Question about Cameras
Memory card not read and not format please solution
  • kakima Aug 04, 2010
    What make and mode camera? What type and size card? We want to help you but we can't read your mind.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Cameras Master
  • 102,366 Answers
Having gone over a month without a response, I assume this is no longer a problem.
Posted on Sep 19, 2010
My 2 gb Micro sd card can not format and 0 byts memory card
dont worry ............please connect your card with pc and press right key then select property after its please disable read only property and format .............then your card will be format..........
Jul 10, 2011 | SanDisk 2GB microSD Memory Card
In sert SD card turn on camera. screan shows Memory card refquires formatting, continue and stills reads card needs formatting. put new card in and does the same. Camera does not read card always say card...
Hi halestone26,
I would like to help you out with this problem ,
Please follow the below instructions :-
  1. Make sure that your remove the memory card out of the camera and connect it to your PC via a card reader.
  2. After you connect the memory card , to your pc via a card reader , you should get a removable drive icon relevant to your memory card in your my computer folder.
  3. Then all you need to do , is select format by right clicking on the card , and then when you see the options in format dialog box you need to select the NTFS and FAT32 one at a time and format the memory card and then check if it works with NTFS file system in your memory card or FAT32 file system.
  4. Unless your memory card is damaged , the above solution works 90% of the times.
Hope this helps ..:) Your feed back would be appreciated.
Jun 21, 2011 | Kodak EasyShare DX4530 Digital Camera
Cant read my m2 memory card after installing some games on my phone
hi....
This is because your memory card may be affected by virus.please delete the games which you installed and try weather it is reading your memory card.
if it is not reading please scan your memory card with proper anti virus,stil the problem presists then format your memory card it wil be ok.
if you can please take a back up of your memory card as when you format the details will be lost.
thanx
Jul 16, 2010 | SanDisk 2GB Memory Stick Micro M2 Memory...
Panasonic Lumix will not read memory card.
try formatting your cd card in your Fz. If it keeps telling you memory error, try using it in windows, put data on it, to see wether it can hold them and read them too.
Happeded to me once too, format did the job. Just format it in the camera, not your pc.
Vladimir
Jul 01, 2009 | Panasonic Lumix DMC-FZ50K Digital Camera
When i turn the camera on....it saids memory card requires formatting. then continues to say formatting will delete everything on memory card. i press continue and nothing happens. goes back to say memory...
Use a computer with memory card reader, and read the card using a computer.
If the computer says the same and does not read the card, then the pictures inside the card are usually lost.
If computer instead does read the card, then transfer all picture on computer using the memory card reader, and format the card using complete formatting.
If you need to use the camera tonight, then buy a spare memory card.
If the camera returns same error on different card, then you may have a faulty memory card slot, but that is quite uncommon.
Regards
Jun 18, 2009 | Kodak EasyShare C875 Digital Camera
Foramtting scandisk
If this memory card will be connected to a camera you can simply put the memory card to the camera and there you can format it using the camera's menu, you can also format this memory card using a card reader that will be connected to your computer, just put the memory to a card reader then connect it to the computer that way you can also format the memory card....
Dec 29, 2008 | SanDisk 2GB microSD Memory Card
Memory Card!!!!!!!
format a memory card through DOS mode
GO on command prompt then go on drive of memory card e.g. remove device f
Mar 13, 2008 | Kingston flash memory card - 256 MB -...
Memory card
this cam will work up to 2gb sd/mmc
what's the capacity of your card? if it's above that, it's really not gonna work with this cam
if your card is 2gb or lower
2 possibilities:
defective card - please try another card
camera memory reading problem - arrange repairs with kodak
Jan 20, 2008 | Kodak EasyShare C663 Digital Camera
"Memory card cannot be read"
My camera used to do the same thing--once I got the pictures off my card, I left it in the card reader, right clicked on removable media (my computer + removable storage) chose to "format" and formatted it on my computer. It seems to have fixed the problem, and my camera now reads it fine. I tried to format it on the camera before, but it didnt work.
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
Cameras Logo
29 people viewed this question
Top Cameras Experts
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
