Question about Sony KV-32V65 TV
Sony TV Toubleshooting Help
My Sony TV KV-32V65 take a while to power on. The standby light blinks for several minutes (1-5 minutes) before powering on. Apparently, this is the amount time it takes before the relay turns on. Once its powered, the picture keeps periodically/randomly blacks/blanks out for a couple of seconds. The picture quality, color and sound are all fine. What could be the problem?
    Scholar:
  • 186 Answers
I had the same problem. Can't remember where, but I had to re-solder some joints. If you look very closely to the bottom of the motherboard, you might be able to see a cracked solder joint, otherwise carefully touch each one to fix it. Easy fix and the tv's been running flawless for going on 3 years now.
Be careful to not touch anything on the high voltage side with your hands. Even with it unplugged.
Posted on Apr 26, 2008
Sony Triniton TV KV 32FS120 will not turn on
In standby mode (red led on/after the led stops from blinking), press "Display", "5", Volume (-)", "Power on" on the remote control in sequence, self diagnostic screen will be display, let me know the what is on the screen to diagnose where the fault came from.
Nov 25, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
TV does not power up. all we get is a red blinking led. Is there a fuse or something else simple to check?
It seems that the TV has an internal malfunction. The TV requires service.
Please contact the nearest Sony authorized service center to get it serviced.
Jul 13, 2010 | Sony KV-32V65 TV
Standby light blinks twice after turning itself
this a code that mean overvoltage in power supply (+B)
Mar 20, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My sony trinitron kv-32v65 has no picture - standby light blinking - sound works through the bose sysytem, just no picture - help
if you cant repair a tv take it ot a w/shop and have it checked. let your tech check that an ht voltage of 95-105 is reaching a line transistor, also a transistor be checked for leaks, also let him check a line transformer, and the surrounding tin capacitors for leakages and change of values.
Mar 11, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Kv-32fs16, no picture or sound , red lights flash 4 times
Hi
In sony tv`s the 4 blink code(sony error codes)usually means that there is a vertical deflection problem.
It is often caused by a faulty vertical output i.c and/or related components. If you feel handy with a soldering iron let me know and i`ll help you with it.
Hope this help Merry Christmas
Dec 17, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
KV-40XBR700, won't come on, standby light blinks 7 times.
sony KV40XBR700 tv no picture but sound is on, standby light blinks 6 times
Jul 20, 2009 | Sony KV-40XBR700 40" TV
Sony wega tv was on and it shut itself off and we tried to reset power and the standby light is now blinking red 6 times with no picture.
Why not try this.
If it is a tube type.
1. Turn off the TV.
2. Disconnect it from the outlet.
3. Connect the power cord after 1 minute
4. Power the TV.
Mar 01, 2009 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Sony Triniton Wega Model KV 32HS510. After pushing the power button,the tv starts to power up, then the standby light blinks 7 times then pauses before blinking 7 times again. It continues to do this,...
This is usually an indication of a failure in the scan amplifier sections. When the scan amplifiers or high voltage sections fail, the main power supply will usually also require servicing.
It is very common that the fly-back and high voltage multiplier and also the horizontal output stage fails in these sets. Along with it, the power supply will usually require to be serviced. On rare occasions, the vertical deflection amp fails.
Jerry G.
Jul 08, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
No picture on a Sony KV-32V65 TV
AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the Cboard, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking.
Jan 18, 2007 | Sony KV-32V65 TV
Sony KV-32V65 TV Logo
134 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
