Question about Bissell 3920 Bagless Upright Vacuum
I have a Bissell pet hair eraser model #3920. It's been working great until last night. I went to use it and the brush won't spin. It also smells like it's burning. I checked the belt and it looks fine, and the brush spins by hand easily. It's not clogged anywhere that I can see. Anyone have any other ideas? This vacuum is only 8 months old.
  • 276 Answers
- Remove the access panel, which is on the bottom of the machine. There are 4 tabs to lift on the access panel to remove. Start with tab 1 then 2-4 tabs.
- Check the brush, and belt for any damage. Clean off any debris on the brush.
-The belt may not be broken but may show signs of wear. If belt is broken or shows signs of wear, replace belt.
Posted on Aug 04, 2010
Turbo pet brush not working
I just had the same problem. It would rotate, but barely. I ended up taking the whole thing apart, following some of the suggestions other people posted, to clean out any hair. The big fix was taking apart and spraying some WD-40 on the brush axle. It doesn't look like it comes apart, but if you secure it down and use a nail and a hammer to gently tap in the little hole on the end where the belt grooves are, it will pop right apart. I only lightly sprayed the WD-40, as the last thing I need is clumps of greasy hair in the thing.
Feb 05, 2011 | Bissell 3920 Cyclonic Pet Hair Eraser...
Need a user's manual for bissell pet hair eraser vacumn model 3920
You can get the manual on the link below.
http://img.meijer.com/assets/product_files/pdf/1001371_3920_manual.pdf
Good Luck please rate 4 thumbs up and please leave a testimonial
Oct 13, 2010 | Vacuums
We have a Bissell 3920 with low suction and part loose
Call Bissell at 1-800-237-7691.... press 3 to ask a representative for help... press 1 to find Bissell service centers in your area. You may be able to take it to a local vacuum clean and repair center if Bissell's store is too far from where you are located. That is if it needs to be repaired by a professional.
Jul 22, 2010 | Bissell 3920 Cyclonic Pet Hair Eraser...
My pet hair eraser smells like it is burning all the time and sounds funny. The brush will not spin once you have it on the carpet unless you hold it up a little while you are cleaning but then the whole...
We had the same problem, and it turned out that the roller wheel height setting had broken, for no apparent reason, and was "floppy" so we had to lock it in to one setting with epoxy.
Limits utility, but it works. Sort of.
Mar 16, 2010 | Bissell Upright Vacuum - The Pet Hair...
Bissell pet hair eraser-the brush is not rotating but the suction is working on the removable parts
That means that you need to replace the belt. Here is the belt you need and a manual you can view which has instructions:
Bissell Pet Hair Eraser Belts and Manual
Jan 01, 2010 | Vacuums
Will not cyclone any more. brush on botton will
That means that you need to replace the belt. Here is a link to the belt you need and a manual you can view with instructions:
Dec 08, 2009 | Bissell Upright Vacuum - The Pet Hair...
Last time I used my Bissell Pet Hair Remover vacuum it smelled like something was burning and it left a black mark on the carpet. What should I do?
When you smell burning like that it usually indicates that the belt is worn and slipping on the motor shaft. You probably need to change the belt. You can get the belts for your model here:
Nov 11, 2009 | Bissell Upright Vacuum - The Pet Hair...
Bissell Pet Hair Eraser Vacuum marking carpet
the brush is always turning on the machine even when your using the tools. try not to set it down on thick carpet , or if you can set it on the linoleum.
Sep 16, 2009 | Bissell Upright Vacuum - The Pet Hair...
Brush will not spin any longer
If the brush won't spin at all, it's either the drive belt or the roller beater brush is clogged. Pet hair can quickly clog a vacuum. Turn the unit over and see if the brush will rotate by hand. If yes, it's probably the belt. Also look for debris and clear as much out as possible. You may have to remove the bottom plate and clean the bottom of the unit out. If you do have to go that far, it would be best to replace the drive belt and thoroughly clean the vacuum.
Apr 19, 2009 | Bissell 3920 Bagless Upright Vacuum
Bissell 3920 Bagless Upright Vacuum Logo
466 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
