Question about Hoover F5866-900 SteamVac Deluxe Wet/Dry Vacuum
HOW DO I GET TO THE MOTOR TO CLEAN AND LUB IT SO IT WONT FREEZE UP
  • Hoover Master
  • 43,501 Answers
First clean it up with some WD-40 and then lub it with some light weight motor or sewing machine oil...
heatman101
Posted on Aug 04, 2010
Miele vaccum cleaner wont run
If dirt or other debris collect around the armature of the motor the stator will no longer communicate and turn. Usually the brushes wear down and need replacement also. Once you replace the brushes and clean the interior of the motor housing, the motor should start up again. AS long as there is no smell, the motor parts are still in tact. You will also need to replace the belt from the motor spindle to the brush.
Feb 17, 2018 | Miele Vacuums
My dyson does not start. I cleaned it out and also cleaned the filter and now it wont start
It could ba a bad cord, switch, motor, wire, etc. Check all these area first.
Apr 01, 2017 | Dyson Vacuums
I stored my FH50220 in my storage unit over the winter and now it will not spray water
If your storage unit got below freezing it may have frozen and damaged something. It's hard to drain all of the water from pumps, tubes, valves, heaters etc. inside a carpet cleaning machine. If a machine must be stored where it may freeze one way to keep it from freezing up is to pour automobile windshield washing solution into the fresh water tank and run it through the machine until it comes out all of the Jets and cleaning attachments. Remove the fresh water tank and continue to run the solution through the machine to flush the windshield cleaner out of the machine. Be sure to use a cleaner with the proper anti-freeze rating and run fresh water through the machine before using it to clean carpets.
Apr 01, 2016 | Hoover FH50220 Vacuum
What maintenance does it need?
any moving metal part can be lubricated. moving plastic parts require dry lub.
May 18, 2015 | Shark Vacuums
Vacuum cleaner Motors plural shut off during operation.
Probably not. Both motors usually wont stop working at the same time. You have given us very little information. Model number? Brand?
May 10, 2015 | Vacuums
Dyson wont turn on and its a bit smelly
It sounds like the motor has overheated and has now been irrepairable damaged.
The motor has a built in over-current trip to protect itself (and you if it seriously overheated and caught fire). This normally automatically resets itself, however if the motor has just about had it, the moment it is switched on, it just trips again.
The primary cause of motors overheating is that the filters are not cleaned or replaced frequently enough. Dont be fooled by Dyson's "lifetime filters". They need to be regularly cleaned and replaced when necessary.
Replacement motors are avaible on eBay2_bing.gif for about £25, however repalcing one requires good DIY skills and tools.
Have a look at www.dysonmedic.com and see if you feel you can tackle it yourself. If not, take it to a repair shop or call the Dyson helpline.
Mar 18, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Hoover F5866-900 SteamVac Deluxe Wet/Dry Vacuum Logo
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
