Question about Gateway Computers & Internet
What is the max (RAM) memory the Gateway Tabor 3 Coppermine WS440BX Motherboard will thak. Also memory type please.
    Sergeant:
  • 206 Answers
After doing some research, I found that you had an Intel motherboard and used a website called www.crucial.com (Crucial is a brand of memory and have some useful tools on their website) These are the specs that came up. You can view the same information at this web address http://www.crucial.com/store/listparts.aspx?model=WS440BX
It also shows the price of the upgrade! Hope you find what you are looking for!
  • 168-pin DIMM Banking: 3 (3 banks of 1)
  • Chipset: Intel 440BX
  • Error Detection Support: ECC and non-ECC
  • Graphics Support: AGP 2X
  • Max Component Density: 128Mb
  • Max Unbuffered SDR SDRAM: 384MB
  • Module Types Supported: Unbuffered only
  • SDR SDRAM Frequencies: PC66 and PC100
  • Supported DRAM Types: SDR SDRAM only
  • USB Support: 1.x Compliant
Q: Will my system recognize the maximum upgrade?
A: Possibly How much memory your Windows OS will recognize depends on which version of Windows you are running. 32-bit versions of Windows will see (and utilize) only 3GB or 3.5GB. To utilize more memory, install a 64-bit version of your OS. More information about OS memory maximums can be found at http://www.crucial.com/kb/answer.aspx?qid=4251.
Q: What memory goes into my computer, and will a faster speed be backward-compatible?
A: SDRAM memory with support for SDRAM, PC133 speeds. Because SDR memory is backward-compatible, you can safely upgrade your system with any of the guaranteed-compatible SDR speeds listed below.
Q: How much memory can my computer handle?
A: 384MB.
Adding the maximum amount of memory will improve performance and help extend the useful life of your system as you run increasingly demanding software applications in the future.
Q: Do I have to install matching pairs?
A: No. No, you can install modules one at a time, and you can mix different densities of modules in your computer. But if your computer supports dual-channel memory configurations, you should install in identical pairs (preferably in kits) for optimal performance.
Q: Does my computer support dual-channel memory?
A: No. Your system does not support dual channel.
Q: Does my computer support ECC memory?
A: No. Your system does not support ECC. Because ECC and non-ECC modules should not be mixed within a system, install the same type of modules that are already in your system.
Posted on Aug 04, 2010
What memory sitck and max n1996 gateway motherboard
Use the Crucial Memory Scanner to identify the type of RAM and Max amount of RAM your motherboard uses. Here it is:
http://www.crucial.com/systemscanner/
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Aug 22, 2011 | Gateway (4000779) Motherboard
Dont know the ram that it use. wat is the number on the battery
  • K8M800-M7A
  • Support DDR 333/400 MHz
  • 2 x DDR DIMM Memory Slot
  • Max. Supports up to 2GB Memory
  • the battery i dont no
  • hope it helps
  • Biostar K8M800-M7A - motherboard - micro ATX - Socket 754 - K8M800 specifications
    • General
    • Product Type Motherboard - Micro ATX
    • Cache Memory None
    • Chipset Type VIA K8M800 / VIA VT8237R
    • Max Bus Speed 800.0 MHz
    • Processor Socket Socket 754
    • Max Processors Qty 1.0
    • Compatible Processors Athlon 64 , Sempron
    • Memory
    • Max Supported Memory 2.0 GB
    • Supported RAM Technology DDR SDRAM
    • Supported RAM Speed 400 MHz , 333 MHz , 266 MHz
    • Graphics
    • Graphics Controller VIA UniChrome Pro
    • Memory Allocation Technology Shared video memory (UMA)
  • Jul 20, 2011 | Biostar K8M800-M7A Motherboard
    Hi Could you please advise the type and size of
    According to the manual, to max out the board's RAM you'd need to install 2 1GB sticks of DDR RAM. It can support DDR400/333/266. 2GB is it's maximum capacity.
    Jul 09, 2011 | Intel Motherboard
    Cant open the tower. i want to add ram. what is the max i can add?
    One way to find out for sure how much RAM your computer can hold is to go to WWW.CRUCIAL.COM and run their SCAN MY COMPUTER feature.
    This handy utility will scan your hardware configuration and tell you exactly how much RAM you currently have installed and what type it is.
    It will also tell you how many RAM slots are fitted on your motherboard and what the maximum memory capacity is for that motherboard.
    If your computer does have room to add more RAM, it will provide you with specific recommendations as to exactly what type and size of RAM stick to get to maximize the memory capacity and performance of your computer.
    Feb 22, 2011 | Gateway Computers & Internet
    What is the Maximum RAM that can be attached to Intel Pentium III with Motherboard "Gateway Tabor3 CopperMine WS440BX"...?
    I had a look on the web and came across an answer. According to he site the WS440BX can only handle 384MB.
    Hope this helps!
    Please rate this..
    Cheers
    Sep 27, 2009 | Gateway Tabor 3 (4000532) Motherboard
    Please identify RAM upgrade options for Asus PSCH-L motherboard. Thank you.
    From the Asus spec site: Memory Memory Type dtrquestion.gif DDR SDRAM Number of Memory Slots 4 x 184 Pin DIMMs Supported RAM speeds 400 MHz • 333 MHz • 266 MHz Max Supported RAM dtrquestion.gif 4 GB
    Memory Memory Type dtrquestion.gif DDR SDRAM Number of Memory Slots 4 x 184 Pin DIMMs Supported RAM speeds 400 MHz • 333 MHz • 266 MHz Max Supported RAM dtrquestion.gif 4 GB DDR SDRAM 400; 333; 266mhz
    4 GB max 4x1024 184pin
    Hope this helps.
    Aug 26, 2009 | ASUS PSCH-L Motherboard
    Update bios........ but i do not now what is the brand of the motherboard please help me important
    Updating with the _WRONG_ BIOS-update can _kill_ your motherboard. If you don't know how to do it _CORRECTLY_ then don't it, or get a certified technician to do it.
    May 14, 2009 | Gateway Tabor 3 (4000532) Motherboard
    Changing FSB & Voltages
    Hi there.
    You can change the front side bus in the bios if the bios supports it, if it does be very careful not to overclock the processor to much as you can cause damage to the motherboard and blow the processor up, also bear in mind that cooling is very important when it comes to overclocking.
    Good luck and thanks for using FixYa!!
    May 13, 2009 | Gateway Tabor 3 (4000532) Motherboard
    Motherboard upgrade
    That computer uses a proprietary motherboard. Only that one or one from the same Gateway family will fit, and the power supply from an old PIII will not work with the newer systems. Don't waste your cash.
    Cheers
    Jan 04, 2009 | Computers & Internet
    Hooking up an ATA card
    What ata card have you got? Do you mean PCI or AGP card?
    Feb 15, 2007 | Gateway Tabor 3 (4000532) Motherboard
    Computers & Internet Logo
    194 people viewed this question
    Top Gateway Computers & Internet Experts
    Prashant M
    Prashant M
    Alun Cox
    Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
