after he shut it off the last time now the tv cant be turned back on. I have a magnavox 27ms343s.can it be fixed? I have no working remote.
  • samkap Nov 11, 2008
    I hv tried pressing 0711 but the sign of red colour lock is not going what to do please help.
  • 934 Answers
Unplug the unit for 5 minutes... After you plug it back in try to power it up. If it won't power-up it's not the result of any lock feature you have another problem... If it powers up and Smartlock is on try this:
The entry code for AutoLock (Magnavox SmartLock) to reset the password code number is 0711 twice.
However, if 0711 is entered just once, the response to first time will be "INCORRECT". If the word INCORRECT is allowed to time out then the second entry of 0711 is not accepted.
To avoid this response when the first 0711 responds with INCORRECT, Immediately enter 0711 a second time. It will then ask for the new code.
Enter the new code and confirm it (2nd time) and proceed to set the blocking as desired.
If you want to purchase a remote for it try here: http://remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m1=27ms343s&uuid=12091926696600
Good Luck!
Bill
Posted on Apr 26, 2008
Lost remote tv fpa lock is on tv has solid red light help
This is the method to unlock an RCA tV:
Most RCA sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
  1. Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Nov 23, 2012 | RCA Televison & Video
Sansui TV/VCR/DVD combo
This solution is provided by one of our experts premtech
Child Lock
Combos
--Should have original remote. Press and hold the power button for 6 to 10 seconds
Combo Model T25208, V-Chip Forgotten Password
If you forget your password, simultaneously press VOLUME down on the TV/VCR front panel and the 0 number button on the remote for a few seconds. This resets the password and you can enter a new one.
Combo Model 13TVR62, V-Chip Forgotten Password
If you forget your password, press STOP/EJECT on the TV/VCR front panel and MENU on the remote simultaneously. This resets the password, but not the limits you’ve set.
Televisions with Parental Lock Feature
If you forgot your password for this feature, press the following buttons on the remote, one at a time. (Note: You must be in the password entry screen) Press, Mute, Display,Clear and Reset, this unlocks parental controls and you can now re-enter a new password.
OR TRY THIS..
Press and hold Menu on the TV AND volume down on the remote for 3 seconds. Nothing will appear on the screen, and the Parental Controls will unlock, and you can re-enter a new password with the LOCK PARENTAL CONTROLS
CTC169AU
Channels that have been locked can be viewed only when the PARENTAL CTRL function is set to OFF. This can only be done with the remote control-it can not be changed with the buttons on the front of the TV.
Therefore, after you turn on PARENTAL CTRL, you simply hide the remote control so that your children can not watch the locked channels. The locked-out channels will remain unviewable even if the TV is unplugged or the channels are autoprogrammed again. The only way to view locked channels is to use the supplied remote control to set the PARENTAL CTRL function to OFF.
The PARENTAL CTRL and the CHAN CTRL functions work hand-in-hand. The instructions below will first tell you how to turn parental control on or off with the PARENTAL CTRL function and then how to lock desired channels with the CHAN CTRL function.
1. Repeatedly press MENU to select SETUP MENU, and then press + or - to display setup functions. Repeatedly press MENU to select the PARENTAL CTRL function. . When this function is set to ON, PARENTAL CTRL is activated and any channels you locked with the CHAN CTRL function will not be viewable. . When this function is set to OFF, PARENTAL CTRL is deactivated and all channels are viewable.
2. To lock channels, press the MENU button to select the CHAN CTRL function. Select a channel you want to lock by pressing CHANNEL up or down. Then press +. The CHAN CTRL setting will change from NORMAL to LOCKED when that channel is locked. To return the channel to NORMAL, press the - button. Repeat step 2 for each channel you want to lock. If the PARENTAL CTRL function is set to ON while you are locking out channels, each channel will go blank as you lock it. When the PARENTAL CTRL function is set to ON and a channel which has been locked out is tuned, the TV will display the words PARENTAL CONTROL to let your kids know you have locked it.
