Question about Brady 2461 Thermal Label Printer
Brady printer 2461 is receiving a message position fault. How can this be corrected?
    Problem Solver:
  • 14 Answers
If you are using die-cut and reflective media you have to perform a Positioning Calibration that sets the TOF and calculates the label length of the media. This process also calibrates the ribbon sensor on printers equipped with the thermal transfer option. To do this;
1) Turn ‘On’ and enter the media setup parameters in the Media Settings-Menu
2) Load media (and ribbon, if equipped with the thermal transfer option)
3) Calibrate the Media Sensor
4)
Press and hold the FEED key for approximately 4 seconds or until 2-3
labels advance. Upon completion, the ‘Ready’ message will be displayed.
Please ask if you need any further details.
Posted on Aug 14, 2010
Brady TLS2200. I turn it on and get a error CHKSUM
Once again, first thing in a GOOGLE search!
Brady TLS2200 manual
https://www.cableorganizer.com/images/brady/tls2200/manual.pdf
Page 77 error messages
Error in Checksum
The software was improperly installed on your printer. (or lost or corrupted in the memory.)
Contact Brady Technical support group.
Aug 03, 2016 | Brady TLS 2200 Label Printer
Print preview looks fine but just get a blank label from label mark. prints ok when not done from pc
You likely need to use Brady's software to create the label on the PC, and your PC will need the correct printer drivers to communicate with the Brady. The software and drivers should be available from Brady.
Apr 02, 2015 | Brady TLS 2200 Label Printer
Only printing on first row of labels, even the test is only on the 1st row, I need to use all four rows. Model number is: dmx-m-4036. Serial number is 54732589, we moved it from one factory to another...
Ypur problem may be due to:
- Le paper sensor is not placed correctly. In that case the length of the 4 rows is not correct.
Check the position of the label sensor.
This is a datamax oem printer
Aug 04, 2011 | Brady BP-T300 Printer
I looking Print head for Brady Model 1344 please find to me .
The Brady 1344 printer is really a Datamax E4304 printer with 300dpi print head. A google search will produce numerous companies selling this printhead
Hope this helps
May 15, 2011 | Brady 1344 Thermal Label Printer
I am trying to find a printband for a Brady THT 2034 printer...is this actually a Zebra model that has been rebranded?
In the heading it says Brady BP-THT-600X+ , but in the comments it refers to a Brady THT 2034.
The THT600X+ is zebra, The THT2034 is datamax. I have printheads for both. www.clearprintsolutions.com
Aug 24, 2010 | Brady BP-THT-600X+ Thermal Label Printer
Error message: codesum: C47B72 memory error
Your printer firmware got corrupted or if yu tried to upgrade, it did not complete successfully. Most probably you will have to do a firmware install
Jan 06, 2010 | Brady TLS 2200 Label Printer
Brady 300 mvp displays "Ribbon in" warning. Whats does this mean?
I've got the same issue. This means the brady machine is configured for direct thermal transfer (no labels in the machine). Press setup, use the - and + buttons to scroll to direct transfer. Again, press select and again use the plus or minus button to select thermal transfer (labels in the machine).
I must say that the setup menu is tricky. If a password is needed, that's another story. Not impossible, but you have to know how to use the label maker, which I don't . I'm unable to remove the flashing errror message.
http://www.zebra.com/content/dam/zebra/manuals/en-us/printer/z-rzseries-ug-en.pdf
Dec 21, 2009 | Brady Office Equipment & Supplies
Get a printer head error. Printer needs serviced. Error number 82
82 error indicates the printer encountered a critical error with the EIO (JetDirect) card in slot 2. Recommended action is to power off then back on, Reaset the JetDirect card, or if the error persists, replace the jetdirect card.
Aug 12, 2009 | Brady GlobalMark MultiColor (76800) Label...
I have a brady label machine 2461
Hex dump mode is mostly used for trouble shooting of the printer. To exit the hex dump mode, enter the Diagnostics menu / Hex
Dump Mode and select ‘Disable’. Exit the menu, save changes and
return to the ‘READY’ mode.
Dec 07, 2008 | Brady 2461 Thermal Label Printer
Brady 2461 Thermal Label Printer Logo
263 people viewed this question
Top Brady Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Bob Rambo
Level 1 Expert
NOEL
NOEL
Are you a Brady Office Equipment and Supply Expert? Answer questions, earn points and help others
