Question about LG L1730S 17" LCD Monitor
No power, 5 volts line is fluctuating periodically (about every one second) between 3 and 4.5 volts. no other measurements done yet... thank you for help DM
  • Louis Ebert Aug 04, 2010
    dinu182, Supply rail is going "in and out" of shutdown mode. What does the other supply rail do??? +12v dc. Have you found any bad (swollen) electrolytic filter capacitors on the SMPS/inverter board? Have you visited YOUTUBE to look at video clips?? 12fixlouie
  • 11,361 Answers
Caps look good? it may be in safety shutdown/restart mode. Try heating up the power supply board with hair dryer to see if it will start up, when bad caps are heated up the caps ESR will go down and may allow the power supply to start up. I use 6vdc small lamp attach to the 5vdc so I can see the lamp comes on or not.
http://s807.photobucket.com/home/budm/allalbums
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Aug 05, 2010
Where is the tcr sensor? code c140f
04 GC
TCR?
easter egg hunt 1000
clear the code with any scan tool, if it comes back, it real
do that yet (as we do with all DTCs on all cars?)
so dash cluster showed, C140F, right?, not a real scan tool
not autozoned? scanned.?
if not fully scanned, how would you know there are 5 more DTC's
and that be very important.
why is last, tests are next unless gue$$ is the game.
and you wonder why?
MY FSM BOOK shows.
C140F-TRANSFER CASE RANGE POSITION SENSOR ERRATIC PERFORMANCE
this is pretty clear, and the steps to test it is in the same book.
quotes. (part)
The Final Drive Control Module detects excessive voltage fluctuation on the Mode Sensor Signal circuit.
quote
2. (T504) DRIVETRAIN 5 VOLT SUPPLY VOLTAGE ERRATIC
NOTE: This DTC sets when the Final Drive Control Module
circuit. Perform a thorough inspection of all wiring and connectors
between the sensor and the control module.
Turn the ignition off.
Disconnect the Transfer Case Motor harness connector.
Turn the ignition on.
Measure the voltage of the (T504) Drivetrain 5 Volt Supply circuit.
NOTE: Voltage should be approximately 5.0 volts and steady.
Compare any slight fluctuations found to a known good circuit in
order to verify voltmeter functionality.
Is the voltage approximately 5.0 volts and steady?
Yes >> Go to 6
No >> Go to 3
end, quote (partial)
14 checks above is 1st.
got a voltmeter
no the buy a new swtich.
checked all 4 + fuses related to this?
the plug is on the transfer case.
here it is.
Mar 02, 2015 | 2004 Jeep Grand Cherokee
I am trying to troubleshoot whether or not my ultra x2 connect 550 watt power supply is bad. When you press the power button on the computer, the light flashes and then noth9ing else happens. The light...
Well here is a way to check your power supply, on your hard drive connector using your volt meter and measuring from ground. this would be using one of two middle connectors it should measure +5 VDC on the red wire and + 12 VDC on the yellow wire. If these voltages are good then we got to see if the power supply is producing the -12VDC voltage. This voltage is ussed by the syustemboard on pin 14 of a 24 pin power supply. I would recommend not having your system board plugged in while measuring these votlages, but the power supply may need a load, I would plug in the cdrom.. Below are a couple of picture to explain this and a link to a website that has this documented.
http://www.playtool.com/pages/psuconnectors/connectors.html
dfish26_1.jpg The 24 pin main power connector was added in ATX12V 2.0 to provide extra power needed by PCI Express slots. The older 20 pin main power cable only has one 12 volt line. The new 24 pin connector added one line apiece for ground, 3.3, 5, and 12 volts. The extra pins made the auxiliary power cable unnecessary so most ATX12V 2.x power supplies don't have them. The 24 pin connector is polarized so it can only be plugged in pointing in the correct direction.
Pinout Pins 1 through 12 Pins 13 through 24 Description Wire color Pin number Pin number Wire color Description +3.3 volts orange 1 13 orange +3.3 volts +3.3 volts orange 2 14 blue -12 volts ground black 3 15 black ground +5 volts red 4 16 green PS_ON# ground black 5 17 black ground +5 volts red 6 18 black ground ground black 7 19 black ground PWR_OK gray 8 20 white -5 volts (optional) VSB +5 volts purple 9 21 red +5 volts +12 volts yellow 10 22 red +5 volts +12 volts yellow 11 23 red +5 volts +3.3 volts orange 12 24 black ground
Good Luck I hope this helps.
Nov 19, 2010 | PSA Ultra X2 Connect (ULT31851) 550-Watt...
