Question about Codemasters Brian Lara International Cricket 2007 for Windows
See error when it loads ,it ask disk key. - Codemasters Brian Lara International Cricket 2007 for Windows
    President:
  • 2,030 Answers
It needs the key code that came with the game on a printed piece of paper.
Posted on Aug 04, 2010
Non system disk or disk error replace and strike any key when ready hp compaq 6730
its asking for its bootup disc.
it sounds like some one has tryed putting its windows disc in but then stopd it before it was finished doing its work.
has some one tryed installing windows?????
Jun 27, 2014 | HP Compaq Evo Notebook N600c
Xp Installation Problem on installing xp home system loads files than reboots into 39 minute prompt, but does change from 39 minutes. The Staus lights continue to move but the system doesn't seem to...
Try cleaning the CD with dish soap and water, u may have a dirty disk, be careful (don't scratch it). Try using a different XP install disk from someone you know, just use your product key instead of theirs when it asks for it. Your install disk is failing.
Feb 14, 2011 | Mercury PVCLE266 Motherboard
I am running windows 7. My system restore does not work. I have tried turning off anti-virus program and fire wall. I have the sysconfig deal. I have made sure the volume shadow copy was on. I have checked...
hi
if the problems not too bad checkdisk might pick up the error, tried that? this navigation is for xp, 7 should be pretty close
my computer/local drive c:/
right click local disk c:
properties/tools/error checking/check now
check both checkboxes, hit start and then itll ask for a restart
if checkdisk doesent get it then I would probably wipe it.
sounds like a virus from a while back got in there and caused a problem
run a "boot time scan" of your antivirus also
good luck..
jm
Oct 03, 2010 | Computers & Internet
On my screen . Invalid system disk. Replace disk and then press any key . This is not working
You have a system error on your computer.it is possible that your operating system software has corrupted and is not booting the system asking you to put in the correct booting disk. If you have the original recovery disk use it to load and run . this will get you system back in order. If not reload the pc with a good OS hoping that all your files were saved into a seperate drive. if not you will have to recover the data - if important- before you format and reinstall the new OS. Hope this helps. Good day
Jun 24, 2010 | Compaq Armada 1700 Notebook
I turn on my compaq and the first thing come on screen is CPU=AMD-K6(tm)/300 00000640K SYSTEM RAM PASSED 00064512K EXTENDED RAM PASSED 0512K CACHE SRAM MOUSE INITIALIZED FIXED DISK 0:FUJITSU...
above 06 lines are related with system information, Go to the BIOS check the startup sequence, if everything is ok save and exit from BIOS.
Apr 01, 2010 | Computers & Internet
My toshiba L500 wont boot up when i turn it on it starts to load files then stops and tries to repair the problem but it does not
There are so many reasons boot up; i.e if system files corrupted by virus or hard disk index tables corruption or hdd partions corruption.
So as a initial trouble shooting try to do following things to resolve problem.
Option 1:
1. Power ON your computer and Press F8 key to have Windows boot menu option
2. Select "Safe Mode with Command Prompt" and Press Enter
3. When command prompt loaded then type follwing command and press enter
chkdsk /r c:
(If this command is not working in "safe mode with command prompt" then start computer with Bootable CD and Press "R" key when first time asked. It will open recovery console and type this "chkdsk /r "command again to repair disk.)
This command will scan your hdd and repair disk errors.
Option 2 :
To repair your windows without losing your data.
Start Computer with bootable CD
Press R when it is asked to press.
It will repair windows.
Note : Please read Status Bar and screen messages /nstructions carfully (while Booting computer thru Bootable CD)
Mar 28, 2010 | Toshiba Satellite L505ES5015 NoteBook
Hello, I have an IMB thinkpad 600E 2645. Previously, i was getting error 00161 & 00163 this was resolved. then i received error 173 & 163 which was resolved as well. It appeared that a piece fro mthe...
there probably is a problem with ur O.S.this is the reason y ur system is not bootin up.try installing O.S from a different C.D.U can use the same serial number as long as you are using the correct installation C.D.u can also go for a diffrerent O.S if u can get it arranged.i think installing a new O.S sud solve ur problem
May 03, 2009 | Computers & Internet
Vista Ultimate Error 0xc004f061
if you have purchased legal copy of Vista, you will be having a Part Number on the Vista DVD. Call Microsoft Tech Support and provide them with this Part Number. they will get a new product key. This will work for you.
Jan 10, 2009 | Microsoft Windows Vista Ultimate Edition
Got following error: Load Error! Press any key to reboot
This problem is indeed caused by a faulty MBR but there are solutions other than zero-filling the drive.
If you can get access to a RipLinux CD there is a little utility called Testdisk that will write a new MBR code to the first block of the drive. I just did this on a Sony PCG-K15 this morning (after cloning the drive just to be safe) that was giving the same error of "LOAD ERROR- Press any key to reboot" and it worked like a charm. The machine booted right up.
Hope this helps...
May 09, 2008 | Computers & Internet
Acer Load Error
Detect the Harddisk in the BIOS setup & if it is detected then also it displays in the same manner then do one thing replace the BIOS.
Sep 17, 2007 | Computers & Internet
Codemasters Brian Lara International Cricket 2007 for Windows Logo
75 people viewed this question
Top Codemasters Video Game Consoles & Games Experts
James Wishart
Nikki  Mclean
Nikki Mclean
Tony
Are you a Codemasters Video Game Console and Game Expert? Answer questions, earn points and help others
