My Ice machine has sat over the winter and now I'm trying to use it again. I tried to make Ice and all it did was make about two batches of ice and the full ice tray light came on and wont go off.
    President:
  • 2,712 Answers
CLARIFICATION REQUEST:
Hello velvetfog2,
Can you please give me the make and model of your icce machine?
Thanks,
IrishDruid
Posted on Apr 26, 2008
    Genius:
  • 2,035 Answers
The machine is kept for a long period of time without use and that,s reason your facing this problem get it serviced once it fix the issue..
What can I do to fix cem256 ice machine that the refigeration light blinks twice ?
http://hvac-talk.com/vbb/showthread.php?679751-Scotsman-CME256-Water-Diagnostic-Light-Problem
May 15, 2014 | Scotsman Ice Machine - 290lb...
Model b198 makes one batch then stops
Check the bin arm spring you will have to disassemble the front of the ice maker to do this and check timer motor could be getting hung up. not a cleaning problem. or replace the complete head.
Oct 09, 2012 | U-Line Icemaker
Hoshisaki makes ice to slow
not sure what "too slow" is to you. Hoshi machines are designed to make more ice per batch but less batches per day. It is not unusual for a batch to take 25-35 minutes for one batch. The 1600 makes a lot of ice per batch. Look for some obvious things. If air cooled condenser, be sure it is clean. Make sure the water to the machine is not Hot water. It is not unusual to get Hot water feedback in a restaurant environment. Check for a leaking water valve. A sticking float can also cause long freeze cycles. Start with that and let me know if I can be of any further help,.
Jun 04, 2012 | Hoshizaki KM-1600S Stackable Crescent...
My ice machine no longer produces any ice cubes? the machine is about 3 years old. Got it from Home Depot. Is this under warrenty? who should I call for repair service or what can I do to determine a...
If the filter is really bad it won't make ice becuuse the water can't get to it. A way just to check to see if the icemaker is working is to pour a small cup of water into the icemaker and see if runs through the cycle a makes a batch of ice, try the cup of water before you call anyone. If it makes ice then either you need to change the filter(which you should do anyway) or you have a bad water valve. If it doesn't make a batch of ice then your icemaker is bad.
Oct 31, 2010 | Maytag 25.6 Cu. Ft. Side-by-Side...
Km500mae never shuts off
this is easy to fix first you need some food grade hose next put this hose in the bottom of your ice bin then run you water through this hose to the machine fit as much hose as you can in the bin floor and start the machine at night and the other thing you may wish to do is get a remote condenser
Apr 22, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Ice-cream maker doesn't fit together
Do a 1/2 to 2/3 batch. Put a book and a soup can on top of the mixing arm to keep it down.
The machine does make wonderful Ice cream, however it is noisy and fiddly. Do not try the full batch as it just doesn't work. I find doing 2 half size batches works best. Also find a spare room to run the noisy beast in.
Jun 16, 2009 | Cuisinart ICE-50BC 1.5 Quart Ice Cream...
Ice maker very slow to make ice
there may be some thing stuck in the ice machine try checking it out
Jun 02, 2009 | LG LSC26905TT Side by Side Refrigerator
Machine turns on makes one or two batches of ice and then shuts off
Try cleaning the condensor coils. Check the fan blowing across them. When the compressor is running the fan should be too.
Jun 28, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Heating & Cooling Logo
54 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