Mitsubishi 62 inch microdisplay hdtv w/screen w/zy
I have a list of problems common to this series here:
Cause #1
1. (Lamp may light and go out) suspect bad lamp part # 915P020010 2. Check for
12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check
for an open F9A09 on the Power PCB, if it is open replace F9A09 part #
283P127060 and the Light Engine part # 939P977010 3. (Lamp may light and go out)
Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if
low or missing check C9A37 and C9A38 both 3300 UFD 10 V part # 181P732040 on the
Power PCB (part # 930B921002) 4. At power on the lamp turns on and off three
times and then the unit shuts down with a red lamp LED (lamp error). Replace the
Light Engine part # 939P977010 5. Lamp enable line at J14 pin 6 does not switch
to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light
Engine part # 939P977010 6. Lamp enable line at connector J14 pin 6 on the
Engine Driver PCB switches to 5 volts after turn on and does go to 0-volts (low)
after 5 seconds, 12 and 5 volt supplies are good. Suspect the Lamp Power PCB
(ballast) part # 939P978010 7. Lamp enable line at connector J14 pin 6 on the
Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-
volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light
I would start with #3, checking the 5 volt line and replacing the listed capacitors if needed.
Please be sure to rate this solution. Thanks!
Nov 09, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Red light on no picture will work fine after several minutes
There is a list of things you need to check, but offhand I'd say that the 5 volt line is low and probably right on the"edge", which is why it works sometimes and not others take a look at this list:
Cause #1
I would say try #3 first, the two caps on the pwer supply board. A couple of warnings: as always, unplug the unit before servicing. The power supply is located on the left side, if you behind the unit. It is in a shielded box and the shield has VERY SHARP EDGES so use care when you try to open it or you will slice your fingers.
Nov 08, 2008 | Mitsubishi WD-57731 57" Projection HDTV
Mits 527252 ballast
Good Day; I would suspect the ballast, but try these first:
Causes: Cause #1 1. (Lamp may light and go out) suspect bad lamp part # 915P020010 2. Check for 12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check for an open F9A09 on the Power PCB, if it is open replace F9A09 part # 283P127060 and the Light Engine part # 939P977010 3. (Lamp may light and go out) Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if low or missing check C9A37 and C9A38 both 3300 UFD 10 V part # 181P732040 on the Power PCB (part # 930B921002) 4. At power on the lamp turns on and off three times and then the unit shuts down with a red lamp LED (lamp error). Replace the Light Engine part # 939P977010 5. Lamp enable line at J14 pin 6 does not switch to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 6. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on and does go to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Lamp Power PCB (ballast) part # 939P978010 7. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010. Good Luck, big IRISH.
Nov 03, 2008 | Televison & Video
Wd52525 Ballast
Good Day, monkbuist;
TRY THIS:
1. (Lamp may light and go out) suspect bad lamp part # 915P020010 2. Check for 12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check for an open F9A09 on the Power PCB, if it is open replace F9A09 part # 283P127060 and the Light Engine part # 939P977010 3. (Lamp may light and go out) Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if low or missing check C9A37 and C9A38 both 3300 UFD 10 V part # 181P732040 on the Power PCB (part # 930B921002) 4. At power on the lamp turns on and off three times and then the unit shuts down with a red lamp LED (lamp error). Replace the Light Engine part # 939P977010 5. Lamp enable line at J14 pin 6 does not switch to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 6. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on and does go to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Lamp Power PCB (ballast) part # 939P978010 7. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010. Good Luck, big IRISH. back.gif
Jun 21, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Flashing yellow
Good Day, davidsonkens;
Try the lamp first; to check try this:
TXN2771HF (5yr old) - Front Panel a/o Remote Issue
Sounds like the 5 volt supply is low, Look for the 5 volt regulator, Measure you can go directly to the sensor 3 pins 1 will be 0 volts one will have 5 volts the other is usually a fluctuating 3-5 volts if 1 pin has to have 5 volts if it is low check capacitors around the 5 volt regulator probably 47uf to 100uf look for rusty look on the leads. If you see it change it! check these voltages with set turned off ( standby ) do not attempt if you dont know what your doing. Good luck. The reason it works when it is on is because there is a run 5 volt supplement.
Jun 20, 2008 | Samsung TXN2771HF 27" TV
New Lamp turning off after 5 seconds
Apr 25, 2008 | Mitsubishi WD-52525 52" Rear Projection...
New Lamp Replacement, still a No Go.
1. (Lamp may light and go out) suspect bad lamp part # 915P020010 2. Check for 12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check for an open F9A09 on the Power PCB, if it is open replace F9A09 part # 283P127060 and the Light Engine part # 939P977010 3. (Lamp may light and go out) Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if low or missing check C9A37 and C9A38 both 3300 UFD 10 V on the Power PCB (part # 930B921002) 4. At power on the lamp turns on and off three times and then the unit shuts down with a red lamp LED (lamp error). Replace the Light Engine part # 939P977010 5. Lamp enable line at J14 pin 6 does not switch to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 6. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on and does go to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Lamp Power PCB (ballast) part # 939P978010 7. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 Hope this helps!
Aug 21, 2007 | Mitsubishi WD-52525 52" Rear Projection...
LG L1730S 17" LCD Monitor Logo
94 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
