Error # 0002 indicates "Fuser temperature not rising at correct pace. Same possibilities as E000" Error #000 refer to a number of possibilities "Fuser did not heat up. Lamp, thermal switch, thermistors, connections, AC driver, DC controller Replace the Fuser Roller also known as the Pressure Roller or Upper Roller to resolve your problem.
First of all I would not recommend even buying a machine this old. Canon no longer makes parts for this machine. If you found one making nice copies and running well I would not pay more than a few hundred at the most.
Good Luck and Thanbk You for using Fixya.
E000Fuser did not heat up. Lamp, thermal switch, thermistors, connections, AC driver, DC controller, SSR, etcE001Fuser temperature too high. Same possibilities as E000, as well as shorted wire
I'm going too suggest the fuser, most likely thermistor
You could probably buy one directly from a third party part supply store over the internet like Ames Supply Company, Katun, or Precision Roller. I only use Canon parts myself but these parts may be a substitute for Canon. But I believe the Part Number is FH7-6080-000 for the scan lamp. Be sure to uplug the copier before replacing the scan lamp because the connector has AC voltage at the contacts. Good Luck.
pretty much the same, the codes are good for several models not just one.
you need to find the other numbers to know exactly which code it is, press the start or stop key to see it display the other #'s.
fuser is on the left side if you replace the parts might as well replace the claws and oil roller.
"E000"
Heater lamp, Thermistor, DC controller
"E001"
Heater lamp, DC power supply / AC Driver circuit board, Thermistor, DC controller.
"E010"
Main motor clock sensor, DC controller PCB, Main motor, DC power supply / AC Driver circuit board
