Question about Kitchen Ranges
Replace the oven control?
You said to "replace the oven control". After reading online of numerous complaints of the same problem with these stoves, ... I too assumed it was the oven control panel. However, is this something that a layperson can attempt? My husband is a building contractor/carpenter, but has never taken apart a stove before. What are the chances that he figure this out on his own?
    Genius:
  • 1,073 Answers
The replacement control will be just like the one that is bad label the wires befor removing and put back on the new control in the same place
Posted on Apr 26, 2008
Maytag Oven model MER5755QAQ has lock on the display and the oven will not operate.
If one of the position switches on the latch assembly is not reading, the control will sometimes lock because it "thinks" a clean cycle has been initiated, if replacing the control did not fix the lock icon, test the switch... Incorrect temp probe and thermostat failures can also make a control "think" it is in a clean cycle. Maytag Range Stove Oven Door Lock Motor and Switch Assembly WP74008702 Maytag Range Stove Oven High Limit Thermostat 74008715
Jul 06, 2016 | Maytag Kitchen Ranges
Black & Decker Toaster Oven CTO650 ... Numbers around dials has worn off. Where can I get a replacement panel?
Search Results
    Black & Decker CTO650 1500 Watts Toaster Oven - Read ...
    www.epinion.com/.../Black_Decker_CTO650_Toaster_Oven.../3529132...
    Black & Decker CTO650 1500 Watts Toaster Oven No complaints Is it really ... Cons:Numbers wear off around dials after years of wiping. ... It has a see-through glass door, 30 minute timer, variable temp up to 450 degrees F and signal bell.
    Black & Decker CTO650 1500 Watts Toaster Oven No complaints i should'a bought this one Is it ... Cons: Numbers wear off around dials after years of wiping. .... It hasa 4-slice or 9 pizza capacity and touch button controls with LCD display.
Jan 28, 2016 | Toaster Ovens
It is obvious that there is a major design problem with this model in that numerous enquiries under Kitchen Aid's "popular solutions" deal with a multitude of self-cleaning issues. We have had to...
NEVER use the self cleaning mode.
Sounds like my problem two days ago. I have a Kitchen Aid free standing gas oven/range model
KGRI801PWH00. I read online that the thermo-fuse might've blown. I found the thermo-fuse after removing the rear panel. It was at the top/center. Mine is T-O-D (brand) 60F24; Westinghouse #8300802. I ordered mine from appliancepartspros.com for only $34.75; arrived in 36 hrs with regular shipping!! Easy to fix, sure beats several hundred $$ to repairman.
Don't bother to call Kitchen Aid - they'll just blow you off just like the hundreds of complaints said that I found online.
Jan 25, 2011 | KitchenAid KESA907PSS Electric Kitchen...
The oven burner will not ignite.
Because the glowbar is glowing does not necessarily make it good.
Turn off the gas to the stove. Remove the oven racks. Remove the bottom oven pan. Remove the flame spreader. This gives you access to the glow bar and gas valve.
Put a clamp on amp meter around one wire of the glowbar. Turn the oven control on to BAKE.
If the glowbar reads 3 amps or less,replace the glowbar ignitor.
If the glowbar reads good,check the burner tube for a white ash buildup. It can be cleaned with a wire brush. Look closely near the glowbar section of the burner.
Check all the wire connections for the gas valve.
If the glowbar is good and the ash deposits are gone and the oven still will not ignite,the next step is to replace the gas safety valve.
Dec 01, 2009 | Amana Ovens
The lower element in my Admiral Sentry stove is not working. there is no layout for fuses so not sure what fuse needs replaced
It is not a fuse issue. Turn off the power to the oven. Remove the screws from the lower element. Pull the element out carefully. DIsconnect the wires. Take a volt/ohm meter set for ohms or continuity. Touch the 2 leads from the meter to the 2 element wire terminals. If you get no reading,replace the element with a new element.
If you do get a reading reinstall the element and replace the oven control.
Sep 21, 2009 | Stoves 720EF Electric Double Oven
Nedd a top oven element for brown stove 24"
since you're online, do an online search for the company and inquire about a replacement element for your model.
Apr 24, 2009 | Kitchen Ranges
F6 f8 and f12 error reading on stove
F0 & F1 EOC (Electronic Oven Control) failure Replace Electronic Oven Control F2 Oven too hot Check Bake function, if OK, replace oven temperature sensor F3 Oven temperature sensor open Check oven temperature sensor, should be ~1100 ohms at room temperature. If too high or low, replace oven temperature sensor F4 Oven temperature sensor shorted Replace oven temperature sensor F5, 6, 7 EOC (Electronic Oven Control) failure Replace Electronic Oven Control F8 Lock switches Check switches and replace if necessary
Oct 27, 2008 | Tappan TGF320 Gas Kitchen Range
GE Oven not working
hi
you may need a new control board. if your stove is in warranty contact the manufacturer, if not and you are handy you can find a replacement online and install it yourself. just be sure to unplug the stove before you work on it. if you need help with this please contact me.
Mar 21, 2008 | Ovens
Oven will not start, stove top works fine, possible lightning strike.
hi thom,
You are likely correct, you may need a new control panel, they are very sensitive to power surges. If you are handy you may be able to find one cheap online and replace it yourself, just be sure to unplug the stove or turn off the breaker before you work on it. if you have any questions on how to do that please contact me.
Mar 20, 2008 | Kitchen Ranges
Kitchen Ranges Logo
147 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
