Question about LG LS-L1210CL Mini Split Air Conditioner
Gal 0411gk pcb kit - LG LS-L1210CL Mini Split Air Conditioner
Air does not pass 60 PSI motor get hot and don't stop
If this is an oil free compressor then you probably just need to replace the piston ring part # DAC-308 or the complete top end kit.
The parts should omly be about $35.00 and the instruction to replace the parts come with the kit.
Oct 17, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Filled truck up with fuel and fuel guage stoped working
There is a TSB for this issue ( TSB 08-2-9 ).
The problem is high sulfur content fuel will cause a problem with the fuel level sending unit, and cause it to read incorrectly.
The 2 times I had this happen, I was not at my normal brand fuel ( had it happen with Shell fuel both times ).
I fueled at 1/2 tank with my normal brand, and then after another 1/2 tank fueled again, and the problem went away.
If you want, the TSB lists new revision fuel level senders, that you can drop the fuel tank, and replace your exiting one with to cure the problem.
The correct P/N depends on your truck cab & bed config, and options
PART NUMBER PART NAME
8L3Z-9A213-E Kit - Fuel Sender 2006 starting 12/8/2005 through 2008 - FFV-26 Gal Tank - 126/132 WB
8L3Z-9A213-F Kit - Fuel Sender 2006 starting 12/8/2005 through 2008 - FFV-30 Gal Tank - 139 WB
8L3Z-9A213-G Kit - Fuel Sender 2006 starting 12/8/2005 through 2008 - FFV-27 Gal Tank - 145/151/163 WB
8L3Z-9A213-H Kit - Fuel Sender 2006 starting 12/8/2005 through 2008 - FFV-36 Gal Tank - 145/151/163 WB
8L3Z-9A213-A Kit - Fuel Sender 2004 through 2008 - Gas-26 Gal Tank - 126/132 WB
8L3Z-9A213-B Kit - Fuel Sender 2004 through 2008 - Gas-30 Gal Tank - 139 WB
8L3Z-9A213-C Kit - Fuel Sender 2004 through 2008 - Gas-27 Gal Tank - 145/151/163 WB
8L3Z-9A213-D Kit - Fuel Sender 2004 through 2008 - Gas-36 Gal Tank - 145/151/163WB
Aug 20, 2010 | 2004 Ford F150
After filling my fuel tank, gauge does not go to full....it takes a few days or hours for gauge to read full
There is a TSB on high sulfur fuel usage, and how it impacts the fuel level resistance.
If you change fuel, it might start working again. The TSB is : ERRATIC FUEL GAUGE OPERATION TSB 08-2-9
Publication Date: January 22, 2008
FORD: 2004-2008 F-150
LINCOLN: 2006-2008 Mark LT
ISSUE:
Some 2004-2008 F-150 and 2006-2008 Mark LT vehicles, built before 12/3/2007, may exhibit erratic fuel gauge operation or illuminated malfunction indicator lamp (MIL) with diagnostic trouble codes (DTCs) P0460 or P0463, and/or Instrument Cluster Module DTC B1201. This may be caused by sulfur contamination in the fuel causing an open or high resistance in the fuel level sender.
ACTION:
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
Install a new fuel level sender following the service procedure instruction sheet provided in the fuel sender kit.
8L3Z-9A213-E Kit - Fuel Sender (2006 starting 12/8/2005 through 2008 - FFV-26 Gal Tank - 126/132" WB )
8L3Z-9A213-F Kit - Fuel Sender (2006 starting 12/8/2005 through 2008 - FFV-30 Gal Tank - 139" WB)
8L3Z-9A213-G Kit - Fuel Sender (2006 starting 12/8/2005 through 2008 - FFV-27 Gal Tank - 145/151/163" WB
8L3Z-9A213-H Kit - Fuel Sender (2006 starting 12/8/2005 through 2008 - FFV-36 Gal Tank - 145/151/163" WB
8L3Z-9A213-A Kit - Fuel Sender (2004 through 2008 - Gas-26 Gal Tank - 126/132" WB
8L3Z-9A213-B Kit - Fuel Sender (2004 through 2008 - Gas-30 Gal Tank - 139" WB
8L3Z-9A213-C Kit - Fuel Sender (2004 through 2008 - Gas-27 Gal Tank - 145/151/163" WB
8L3Z-9A213-D Kit - Fuel Sender (2004 through 2008 - Gas-36 Gal Tank - 145/151/163"WB
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage And Emissions Warranty Coverage
IMPORTANT: Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part.
OPERATION DESCRIPTION TIME
080209A 2004-2008 F-150, 2006-2008 Mark LT: Install New Fuel Level Sender, Includes Time To Remove And Install Fuel Tank (Do Not Use With 9002A, 9002A4, 9002A6) 1.9 Hrs.
DEALER CODING
BASIC PART NO. CONDITION CODE
9A299 42
Apr 20, 2010 | 2006 Ford F-150
1.5 hp small portable air compressor won't pump up above 22# or so....keeps running but won't increase pressure.
The rings are probably done for. You could rebuild it if you are handy. Get a rebuild kit from Sears. Compare the price of a new one to the price of the kit and your time.
Dec 28, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
What is error code E000025 0002 for a Canon Color Image Runner C3380i and how do you fix it?
Product : imageRUNNER C2880 / C3380 Title : E025 sub code 0002
Problem :
The machine is giving an error code of E025 with a sub code of 0002 indicating an error with the cyan toner motor.
Solution :
Replace the Process Kit Relay PCB. Item 58 of the Hopper Assembly circled below, part number FM2-8266-000. NOTE: the service manual refers to this part as the Process Kit Relay PCB while the parts catalog calls it the Connecting PCB Unit.
getfile.asp?rid=24817
Apr 27, 2009 | Office Equipment & Supplies
Repair Kit
Good Day, gestephe;
Can not get boards from Mits. You and a million others are having this problem. Are you handy? Did you say; yes/kind of?
HERE IS THE SOLUTION FOR THAT PROBLEM AND THE ONES YOU WILL HAVE IN FUTURE:
Replace C81A2,C81A3, C81B3 AND C81B4 (1000uFD, 16 V) On DM PCB.
Replace C8F19, C8F21, C8F22 and C8F27 (1000uFD, 16 V) On FMT PCB.
Replace C9A51, C9A52, C9A61, C9A62 On power PCB.
REPLACE ALL WITH (680uFD, 16V, 105c), part number 181P734030.
Replace C9A37 and C9A38 ON POWER PCB. (3300uFD, 16 V).
Good Luck, big IRISH.
ps; Three boards on left side of TV and about 2.5 to 3 hours of repair time.
Aug 25, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Blinks wd 52525
Thats a 34 code which means lamp abnormality. This is related to the bad capacitors on the PWB PCB just helped a guy last week repair his. You need the repair kit thats called V26 DLP PWB PCB Kit its 35.99 at the following link and contains all the capacitors and a CD that shows how to disassemble the chassis and identify the PCB and which capaitors go where. Heres the link and they also give free tech support to help you with the repair.
http://servicemanuals.vstore.ca/
Jun 30, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Wd-52525
Sounds like the Capacitors on the PWB PCB You can get a repair Kit to fix that its called V26 PWB PCB kit at the following link. It contains the different capacitors and a CD with the info on the repair. Heres the link.
Jun 28, 2008 | Mitsubishi Televison & Video
Error code 7E
Silver Care Kit (Silver Care PCB) Failure.
Check Silver Care PCB ,Main PCB & Wire harness
Jan 27, 2008 | Samsung WF337AA Front Load Washer
LG LS-L1210CL Mini Split Air Conditioner Logo
60 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