CTC185's
If the front panel function buttons don't work, (menu, ch up/dn etc.) but the functions work normal with the remote, enter the "Channel" menu with the remote and turn "Parental Control" off.
CTC203's
In the event you have forgotten your password, perform the following procedure:
Press and hold for 3 seconds the TV button on the remote while pressing the menu button on the TV.
This procedure will turn off the parental lock and erase the previous password .
Another Possibility To Try For Various Models: If TV's in the Parental mode and askes for a password that's forgotten, Press menu on the TV, select Parental Lock #4 on menu, then with the remote press Mute, Display, Clear, and Reset buttons in sequence.
TX808 Chassis
If Parental Controls have been set and you don't know the password, do this:
Press and hold the volume down and the channel up buttons at the same time for 5 seconds.
Now you can reset the password to 0000, and using that password you can now access the V-Chip menus.
TV's (Made by Daewoo or possibly Apex, ie. GE model 24GP653)
The factory default pass code of 6688 is also the override code, in case the owner forgets their pass code. If that doesn't work, another place in the owners manual says to push Function and Mute on the remote at the same time. Function is the top right button.
Jun 28, 2008 | Sansui DTV2760 27" TV
Tv shutting off wont let me delete parental code, i dont know what it is
You can reset the parental pass-code.
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset procedure is different depending on the model. Try each method until you find one that works:
1. Hold down MENU on the remote and VOLUME DOWN on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
2. Hold down the 0 on the remote and the VOLUME DOWN buttons on the TV its self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
4. Hold down GO BACK on the remote and MENU on the front of the TV at the same time for at least 4 seconds.
5. Hold down EJECT on the front of the TV and the MENU button on the remote at the same time for at least 4 seconds.
Sep 02, 2012 | RCA TruFlat 27F520T 27" TV
My son some how used the universal remote to set the pass word on the V-chip controls. Now I am locked out and cant get any channels.
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
  4. Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Mar 05, 2011 | GE Televison & Video
Lost parental control password
Hello
You can unlock your RCA tv by the folloing method. After unlocking it, you have to set a new parentioal control password.
Most RCA TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
Feb 26, 2011 | RCA 27F534T TV
I have a rca tv model no F27318, parental controls are locked and the password is lost
Hello
I know one way to unlock RCA tv. I'm not sure about whether it works with combos or not. Anyway try this. If you gets positive result. please inform me to my mail also.
Ok
gopakumarg43@ymail.com
gopalan.gopakumar327@gmail.com
Feb 22, 2011 | RCA Televison & Video
RCA 20V500T television. Inadvertently set FPA (parental control) to on. I shut TV off thinking it would reset. It is now in standby (in accordance with manual). It can only be turned on with remote. ...
Hello
You just try the following to open your TVs lock.
You must have its remote to unlock it.
OK.
Dec 23, 2010 | RCA 20V500T 20" TV
Locked tv
You need to buy a remote for that TV. They're available online for around $39. This site has them in stock, but you can shop around to be sure its a good price. When you receive it, turn on your TV and press menu on the remote and turn off child lock. Click the Remote here:
http://www.newremotecontrol.com/catalog/dyn_models_accys.php?modnum=27MS343S&hash=e91e6348157868de9dd8b25c81aebfb9
Nov 19, 2008 | Philips Magnavox 27MS343S 27" TV
Parental lock
Child Lock
Combos
OR TRY THIS..
CTC169AU
CTC185's
CTC203's
TX808 Chassis
Mar 26, 2008 | RCA TruFlat 27F520T 27" TV
How to disable parental lock
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset procedure is different depending on the model. Try each method until you find one that works: Hold down MENU on the remote and VOLUME DOWN on the TV it?s self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked. Hold down the 0 on the remote and the VOLUME DOWN buttons on the TV its self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. Hold down GO BACK on the remote and MENU on the front of the TV at the same time for at least 4 seconds. Hold down EJECT on the front of the TV and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET. Good Luck
Aug 18, 2007 | RCA F27664 27" TV
Philips Magnavox 27MS343S 27" TV Logo
134 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
